01-04-2004
Crackling deck on an ericson-27
Crackling sounds come from delaminating fiberglass. As the strands move & break, they make noise. The same thing happens in skis. Eventually, it will weaken to the point that the deck does crack - even if it isn''t cracked yet . Water will get in, and you''ll have your trampoline. If it''s dry now, you may be able to fix it by injecting epoxy into the laminates; gluing them back together and sealing them against moisture penetration. If you can get at the spots from the underside of the deck, you won''t have to drill holes in the deck surface itself. This avoids the problem of resealing holes made in the deck and matching the deck nonskid patterns. We fixed extensive delamination and rot problems in our cabin top from the inside, and have been pleased with the results.
