beachable/groundable trailer sailer - Page 2 - SailNet Community
 2Likes
post #11 of 22 Old 04-16-2012
Re: beachable/groundable trailer sailer
My Aquarius is very beachable, sole keel with 900lbs of lead, self righting even with centerboard up.
Balboa also makes some very beachable boats.
The Sun has Risen on a New Day filled with the Promise of Adventure.
CapnBilll is offline
post #12 of 22 Old 04-16-2012 Thread Starter
Thanks everyone. I had looked for tein/bilge keels, but they really seem to very hard to come by in the US. I had looked at some of the retractable keel boats (i.e Catalina 22) but the swing keel really does seem to bear the weight of the boat. Maybe that is OK, but I have to think the pin is not designed to hold the full weight 50% of the time.
I will look into many of the other boats listed and see what I can come up with.
Thanks again!
MWelcome is offline
post #13 of 22 Old 04-16-2012
Send a message via Yahoo to dacap06
If you aren't too hung up on hull length and are really after the features, take a look at the West Wight Potter 19. It has the features you seek. There are imminently affordable used and new models available although they are typically more expensive than the 7K ceiling you are mentioned.
T. P. Donnelly
S/V Tranquility Base
1984 Islander 30 Bahama
Pasadena, MD
dacap06 is offline
post #14 of 22 Old 04-17-2012
Once known as Hartley18
Classic30's Avatar
Dock
If you're considering a West Wight Potter, have a look for a Hartley TS21 first.
Tough as nails (one I know of landed upside-down on the highway at 100kph after it's brand new owner discovered how not to recover from sway on his way home and yet survived to sail again with only a damaged hatch) and will sleep more than two - and two comfortably at that.
Classic30 is offline
post #15 of 22 Old 04-20-2012
mikehoyt's Avatar
s2 7.9
Mike
mikehoyt is offline
post #16 of 22 Old 04-20-2012 Thread Starter
Thanks Mike. The S2 looks very interesting with the weighted board that appears to be fully retractable. That has been my main concern as many of the swing keels don't appear to fully retract in the hull and would not take the beating of being grounded twice a day.
I like the reviews I've read on it's performance. Budget may be an issue with the S2, but I'll work on that if everything else works for me.
Thanks again for the recommendation.
Mark
MWelcome is offline
post #17 of 22 Old 04-20-2012
I do not have experience with a beachable boat big enough to spend a few nights on, but I have had lots of smaller boats on the beach. A big problem is getting mud and sand up into the Board trunk. I have had boards jam even after a short period of time, once I even got enough glop in my kick up rudder on the beach that I could not get it back down without taking it apart. I think any boat left aground for long periods of time will not work out unless it is made for that type of use. When you add the pounding that will take place 4 x a day as the tide goes in and out the end result will be a pretty beat boat, particularly since they will be sitting on their hulls.
Bilge keelers are made for this, another otion would be a sturdy old boat with lee boards instead of a centerboard. Some extra rub strips and lots of extra applications of bottom paint would help.
baboon is offline
post #18 of 22 Old 05-10-2012
Otter
DivingOtter's Avatar
I have a Santana 2023 and its perfect for a few nights out, water ballast and swing keel, draws 12 inches and i beach it constantly.
DivingOtter is offline
post #19 of 22 Old 05-10-2012
S/V Wyndwitch - Morgan 24
oysterman23's Avatar
Gee Mark sounds like a job for a Cape Cod catboat.... but something like a Marshall probably run outside yourbudget unless a forced sale or project boat.... The version with bowsprit/ jib rig would be ideal and very solid
Chris
oysterman23 is offline
post #20 of 22 Old 05-11-2012
If you have some wood working skills, build one just like you want. Check out
Duckworks Indexes - Trailer Sailer Cruisers
zumwaltd is offline
14'' cal trailer sailer mick b General Discussion (sailing related) 2 11-13-2011 06:15 PM
Looking for a trailer sailer kruucks Boat Review and Purchase Forum 10 09-30-2008 08:39 AM
A new trailer sailer Giulietta General Discussion (sailing related) 33 05-27-2008 03:46 PM
looking for a trailer sailer hillbillybear Boat Review and Purchase Forum 28 03-27-2008 11:57 AM
