Old 01-27-2012
TJ8187 is on a distinguished road
Buying a San Juan 21 in Alaska
My wife and I would like to begin sailing together. I grew up sailing, but it has been many, many years since I've been out on the water in a sailboat. I am looking at a 1974 San Juan 21 that was recently listed for sale. Wondering if anyone has some advice on specific things to look for or what are some red flags. I've read other posts about the problem with deck rot. We live in Alaska, so right now its consistently -5 to 10 degrees out. I've heard about using a rubber hammer or screwdriver to check for deck rot. Will that work in below freezing temperatures?
Old 01-27-2012
thesnort's Avatar
thesnort is on a distinguished road
I imagine in temperatures like that, if water had gotten into balsa core, you'd have a lumpy looking deck with the expansion of the ice crystals in the wood.
I can't tell you anything about surveying boats in freezing weather, but when temps are above freezing, it's worth having a moisture meter to check capacitance (and possible moisture ingress).
Watch videos online (youtube probably has them) on surveyors banging on boats to hear the response sounds they get. I'm sure someone must have posted something like this somewhere.
At any rate, good luck!
Old 01-27-2012
treilley's Avatar
treilley is on a distinguished road
There is usually not enough water in the wood core to cause any noticeable expansion on the deck. You should use a moisture meter and a phenolic hammer but both require at least a little skill in using them properly. Both of these will be pretty useless below freezing though. You will need to wait for a stretch of warmer weather.
A '74 SJ21 should not be going for more than about $2,500 if it is in excellent condition and also includes the trailer. The biggest issue I have read about was oil canning on the hull from the trailer bunks but this would correct itself once in the water for a little bit. I personally never had this problem with mine though.
Check the centerboard to ensure it still moves in the trunk. They have been known to get wet, expand and cause some damage. Very common to have to replace the cable and winch for the CB also.
These boats are fairly cheap to maintain. Make sure all the rigging and sails are fairly recent. I remember replacing all the standing rigging on mine in the early 90s for about $450.
See the following link for lots of good info. You may even find some references to the boat you are considering.
Jim Hubbard's San Juan 21 Sailing Page
Tim R.
Living aboard in Portland, Maine
1997 Caliber 40LRC
and
Old 01-31-2012
Thanks
Thank you both for the pointers. We'll see how it goes.
Old 01-31-2012
night0wl's Avatar
night0wl is on a distinguished road
Also - the keel trunks tend to leak. A friend of mine has a San Juan 21 and his inevitably leaks and collects a pool of water on the cabin floor. You'll need to raise the boat and get underneath to perform the repair.
S/V Jendai
Beneteau 343
Hello from Alaska captiantim68 Introduce Yourself 2 05-11-2011 05:37 PM
Greetings from Alaska Bluv Introduce Yourself 1 04-09-2011 10:54 AM
Buying a San Juan 28 ShamsB Boat Review and Purchase Forum 12 03-17-2011 04:15 PM
Hello From Alaska lavery Introduce Yourself 0 06-13-2009 05:48 PM
Ohio man sues Holland America over Alaska cruise (Alaska Public Radio Network) NewsReader News Feeds 0 09-26-2006 12:15 AM
