01-16-2004
Survey a Ranger 23?
If the boat is hauled out while you''re present, you may be able to see the keel ''settle'' when picked up and put down on a cradle or jack stands. If in the water, a wet bilge may or not be indicative, since it may come from other sources. There may be a noticable crack around the seam.
A cautionary note, the presence of a keel seam crack does not, of itself, indicate that the boat is leaking at that location. It MAY be. It depends upon the degree of ''wobble'', and the extent of flexing under sail. If shes in the water, I would dry the shallow bilge, and go sailing. Check the bilge often - see if she starts to show water.
Also, take a look at the nuts atop the keel bolts.They may be a bear to deal with if you need to remove the keel.
Unless, your able to do this work yourself, I would pass on the boat.
