-   Boat Review and Purchase Forum (http://www.sailnet.com/forums/boat-review-purchase-forum/)
-   -   advice on buying a cruising boat (http://www.sailnet.com/forums/boat-review-purchase-forum/8113-advice-buying-cruising-boat.html)
bidet 09-24-2003 03:11 PM
My wife and I are finally getting serious about looking for a cruising boat. we have been surfing yachtworld and with all the models it is easy to get confused,(cutter or sloop,full keel or bulb, center cockpit or aft). as most of our cruising will be down the intercoastal,Bahama''s and florida Keys I kmow we want a max draft of 5''. we are currently looking at a 1990 Endeavour 42 and an 1987 Island Packet 38. having not sailed either boat could we get some input on their cherecterstics. with the full keel I would assume the Packet would point a little higher and track straighter but which would be faster, but then again never sailed a cutter rig. I know both offer abundant tankage and storage. does anyone know of any flaws in either model. There are a lot of Catalina''s up here on the great lakes, what do you guy''s think of these as live aboards?
Thanks for any information you can offer.
Bill and Elizabeth
Jeff_H 09-24-2003 05:16 PM
These are such extremely different types of boast that I would respectfully suggest that you spend more time learning about boats before trying to buy a 38 to 42 foot live aboard and cruiser. A 38 to 42 foot boat is a lot to handle and the forces involved are sufficient to badly injure someone if somthing goes wrong. Boats of this type and size are too large to really learn to sail on. You would really be better off sailing a variety of smaller boats so that you can develop your own preferences.
As to your questions, your assumption is mistaken about the full keels. Full keels generally do not point as high as a fin keel and generally make more leeway. Island Packets have post hung spade rudders which probably would not track as well as the Endeavour 42''s skeg hung rudder.
The Endeavour is wildly faster of the two (PHRF 129 vs 162) which is not to say that either is particularly fast. A Catalina 400 or 42 would be noticably faster than either. The sloop rig would be easier to handle than a cutter in the venues that you are proposing. In terms of build quality, the Island Packet would edge out the Endeavour which would edge out the Catalina. The Endeavour 42 has the better layout as a live aboard but none of the three have especially good layouts for sleeping underway.
Over a certain size, having a center or aft cockpit is strictly a personal preference thing, but center cockpits really do not work very well on boats under 40 or so feet.
Respectfully,
sailingfool 09-24-2003 07:19 PM
54 Attachment(s)
My recommendation is that you check out the Bristol 41.1 or even the 38.8 as boats as they would provide better build quality and more performance then these two with the advantage of a centerboard for shallow draft. If you don''t go for a good performing sailboat, skip all the compromises and get a trawler instead.
Good luck.
(PS - I am surprised by the rating of the Endevour 42 - to look at the underbody it doesn''t look like the boat would sail to windward... I wouldn''t bet on it delivering that rating...)
mdougan 09-25-2003 09:38 AM
I would echo JeffH and say that for what you want to do, a sloop rig would probably be easiest to manage, especially with a roller furling jib.
Not sure I agree about the size issue. I did my first bareboat charters on a 40 foot Beneteau center cockpit and didn''t find it significantly harder to handle than 30 foot Erickson''s I''d sailed before. In fact it was much easier in ways because it had both roller furling jib and main sails, electric windlass, autopilot. But then, I''d spent a lot of time learning sailing basics in a Coronado 15 sloop.
Be aware that in many places along the ICW the channel depth can go below 3 feet! I have a 4 foot draft and have gotten stuck in the middle of the channel at high tide in Florida. I also have heard that in Georgia, the ICW is even more poorly maintained. So, the center-board idea has a definite appeal.
A good book for you to read is called Choosing a Cruising Sailboat (I forget the author), which discusses the "ideal" design characteristics of three different types of sailboats and explains them in detail.
Good Luck!
GordMay 09-26-2003 01:06 AM
Mdougan surprizes me with his opinion that the 40 footers he''s sailed "...were not significantly harder to handle than 30 Ft..."
A 40'' boat is more than twice a 30 footer - in most every way.
As Jeff says, 40'' is too big to learn (quickly) on.
OMO
Gord
DuaneIsing 09-26-2003 04:02 AM
Gord,
I completely agree that one should learn on small sailboats and that most 40 footers are twice the boat that a 30 footer is. As to handling diffrences, however...
After learning on dinghies and smallish keelboats boats (under 20''), my first "big boat" training was on a modern moderate displacement 38 footer. After understanding (not yet mastering) how to handle a larger boat (prop walk, windage, current, spring lines, backing and filling, etc.), I found that handling a 45 footer of considerably more weight was no different. All the skills and principles were the same.
Of course, making a mistake with a 24,000 lb boat is often more costly than on a 16,000 lb one!
In the above, I''m talking about the most challenging handling (IMHO), which is close quarter maneuvering near other boats and docking. Handling in open water under sail seems to be just a matter of higher forces on the control lines and sheets.
Just MHO.
Duane
russ325 09-28-2003 05:27 AM
I first learned to sail on a 15 foot boat MANY years ago. My first purchased boat was a 32 foot winged keel. Before I purchased this boat I spent about two weeks learning to handle a 38 foot full keel boat. After three years of practice, I bought a 40 foot Caliber. There is a world of difference in these boats. The 32 handles like a sports car - the 38 had a mind of her own - the 40 "listens" to me and while not as responsive as the 32 does what I tell her to :-)
My advice is to start in 30 foot range and then move up after you''ve "been there - done that" for a couple of years.
KenD 09-30-2003 09:33 AM
For what it''s worth the issue of center cockpit as compared to aft cockpit the former will keep you high and dry (well pretty much anyhow)and visibility is great when sailing I have owned both types and my preference is the aft cockpit I found I have a better sense of where the boat is in docking and slipping berth.Also you are already at the stern so you can handle lines aft without leaving the wheel and motor controls unattended.With a cc you are halfway between both areas and niether is easy to get to. We use walkie talkies for communication between the bow and stern it''s better than screaming commands to whoever is handling the bow lines. although it most likely looks strange seeing someone talking to themselves.Jeff is right on the money get a smaller boat to start with that way when one or the other of you decide that living aboard is not what was expected it won''t hurt the wallet so much. good luck
mdougan 09-30-2003 11:59 AM
Gord,
Duane pretty much explains it for me. After some reflection though, I really learned to sail extensively on 15'' sloops, and then spent some time crewing aboard 30'' boats on weekend trips. So, you could say that I learned to sail on smaller boats as everyone here has been recommending.
However, the point I was trying to make is that the 40''s I''ve sailed were actually easier to sail than the 30''s for a number of reasons. First, because of furling technology, I didn''t have to actually raise the sails, just furl and unfurl them. The 30''s I sailed didn''t have either sailed rigged for furling.
Secondly, the larger the boat, the longer it seems to take to manouver, so, you have a little more time work things out. (OK, if you''re trying to get out of a bad situation, this is not an advantage)
Thirdly, the 40''s were probably more heavily ballasted and heeled less, and so when coming about, I wouldn''t be thrown from one high angle of heel to the same high angle on the other tack which tends to distract a novice during a critical manouver ;)
DuaneIsing 10-01-2003 02:54 AM
mdougan worte: "...the larger the boat, the longer it seems to take to manouver, so, you have a little more time work things out..."
We have a saying in the aviation world that you always need to "stay ahead of the airplane," which means anticipating everything you will need to do so it can be done in a controlled and timely manner. I say it is no different with boats.
