Seafarer 24 swing keel, keel pivot? Sailing qualities? - Page 3 - SailNet Community
 6Likes
post #21 of 45 Old 03-10-2012
S/V Wyndwitch - Morgan 24
oysterman23's Avatar
Re: Seafarer 24 swing keel, keel pivot? Sailing qualities?
james. Please excuse did not intend any personal slight and do understand that the ss cable issue is not simple. I was reading up on it last night actually...I almost went with the new line as well and may do so this spring if I see any trouble down there at all. The notion that the small diameter steel strands are prone to the pitting effect corrosion that is often noted with the ss underwater makes plenty of sense to me so forgive any unintended slight and lets use my boat as another lab rat since we already have your valid and kind of alarming example let me tell you I dont want to be around for another centerboard letting go! Once is enough thanks
anyway pax and best sailing in the Seafarer!
Cod
jamesnewsome likes this.
oysterman23 is offline
post #22 of 45 Old 03-13-2012 Thread Starter
skygazer's Avatar
Originally Posted by jamesnewsome View Post
After installing the new cable I thought I was home free until about a month later the same thing happened. I started reading and asking questions and the consensus was that the fine strands of the SS cable were subject to natural electrolysis since Stainless Steel is actually an alloy and thus contains metals of different nobility. The fine strands of the SS cable apparently allow the electrolysis process to accelerate.
Since I had my original Kevlar cable made by West Marine, the newer Amsteel Blue Synthetic lines have come to market. And they have superior ratings over SS or Kevlar, so next time I'll probably switch to this material.
I hope this was helpful to anyone interested.
I edited the above post, click small blue arrowhead to read the whole thing.
James, regardless of the pros and cons of synthetic line, having two stainless steel cables part in a month is amazing, there must be something more going on. While I agree the small strands of the cable make galvanic corrosion easier (more surface area per unit of volume), I don't agree that being an alloy is the cause. Galvanic corrosion happens when two dissimilar metals touch or are connected electrically. In an alloy I believe the metals are blended, and since each strand should have the same content there should be no galvanic corrosion.
I was also concerned about stray electricity around my boat so I reported the issue to the marina management and they promptly had their electrician check out the area and found no problem.
This is where I'm a bit doubtful. The electrician may have been testing for 120V AC stray current, a dangerous condition that can happen. He may not have been testing for a very weak (1.5 volt or less) DC charge. In fact, I'm not sure if he wouldn't have to have the correct alloy probe to measure it since it is in effect a chemical battery which depends on the metals involved.
Further, it is possible that the currents are within your own boat. One month is just too fast! There must be a problem.
I agree that the whole science involved is not intuitive. Here is a link that gives a decent explanation and may help you to discover where the problem lies, before it finds something else to attack.
BoatUS: Seaworthy
It's from a marine insurance company, they are motivated to reduce claims so the info is unbiased.
skygazer is offline
post #23 of 45 Old 03-13-2012
sunfish?junior?
I may be the one that is deemed doubting and that is ok because I have little experience with salt water and cable. This is a great fourm for learning and it may save me a lot of $. Someplace along the way I may learn a thing or two. The world needs less yes men and more civil expressions ! Now I would like to know more about the grade of SS cable in use and more about Synthetics
Lou452 is offline
post #24 of 45 Old 03-20-2012
I am looking at a Seafarer 24 with the swing keel. Any idea how much of the keel is exposed when fully retracted? I am trying to determine if the trailer I am looking at would have sufficient clearance.
sailered is offline
post #25 of 45 Old 03-20-2012 Thread Starter
skygazer's Avatar
Mine is just over 6 inches from the belly of the hull. I think I allowed 10 inches, and when the boat was tipped going onto the trailer it rubbed, then was free and clear after it cleared the end of the trailer.
I was dry loading on land, not floating it on.
skygazer is offline
post #26 of 45 Old 03-21-2012
I have a Seafarer 29, which is of similar design. Although I've never measured the exposed keel below the boat when in the retracted position, my best guess is no more than 12".
Go to the link below for a S24 named Satori. There are several good photos of the boat on a trailer with the keel fully retracted.
Satori, our Seafarer 24 - Gregg's Photos
jamesnewsome is offline
post #27 of 45 Old 03-21-2012 Thread Starter
skygazer's Avatar
James, thank you for that link. "Satori" is my boat now, purchased her last fall. I didn't know about these pictures, which should be very helpful when I try to rig it for the first time. Needs some work first.
First thing I did was measure the drop of the fully raised keel so I could fit it onto my heavy equipment trailer. It was very close to exactly 6 inches, just a bit over at one point on one end.
One picture on that site shows a separate forestay and roller furling headsail. I have zero experience with a roller furler, and actually hate the idea. I like to change jibs according to the wind conditions (hank on). If however one could furl the Genoa and hank on a working jib to the forestay, that might be OK.
Do you (or anyone) have any experience with this?
skygazer is offline
post #28 of 45 Old 03-21-2012 Thread Starter
skygazer's Avatar
I enlarged the photo and see that the furled Genoa is quite large in the center, and would likely disrupt airflow with a hanked on jib.
Would this matter much if I was only doing it because there was too much wind?
skygazer is offline
post #29 of 45 Old 03-21-2012
Thanks for the info. Looks like the trailer will work.
sailered is offline
post #30 of 45 Old 03-22-2012
I have a Shaffer wire furler which does allow for easily dropping the furled sail and replacing with a hank-on while under way. The wire furlers were some of the earliest furling system, and fell out of favor but are making a comeback because of sail-changing while underway. I'll try to find some links and post.
Swing Keel or Fixed Wing Keel? Catalina 22 or 25? BRCincy Boat Review and Purchase Forum 60 08-29-2015 01:03 AM
Seafarer 29 CB sailboat swing keel stevex440s Introduce Yourself 11 05-28-2014 05:11 PM
Swing Keel or Fixed Keel for Caribbean Sailing SailorJim123 Boat Review and Purchase Forum 1 02-04-2009 11:15 AM
1972 Venture 222 - Keel Pivot Bolt CHOCKfullOnuts222 Gear & Maintenance 7 01-27-2009 10:04 AM
shoal keel vs swing keel pelicanl Boat Review and Purchase Forum 0 02-04-2007 03:52 PM
