Like Tree4Likes
Old 09-29-2011
cb32863's Avatar
Boat Owner
cb32863 is on a distinguished road
Free Standing Mast
Are they a good thing, bad thing, or don't really matter?
Umquam Porro
S/V Papillon 1977 O' Day 25
Old 09-29-2011
LandLocked66c's Avatar
Sunsets and Warm Beer....
LandLocked66c is on a distinguished road
subscribed!
1971 23' Oday Pop Top
S/V Frida
You can't steer a boat that isn't moving? Just like a life - P. Lutus
Old 09-29-2011
jackdale's Avatar
jackdale will become famous soon enough
Like most boat innovations, it depends on how well they are constructed. The Nonsuch has a pretty good reputation.
BTW - I assume that you are talking about cruising boats, not sailing dinghies.
ISPA Yachtmaster Offshore Instructor Evaluator
CYA Advanced Cruising Instructor
Old 09-29-2011
SHNOOL's Avatar
SHNOOL is on a distinguished road
So you ditch the shrouds, and have to increase diameter of the mast, to keep it standing upright in a blow... Now the foil (that'd be the sail), has a huge(r) bulb at the foreward end, screwing up the aerodynamics (more than the smaller mast).
The plus side is you don't have all that standing rigging to trip over/replace. Generally this "ease of use" coincides with a lack of a headsail (or at least a very small self tending headsail). This is because of the first part would require an even BIGGER diameter mast to hold up to the forces. Plus those halyards are like shrouds only softer (to trip over).
I dunno. For simplicity, they get my vote. For speed... I think I'd move on. But then I am a tweaker, and love a challenge (and apparently changing standing rigging every 5 years).
Old 09-29-2011
PCP PCP is offline
PCP is on a distinguished road
I can see advantages in what concerns no backstay (uncluttered transom and fuller main sail). I can also see some disadvantages regarding performance sailing in what regards control of the sail shape and probably a lesser resistance to breaking.
regarding a free mast, it has the advantage of simplicity, to put in and out but not to break such a mast has to be flexible and that means that the sails would change shape without any control of the skipper.
That would be a no no in what regards any kind of performance sailing.
To be able to stand alone, a mast would also have to be stronger than a stayed mast and that means more expensive and that matters a lot.
Regarding resistance to breaking, I don't believe that a free mast has the same resistance to breaking as a stayed mast. I mean the same mast with and without stays.
There are others that think otherwise (not many because we don't have a lot of free standing masts on cruising boats). The big defender of free mast is Eric Sponberg .
Here you can read what he thinks about the subject:
State of the Art
Old 09-29-2011
You also have to consider the structure that will support the unstayed mast. Reading about the Maltese Falcon, that was a considerable feat!
S/V Frida
Old 09-29-2011
CrazyRu's Avatar
CrazyRu is on a distinguished road
Just sail the boat with freestanding mast for a day or two. Singlehandedly.
You will never understand rest of the crowd afterwards.
P.S. Modern freestanding masts tend to be much smaller diameter than ones on Nonsuch and Freedom
CR
s/v NEMO - Freedom 28 Cat Ketch, centerboard
Old 09-29-2011
PCP PCP is offline
you can build almost anything these days....but that has a cost, a big cost. If you have almost unlimited funds that is not a problem but if you are like the rest of us, well, we want the best solution for a price...and when the vastly more expensive is probably not the most efficient solution in what regards sailing, well, that does not make much sense to me.
I can't wait to see how this one will perform comparing with the Maltese Falcon.
This one has a conventional rig and I believe it will be way faster. Of course I can be wrong
Old 09-29-2011
Man! That's an eye full!!! Is that his next?
S/V Frida
Old 09-29-2011
mitiempo's Avatar
Lack of performance? Not really. And a jibe isn't a problem - in any wind strength!
Project Amazon is the first pic.
Brian
Mast Standing Rigging Spreader Replacement. sce56 Gear & Maintenance 2 05-08-2009 11:12 PM
Wire Luff Sails (free standing furling) ranes Gear & Maintenance 2 07-04-2008 03:03 AM
Free Standing Rigs Bardo Sailboat Design and Construction 3 10-20-2007 10:30 PM
hoyt free standing boom dm567 Gear & Maintenance 3 12-28-2006 07:03 PM
Modernizing the Free-Standing Rig Bruce Caldwell Buying a Boat Articles 0 12-25-2000 07:00 PM
