Looking at buying a Discovery 47' - Page 4 - SailNet Community
 17Likes
post #31 of 44 Old 03-29-2012
Re: Looking at buying a Discovery 47'
jg - take a look at bumfuzzle.com:
http://www.bumfuzzle.com/Pages/2010/....php#Spindrift
They are living aboard a 43'er - and you'll get a very good idea of the kind of maintenance that's involved. It seems to working out great for them, but they are in Mexico and are able to handle the ongoing expenses.
Either way, they're great people - and their blog gives a lot of great info...including costs for everything.
smackdaddy is offline
post #32 of 44 Old 03-29-2012
Senior Moment Member
SloopJonB's Avatar
Originally Posted by mitiempo View Post
Speaking of gas docks, where is the closest one if you are anchoring in English Bay? As far as I know the one near Burrard Civic Marina has been closed for years. Coal Harbour?
Coal Harbour, Fisherman's Cove and Sewell's in Horseshoe Bay are probably the closest. They along with Mosquito Creek and Deep Cove are it AFAIK.
I'm sure there are some water hoses in False Creek but you'd have to raft up to access them unless there's one at the Market docks.
SloopJonB is offline
post #33 of 44 Old 03-29-2012
The False Creek fuel barge reopened last year at the same location so that's not a big issue anymore. Not Esso, but an independant.
The market docks are not quite as 'visitor friendly' as they once were, but they are all new and more extensive...
Faster is online now
post #34 of 44 Old 03-29-2012
mitiempo's Avatar
The False Creek fuel barge reopened last year at the same location so that's not a big issue anymore. Not Esso, but an independent.
That's good - I didn't know that.
Brian
mitiempo is offline
post #35 of 44 Old 03-29-2012 Thread Starter
bumfuzzle | june 2010
Thank you very much! I was following disengage.ca which was what gave me the idea for anchoring being possible since he lived out at Kit's beach after getting kicked out of False creek, but he didn't list a lot of costs.
Disengage.ca talks about the water taps under the bridge, I'm trying to find contact info for him, and the couple who live aboard sv Asunto, according to their site they started out anchoring for a few years first around here before buying a boat in the Co-op. Would fuel docks be tolerant of tanking up on water if you're buying diesel at the same time?
JG, just a quick reality check - Working at a city job while living at anchor, particularly in a climate like ours, is very different from cruising - so different in fact that it might put you off cruising entirely. Rowing back & forth in the rain & cold would get old in a hurry. It's very difficult to maintain "city" or "office" clothes and grooming under those circumstances. Picture rowing ashore in a November rain with a couple of garbage bags of laundry, which you have to bicycle to the laundromat (if your bike hasn't been stolen). Every few days you'll have to up anchor just to go fill your water tanks. AFAIK there isn't anywhere near any anchorages where water is available to just anybody who stops by. The gas docks will quickly tire of seeing you if you aren't buying fuel from them regularly.
Living aboard here, even in a deluxe marina, requires adjustments and compromises that few are prepared to make once the reality hits home. Living at anchor multiplies them exponentially. This ain't the tropics.
That's a really good point, I had been thinking of a motor, but it would probably disappear fast! Do most people who live at anchor here row instead of using a motor to avoid theft? What sort of a dinghy is safe for back and forth and beaching in all weather with decent cargo capacity?
I'd likely continue using the same bag setup on my bike if I can afford the insurance on top of the boat costs.
If not I'll be moving the battery on my E-bicycle(48V 10AH lithium and a 1000w rear engine) into the frame triangle and I can swap the saddlebags over from my bike, they are just modified bicycle bags.
I'd need a way to transport in the dinghy without losing it overboard like happened to the owner of disengage.ca's bike, any thoughts on how to do that?
I need to maintain a reasonable level of cleanliness, but other than a beard trim every couple weeks(battery power razor I charge once a month) that is pretty much limited to a shower before I start work, I can do like the people who work out before shift. In terms of clothes, I just need hole free pants and clean shirts. I wear a mix of quick dry nylon(travel) pants and jeans, lightweight cotton shirts under a fleece to cut down on laundromat expenses.
Every point helps me to learn about those differences, you've given me several more things to try and figure out, thanks!
Hmm, there's teacher who lives on a houseboat, and a couple more who commute across to Granville island by water I think, I'll ask them about how they park. If I could take care of most things in one place that would make life a lot simpler.
Do you know anybody currently living aboard in Van long term outside of False Creek or a Marina, I'd really appreciate a chance to talk it over with someone who's done it, see what I might be in for.
Jgbrown is offline
post #36 of 44 Old 04-03-2012
Wow is Vancouver really that bad? I thought the SF Bay area was bad but that sounds much worse.
benajah is offline
post #37 of 44 Old 04-03-2012
mitiempo's Avatar
Yes, it is that bad.
Victoria is the place to be.
Brian
mitiempo is offline
post #38 of 44 Old 04-03-2012
There's a Catalina 36 called "Pegasus" that seems to cycle in and out of False Creek (probably wearing out their permit, moving out and re applying, etc etc) When they are not in the creek the boat is anchored just past the Maritime Museum in English Bay, edge of the fairway. You might see if you can catch them sometime (do you have any kind of boat now?)
There is also a floathome community just east of the Ocean Cement plant and it might be worth chatting up some members there for some inside info.
You may find that most of those living aboard on the hook in the area will tend to be rather reclusive - but you may get lucky. The liveaboard communities in marinas are usually a pretty friendly bunch and should be happy to discuss the realities of the lifestyle.
Other floathomes areas are in North Vancouver's marinas as well as in Ladner's Canoe Cove area on the river. Shelter Island marina on the New West/Richmond border further up the river also allows liveaboards, I believe.
post #39 of 44 Old 04-03-2012
SloopJonB's Avatar
It's almost impossible here - you have to buy a boat with a transferable berth, just like in the early 70's. S.F conditions are merely a dream here - that big floathome area in Sausalito, living aboard at scruffy docks in San Rafael, picking up a berth for a big boat anytime in Alameda - I wish. The fact that you have lots of regular wind is also merely a dream here.
I don't envy your dry storage rates though - $1/foot a DAY 9 years ago in San Rafael. I paid $350 a MONTH for my 43', 5 minutes from home back then. Even now, I only pay 40% of those 2003 S.F. rates.
Having to motor all the way to Napa to be able to afford to work on your boat for a stretch would be a pain.
post #40 of 44 Old 04-04-2012 Thread Starter
Too funny, the owner of the Pegasus is sitting next to me at work most days. We've worked together for months and I just mentioned that I was looking at boats in passing a day before reading your post.
I've been bookmarking people I want to bug for advice on here when I remember. Real life would be good too though. I'll be over in Victoria Friday the 13th to take a look at a couple boats like that CS36T in anyone wouldn't mind a visitor for a bit.
Can sailboats dock in the N Van marinas? That might not be too bad of an option.
Jgbrown is offline
Secrets of WTC Shipwreck Revealed - Discovery News NewsReader News Feeds 0 09-07-2011 12:50 PM
Off-season trip desolation/discovery islands area ArgleBargle Pacific Northwest & Alaska 2 09-03-2011 01:01 PM
Cooper 416 vs Discovery 42 augustur Boat Review and Purchase Forum 7 04-21-2011 03:04 AM
Most scenic Desolation Sound/Discovery Island anchroages ArgleBargle Pacific Northwest & Alaska 23 08-21-2010 05:13 PM
Voyage of discovery (Sunday Life) NewsReader News Feeds 0 01-28-2007 07:16 AM
