Old 11-04-2003
tommyt is on a distinguished road
New Dufour 34
I spent some time on the new 40 at Sail Chicago and have become enamored with the new Dufour 34. I have not sailed one or even been on one as yet.
Anyone out there that has had the opportunity to look closely at this new model that would like to share your thoughts?
As there are usually many opinions out there I would also like input on Dufour and the quality and design of these new models.
Thanks,
Old 11-05-2003
GordMay is on a distinguished road
New Dufour 34
See their site:
http://www.dufouryachtscanada.com/dufour_factory_tour.html
Notable deficiencies:
Hull-Deck joint is screwed - not bolted
Hull is Cored & Vacuum Bagged
Hull Liners are Bonded In
Gord
Old 11-05-2003
pehrst is on a distinguished road
New Dufour 34
Check out the October issue of Yachting World, they had a review of the Dufour 34.
Goog Luck
Old 11-05-2003
paulk's Avatar
paulk is on a distinguished road
New Dufour 34
Would tend to thnk vacuum bagging is an asset, rather than a deficiency, and would certainly want the pans & support grids moulded to the hull - what good would they be if they weren''t? Hinckley builds their boats that way too. Using screws instead of bolts would be an absolute no-go for me. I''d want to check, however, whether they''re sheet metal screws simply holding the fiberglass pieces of the hull and deck together temporarily (because if tthat''s what they are, then it will only be temporarily) ,or whether they are machine screws that are threaded through a plate that has been moulded into the hull along the rail. The latter procedure is followed by some builders, since it enables them to provide the security of bolts (with even better spreading of loads, due to the continuous plate in the hull) at a lower cost. (You only need one guy to install them, instead of having a second guy inside the boat holding the nut.) It can look like they''re simply screws, however, so it would be worthwhile to check. I suspect they might be screws in this case. Dufour''s interior cabinetry has not impressed me with its strenght or solidity, though they may have improved since I last looked. too.
Old 11-05-2003
Sailor-man is on a distinguished road
New Dufour 34
Check out the review on the new D34 in the October edition of Pacific Yachts
It''s available online here:
http://sailingsource.com/dufour/readingroom/pacif_ycht_d34.php
Old 11-06-2003
kmeeks's Avatar
kmeeks is on a distinguished road
Send a message via Yahoo to kmeeks Send a message via Skype™ to kmeeks
New Dufour 34
I was recently aboard a 34 while at the Long Beach Boat Show.
I liked it better than the comparable Hunter, Catalina, and Beneteaus that were being displayed.
It seemed to be of better quality construction - and had a good layout.
Old 11-07-2003
New Dufour 34
Paulk is correct, of course - I meant to say "observations", not deficiencies.
They have a detail dwg, showing a "Screwed" hull-deck joint.
The Deck is bedded /w Sikaflex then Screwed to hull flange. Then Toe-rail is then screwed thru'' both, covering first screw. Like Paulk I view this as a major deficiency, and a tell-tale of overall design/build quality. Quality is always an issue, but MUCH more so with a "Cored" hull. Failing persuasive evidence otherwise,I''d pass.
Regards,
Gord
Old 11-07-2003
turbo87 is on a distinguished road
New Dufour 34
Check out the Dehler 34. Narrower beam and more expensive but better built and more of a "sailors" boat. You get more "stuff" with the Dufour.
Priority Sail in the Chicago area sells Dehlers. Here is the web site and let me know how you made out. As you guessed, I am a Dehler 34 owner.
http://www.prioritysail.com/sailboats/new/dehler/34/index.html
Old 11-07-2003
magnusmurphy is on a distinguished road
New Dufour 34
This hull-deck issue is really confusing. I noticed that (if I understand it correctly) the Aerodyne yachts (considered quality yachts) don''t have any screws or bolts through the joint - its "bonded" only with modern material.
The Dufour has Sikaflex for this, with an integrated glassed in wood liner and then two layers of screws as mentioned above.
Are bolts really always better? How many boats have bolts that have worked themself loose, thereby not actually giving any structural support? Screws could be better as far as that is concerned.
It is likely that this whole issue is blown out of proportion. Isn''t it more likely that something else will fail completely in bad wheather (like the crew), before the hull-deck joint fails on almost all boats, no matter how it was put together?
MM
Old 11-08-2003
New Dufour 34
Dufour''s construction methods are on a par with other high-end production builders. Both the Classic series and the new 34, 40 and 44 meet Bureau Veritas Standard One and CE Category A, both standards for unrestricted off-shore cruisers ... The hull comes with a 10 year guarantee vs. 5 years for Hunter, Beneteau and Catalina.
1982 Dufour 40'' Ketch keithblankley Boat Review and Purchase Forum 5 11-05-2009 10:34 AM
Dufour sailboats in the 50'' plus - info wanted. Myblueheaven Boat Review and Purchase Forum 0 09-07-2003 09:54 AM
Dufour vs Dehler turbo87 Boat Review and Purchase Forum 3 09-12-2002 12:43 PM
Dufour turbo87 Boat Review and Purchase Forum 0 09-07-2002 07:03 PM
Dufour tat Boat Review and Purchase Forum 0 03-14-2002 03:33 AM
