Please help me compare these cruising boats. - SailNet Community
 2Likes
post #1 of 12 Old 06-10-2012 Thread Starter
Hello,
I'm beginning to look into purchasing a sailboat for cruising. I am in the SF Bay Area, so that is where most of the cruising will be done for now. I am in no rush to buy before I've done my homework, nor am I in a rush to get out into the blue water before I've done my homework, but that is an eventual goal. The most likely uses for this boat will be weekending and potential liveaboard for some time. I'm not really interested in racing, but nevertheless assuming a list of cruisers deemed seakindly, I'd give up a few creature comforts or features for a bit more responsiveness and performance. I'm looking at mainly older models, between 30 and 38 feet, since that's what I can swing right now. I will get a professional survey before purchasing, etc. Please assume that the condition of the boats below are all sufficient when making your assessments.
All of that said, here's my working list, based on a list some of you may have seen, and I'd appreciate input from anyone with experience with these boats. Mainly I'm looking for strong opinions. Any that you love? Any that you'd never sail/own again? Thanks.
Allied, Princess 36,
Bristol, 35.5 (centerboard or not)
C&C, Landfall 35
Cape Dory, 33
CSY, 37
Endeavour, 37 (I've heard some gripes about this one on the forums)
Morgan, 382,383,384
Pacific Seacraft, 31 (A bit pricey for similar specs as the others)
S2, 11.0
Valiant, 32
sailnoob is offline
post #2 of 12 Old 06-11-2012
jsaronson's Avatar
The Cape Dory will be on the slow end of the spectrum. I have a C&C that is not a Landfall. The Landfall should sail well, as will the Bristol.
Good luck!
Atlantis
Hylas 44
Annapolis
jsaronson is offline
post #3 of 12 Old 06-11-2012
TQA
Bombay Explorer 44
TQA's Avatar
Re: Please help me compare these cruising boats.
A CSY 37 owners model was on my list of possibles. Very tough, 150 galls water, roomy and a cutter.
TQA is offline
post #4 of 12 Old 06-11-2012
wayina's Avatar
Send a message via Yahoo to wayina
As would an Islander 36, designed for the area I believe, I have one and think they are fantastic, comfortable and fairly quick, they have an association in the SF area, and regattas as well
regards Wayne
"No, it's not going to be fine. Change is never fine. They say it is, but it's not. "
wayina is offline
post #5 of 12 Old 06-11-2012
I would add Cal to the list. There should be some good Cal 40's or 39's out there.
kbyte is offline
post #6 of 12 Old 06-13-2012
chef2sail's Avatar
I prefer the C&C35 MKIII obviously over the Landfall. Greater headroom and the 35 MKIII is a much better and faster sailing boat.
Check the CS and also the Cals
Dave
___________________________
C&C 35 MKIII Hull # 76
Parkville, Maryland
(photos by Joe McCary)
Our blog-
chef2sail is offline
post #7 of 12 Old 06-13-2012
The Bristol 35.5 sails very nicely and construction is bombproof. Your main problem is likely to be finding one for sail on the west coast.
There is a 31.1 for sale in Redwood City on Yachtworld. I know nothing about it's condition (except that it doesn't look that great in the pics) It might also be a bit small looking at what else is on your list.
This site is quite useful for comparing numbers :
Sail Calculator Pro v3.53 - 2500+ boats
The 35.5 (the 31.1 too) has a combination of motion comfort and decent speed that is hard to match and makes for a nice SF Bay boat.
Generally my suggestion would be to make a shortlist of models, then search for the best example.
MarkSF is offline
post #8 of 12 Old 06-13-2012
Though I kind of like the look of the C&C Landfall 35/38, I think that you'll have better availability and space with a 35 mkIII as chef suggests. Also quite a bit less woodwork for upkeep. The 38s layout is a bit unconventional, something that has to 'work' for you.
Also second the suggestion to add the CS 36T to the list.. great rep, robust boat and good following, many have done serious miles offshore and can hold their own on the coastal scene and then some. Not a fan, however, of the near vertical companionway steps...
I also like the Brewer Morgans, most of the rest are going to be heading for the heavy, fuller keel slower category.. but maybe fine in the bay where light winds won't be your biggest concern.
Faster is offline
post #9 of 12 Old 06-13-2012
Budget? There's going to be some pretty large price variations in the boats you mentioned.
Faster and chef2sail like this.
puddinlegs is offline
post #10 of 12 Old 06-15-2012 Thread Starter
Good question puddinlegs, I'm thinking in the neighborhood of 20-40k, which is why I was going for well-made boats from the late 70's or early 80's, and then plan to have a thorough survey performed. The pacific seacrafts are going to be outside that range, I know, even for a late 70's model.
Thanks everyone for the replies so far!
sailnoob is offline
Tags
blue water , cruising , opinion , used boat purchase
Cruising Boats KPBaker Boat Review and Purchase Forum 12 12-01-2012 06:35 PM
Boats that compare to a j/30 GreatWhite Boat Review and Purchase Forum 11 03-26-2009 10:23 AM
Three Types of Cruising Boats Jim H Boat Review and Purchase Forum 8 10-08-2007 05:57 AM
Cruising Boats Fleetwood56 Boat Review and Purchase Forum 2 06-18-2007 09:54 PM
Recommended cruising boats gregreinhard Boat Review and Purchase Forum 15 10-23-2003 01:02 PM
