Like Tree1Likes
Old 03-22-2012
champlain94's Avatar
champlain94 is on a distinguished road
Pearson 30? Good buys! Any others
Hello,
I'm looking for a sailboat. There are a lot of Pearson 30's out there for less then $7000. I even found
One with a Yanmar instead of atomic four. I also like Bristol, tartan, ericson, and Tayana. I know Tayana are more expensive but I still can dream.
I live in S.C. I want to sail down to the Caribean and
Possibly south America. Sail a year around the Americas, upgrade and prepare and then if I feel comfortable and safe maybe cross over to wherever.
What I am asking is how do you feel about these boats. I know there not full keel. I thought I wanted an alburg 30 at one time. But....I think I would enjoy a smaller keeled boat more(faster, Manuverability) Pearson 30's have a head but no shower. Do most people shower in there boat or on deck? Do you think any of the other ones I mentioned would be a better boat. Less the TayanaI will never afford that boat. I looked at some ericson 32's Pearson 30's and Bristol 30's. Maybe I will get lucky and be able to get one of them in a larger model. I don't want to spend more then $8000 possible $10. Are there any other models I should be looking at. That are all around good sailboats that parts are readily available
Allied, bayfield, C&C?
THIS OLD BOAT
Old 03-22-2012
kwaltersmi's Avatar
Broad Reachin'
kwaltersmi is on a distinguished road
Re: Pearson 30? Good buys! Any others
With your budget, condition is going to be far more important than the make/model. Are you handy? You should also plan on doing some upgrades and repairs at that price point. I'm not trying to discourage you at all, because you CAN find a boat to suit your needs within your budget. But you'll need to do your homework.
Check out this video for a group of friends that did what you're talking about with an Irwin 28 and a small budget:
Last edited by kwaltersmi; 03-22-2012 at 04:24 PM. Reason: Changed boat make in video from P30 to Irwin 28
Old 03-22-2012
Yes I am handy. I have been a carpenter all my life. Well off and on. Crown, cabinetry, baseboard, hardwood flooring etc...and a good electrician. But I have never in my life touched fiberglass. The only thing I know about fiberglass is what I've read in Don Caseys this old boat. I will attempt anything if I have a good book in front of me. I am sure there is going to be work to do. Chainplates, soft deck, mast base rot etc.. Hopefully none of them but when you buy an older boat at a deal you get what you pay for. I will be single handing most of the time. But family will stop by from time to time. Never more then myself, two adults and a child. And no longer then seven days with that many. But if I can talk the wife into staying in the boat for long periods I will.
THIS OLD BOAT
Old 03-22-2012
BubbleheadMd's Avatar
Chastened
BubbleheadMd will become famous soon enough
Send a message via Yahoo to BubbleheadMd
As you've found, there are many good deals out there, and they aren't all project boats. The "toy" market is in the toilet, and good boats are going cheap.
I bought a Pearson 30 last August that is definitely not a project boat, for $4100. The Atomic-4 engine ran perfectly after 2 years on the hard. All I've done is give it the regular, basic love that such engines require.
Tartan 30, Pearson 30, and Catalina 30 tall rig with fin keel are all wonderful boats. The Catalina 30 is nearly a foot wider than the Pearson 30 though, so make sure your slip can accomodate the beam.
Check the decks for soggy core, check the chainplates and their attachment points, look for water stains on the interior indicating leaks in those areas. Check through-hulls for leaks, seacocks for leaks and proper operation. Check the engine and transmission for proper operation.
Do all of this to help determine your offering price.
Good luck!
S/V Old Shoes
1973 Pearson 30 #255
Old 03-22-2012
zeta is on a distinguished road
Agree, condition is all important. If boat needs new sails, bottom paint, rigging, engine work, thru hulls, etc. Your 10k will quickly double or maybe triple. I would not cross off any 27-30ft boat and buy the one that is most fit, regardless of age, size, or pedigree. Just my 2 pesos.
Old 03-22-2012
JimsCAL's Avatar
JimsCAL is on a distinguished road
I agree with Bubblehead that Pearson 30, Tartan 30 and Catalina 30 tall rig are all worth considering. I would add the Cal 2-30 and 3-20. The Pearson,Tartan and Cal are better sailors and the Cat has the most interior space. All are coastal cruisers however and not the best choice for extensive cruising of the Caribbean and South America.
Old 03-22-2012
Would the interior of an Ericson 32 be roomier then a Pearson 30? Which boat is more heavy water capable all other things being the same. From what I've read and seen tartan 30 will out sail the 32 but a Pearson 30 it will not. But the interior isn't as nice(wood) in the Pearson. What's the Bristol 30 like compared to the E32 and the P30
THIS OLD BOAT
Old 03-22-2012
RichH's Avatar
RichH will become famous soon enough
The P30 is an excellent 'sailing' boat, much better sailing characteristics than a Cat30 or T30. However for long distance cruising and island hopping you may find the P30 hull a bit too 'floppy'. A P30 hull can be stiffened by the addition of internal 'stringers' that parallel the boats center line.
Finding a 'good' P30 is getting harder and harder ... as these boats decks were balsa cored ... and Pearson boats are notorious for deck leaks. Also notorious are the rotted 'compression post' bilge mounted bases - easy 'fix' if youre handy' but a real PITA to fix if the main bulkhead has 'shifted' (and you cant get the head door closed anymore).
Easy to add a 'shower' to a P30 ... the head already has a FG pan for the head sole ... just have to get the shower water overboard quickly and not let it get to the bilge; or, horrendous putrid bilge STINK.
Old 03-22-2012
Jeff_H's Avatar
Super Moderator
BTW, Whatever else that it boat in the video is, it is not a Pearson 30 which had more of a triangular transom.
Curmudgeon at Large- sailing my Farr 11.6 on the Chesapeake Bay
Old 03-22-2012
kwaltersmi's Avatar
Broad Reachin'
I think the video calls it a Pearson 30. I agree though, it doesn't look like any P30 I'm use to. Actually looks a lot like the mark I Irwin 28's. Have a look at the profile:
Raymarine buys Tacktick Tanley Gear & Maintenance 15 07-29-2011 10:12 AM
5hortBu5 Buys a Boat 5hortBu5 General Discussion (sailing related) 4 09-07-2010 10:08 AM
PSC 34 vs Pearson 34 - a good problem to have fefrich Pacific Seacraft 1 02-15-2010 10:15 AM
Suunto buys Tacktick Ltd JomsViking Electronics 1 04-26-2009 03:12 PM
Newbie buys a boat! gar37bic Columbia & Coronado 1 09-23-2007 09:15 PM
