Old 09-29-2003
jbarros is on a distinguished road
shallow draft sea worthy craft?
by sea worthy I mean rough weather, ocean crossing type of sea worthy, not just "good for the islands"
can it be done? how?
Thanks.
-- James
Old 09-29-2003
JohnDrake is on a distinguished road
It has been done. Look at many of Ted Hood''s designs, particulatly the Wauquiez Hood 38 (sisterships Bristol 38.8 and Little Harbor 38). She has a 4.5 ft draft with a keel/centerboard design. She sails as well as any boat on her keel alone and can use the CB to go to windward like many raceboats. You will find this design on many high end boats like Hinckley, Little Harbor (I wonder why :O), Alden, Bristol and others.
If you use the online calculators you will find impressive numbers for comfort factor and angle of vanishing stability. While these calculations are arguably a poor surrogate for the actual data, they can serve as one simplistic reference point when comparing similar boats. In the case of the Hood 38, the AVS is extremely high...at least by the formula used. These calculators aside, if you read the 30th Ed of Adlard Coles Heavy Weather Sailing, you will find in Chapter 2 (I think) a treatise by Olin Stephens on hull forms and see that the hull of the Hood 38 looks quite familiar in his data as having and has a very high AVS.
In my experience (you must have guessed by now that I have a Hood 38), her motion is so easy and comfortable, I am jaded. I am very pleased. And her stability in a blow and rough weather is quite incredible. These boats are sailed in every ocean of the world, including the Southern ocean and many have circumnavigated.
But, all this comes at a price...greater sail area to handle (something I have not minded thus far). She IS a mederately heavy boat with a high ballast to displacement ratio. She displaces 22,000 lbs and has 11,000 lbs of ballast. There is more weight to carry and thus more canvas.
Hopefully, you will get a response from someone who is truly an expert in the field, I can only lend my opinion. There are many schools of though regarding displacement. I personally am in the school that focuses on simple Newtonian physics where you want mass to counter mass (even a small wave weighs 10,000 lbs). Nonetheless, having this much displacement means carrying more sail and more sail to handle. She has fine sail handling gear, including Lewmar 48 primaries. Still, work is work. You are either up for it or not. Smaller crew might find this boat a challenge, might not. That said, I know a wonderful couple who are both 70 and race one. I was looking for exactly this type of boat and feel rewarded with my choice.
Restricting your choice to a certain draft limits your choices in a cruising boat tremendously. You should know this going in. But, for many, such as myself, this is a critical need and while almost any draft can be accomodated in the waters we might chose to sail, there are sailors who do not want the depth of the water to be THE overwhelming consideration in their cruising plans.
This is just one option, hopefully others will chime in and give you some alternatives.
My best to all,
John
s/v Invictus
Hood 38
Old 09-29-2003
Jeff_H's Avatar
Super Moderator
I think that John hit the nail on the head. Of you want a boat that offers good heavy weather performance and shoal draft you are probably looking at a keel-centerboarder with a cut away forefoot and skeg or post hung rudder, with a very high ballast to displacement ratio. The one thing that has evolved in this department since Hood developed his design approach in the 1970''s is that more modern versions of this concept have finer entries to minimize the impact with waves, have a bit more form stability to reduce roll angles, better engineering which reduces weight for better light air and heavy air performance, and have straighter runs to reduce the likelihood of broaching.
John and I agree about Newtonian physics being important, but I prefer to minimize the force of impact by reducing weight while John prefers to have additional weight to increase the momentum to carry through the larger impact loads.
Respectfully,
Gulfstars for Cruising? flicker Boat Review and Purchase Forum 4 03-21-2005 02:51 AM
SHALLOW DRAFT PROBLEMS troyaux Boat Review and Purchase Forum 4 09-12-2002 02:29 PM
Looking for a shallow draft boat for W Florida waters F troyaux Boat Review and Purchase Forum 9 08-23-2002 04:14 AM
How Much Draft? Cheetie Cruising & Liveaboard Forum 2 04-28-2002 12:21 AM
Draft help??? troyaux Boat Review and Purchase Forum 2 03-20-2002 04:41 AM
