Blogs
User Name
Old 10-23-2003
mixmaster mixmaster is offline
mixmaster is on a distinguished road
big vs. small
What are some major pros and cons of a couple living aboard and sailing a 41'' boat as opposed to, say, a 36''?
Old 10-23-2003
928frenzy 928frenzy is offline
928frenzy is on a distinguished road
big vs. small
Pros: besides more space for living and storage on the larger boat, they usually sail a bit faster (longer waterline) and will feel more comfortable in a seaway. It can carry more water and fuel, which means it may have a greater range.
The cons for a larger boat are: more costly to dock/moor, may require more maintenance, bigger sails may require more effort to raise and lower them, a bigger engine may be louder and use more fuel, a taller mast may restrict passages under fixed bridges, a deeper draft may limit where it can go.
~ Happy sails to you ~ _/) ~
Old 10-23-2003
WHOOSH WHOOSH is offline
WHOOSH is on a distinguished road
big vs. small
Mix, I''d encourage you to think about the ''size'' issue differently. Ask yourself the difference between living aboard/cruising a 6-8 ton boat (lighter, production-type 36'' sloop, let''s say, perhaps a Catalina or similar), a 8-10 ton boat (either same length as above but intended for offshore cruising, probably rigged as a cutter...or a lighter 40 footer again of the Catalina type), and a 12+ ton cutter/ketch intended by design and construction for offshore cruising.
Speed will be a function of many things, and may be higher in a smaller, lighter, more easily driven hull (but which may be less intended for true offshore cruising) than in a longer but heavier cruising boat. One reason this could be true is some (many, IME) cruising boats don''t often have high SA/D ratios, as offshore sailing with short-handed crews makes ease of sail handling far higher a priority than max speed potential. OTOH boats intended for larger carrying loads won''t be burdened as much by the same loadout you''d be placing in your boat as boats designed/built to a lighter displacement...so e.g. the heavier, cruising capable 35 footer may in fact be faster in a given offshore seaway than it''s light production-type sistership once she''s loaded down with all your ''stuff'', even with the latter''s higher potential SA/D ratio. As you can see, it can get pretty complex when looking at the real-world variables. I think Calder''s Cruising Handbook does a nice job of giving you a sense for these choices.
A ''longer'' boat WILL cost more to run, in every respect. And this is doubly so for cruising/live aboard boats as most of us tend to make these boats more systems intensive (tho'' they don''t have to be; that''s about the crew and not the boat nor its size) and they are of course more heavily used (wear & tear, etc.). E.g. we''re currently cruising a 42'' ketch. We love the space, the ease with which we can take on guests, we like the fact its size makes a watermaker, just as one example, an option (which we don''t choose) vs. a requirement, and motion in a seaway is relatively comfortable. We cruised a 35 footer before that and found it much easier to manage in confined quarters (which usually is the case when out cruising); it was also simplier and cheaper. We''d go back to that size if the other realities of selling one boat and buying (and customizing, which takes $$ and LOTS of effort and time) another were different. The first two boats we cruised were 27'' and 24'', far simplier, far far cheaper, and we probably had the most fun on them...but were the least comfortable and, in both cases, the cruise was intended to be 6-12 mos. vs. the open-ended cruising we''ve done since then.
Last point: try to firm up what you mean by ''cruising'' - it''s a hugely overused term than can mean many different things...and results in lots of mixed advice on BB threads like this one. If you want to reserve the option for it to mean ''crossing an ocean'' type cruising, you''ll have to be much more thoughtful and selective in your shopping than if you mean ''visit the Caribbean'', which damn near anything can do and does (eventually, perhaps ,with some glorious sea stories you can bring back with you).
Jack
WHOOSH, currently lying London, England
Sponsored Ad
Old 10-23-2003
Jeff_H's Avatar
Jeff_H Jeff_H is offline
Super Moderator
Jeff_H will become famous soon enoughJeff_H will become famous soon enough
big vs. small
I think there have been some very good points raised. I would like to weigh in here with a slightly contrary answer, if you look at the title of this thread, big vs small I guess I have to ask how that is measured. I normally think that displacement more than length really governs seaworthiness, carrying capacity, cost of maintenance, ease of handling, rigging loads etc. If you talk about two boats of equal displacement (Probably in the range of 15,000 to 20,000 lbs displacement), one a 36 footer and one a 41 footer (both with proportionate waterline lengths), the longer boat will have equal or greater carrying capacity, all other things being equal have greater speed, motion comfort and stability, a similar cost of maintenance,and generally be easier to handle shorthanded especially in light air or in heavier conditions.
Living aboard, the longer boat of equal displacement will generally have more useable space and more room for storage low in the boat.
Old 10-24-2003
flicker flicker is offline
flicker is on a distinguished road
big vs. small
Jeff,
I know some things are not linear when making a boat larger, volume for example.
But if one boat is more or less proportionately larger than another boat, how will the bigger boat have greater motion comfort and stability? (I think you said once before that greater displacement didn''t affect motion comfort nearly as much as a motion buffering design would.)
Chas
Old 10-24-2003
Jeff_H's Avatar
Super Moderator
big vs. small
I think in this discussion we are talking about two boats of equal displacement but different lengths. Almost by definition the longer boat will have a proportionately narrower hull and will spread its displacement over a longer length. Similarly the center of buoyancy would tend to be higher. It also means that potentially, the vertical center of gravity would be lower. This means that the proportionately longer narrower boat would be less prone to pitching and rolling and would develop a higher ballast stability than the wider shorter boat. Additionally the more easily driven hull of the longer boat requires less sail area to make good progress in heavier going and can disburse more of the energy of gusts through acceleration rather than heeling and so would have more apparent stability.
Old 10-24-2003
big vs. small
Ah, I see. Thanks.
Chas
vB code is On
small boat in So Cal. jbarros Living Aboard 1 08-30-2004 12:34 AM
the perfect 20'' cruising boat? jbarros Boat Review and Purchase Forum 14 04-18-2004 07:45 PM
Small boat adventures on the West Coast jbarros Cruising & Liveaboard Forum 0 11-07-2003 11:56 AM
small racer/cruiser magpie Boat Review and Purchase Forum 0 09-06-2003 06:04 PM
Small Diesel Seminar - Old Lyme, CT elarson Gear & Maintenance 0 02-14-2003 01:41 AM
Page generated in 0.5058 seconds (66.76% PHP - 33.24% MySQL) with 15 queries
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.0.0 RC8
(c) Sailnet 2000-2006
