Sloop vs. Fractional Sloop vs. Cutter - Page 3 - SailNet Community
Blogs
  #21 (permalink)
Old 02-05-2004
genethompson is on a distinguished road
Oh, I forgot another problem with a long boom is the possibility of dipping it in the water when running. This can cause significant damage to boom and rig.
I know someone that converted to a furling boom that was about 3 feet longer than their existing one. They also raised it about a 1.5 feet. Looked odd to me but I think they were concerned about the dipping problem.
Gene
  #22 (permalink)
Old 02-05-2004
hr53 is on a distinguished road
Hi,
Hi,
You state that you are looking for sailing vessel, 35 feet, primarily for single-handling in offshore waters.
We live in a world were everybody out there has their own opinion. My dear friend JeffH being one of them. Jeff has always pressed the advantages of a fractional rigs. Fractional rigs work on the big Farr designed Volvo Challenge boats, that have a crew of eleven. Fractional rigs are also wonderful on the race course going around the buoys. This is the type of sailing that he does.
Now to my point. Seventy five percent of the cruising vessels out there are being single-handed, I mean actual world voyaging boats out there doing it, are CUTTERS. For a good reason. They work. Offshore, one will work under jib, staysail and main. This is a proven combination that works. In building winds and seas; one will reef the main; then after that partially furl the jib,; then as the wind builds, one throws in another second reef and furls the jib; then the sailor will have just the staysail up and double reef in the main; if the winds builds further, drop the main and staysail will carry the vessel to 50 knots; his vessel will be balanced, the center of effort is low and center; the autopilot works effortlessly, the crew is relaxed.
Take a survey of the boats doing the cruising, and see for yourself that it’s much different than the opinions of the sailors that sail the race courses.
I have always sailed successfully a cutter; if it was a Perry designed Norsemann 447, or a Pacific Secraft Crealock 34, or a Valiant 40, or a BCC28, or now a HR53. I’ve owned sailed 200K on these cutters. The design works.
Bernie
Solstice, HR53
RogueWave Yacht Sales
  #23 (permalink)
Old 02-05-2004
Hi,
Now to my point. Seventy five percent of the cruising vessels out there are being single-handed, I mean actual world voyaging boats out there doing it, are CUTTERS. For a good reason. They work. Offshore, one will work under jib, staysail and main. This is a proven combination that works. In building winds and seas; one will reef the main; then after that partially furl the jib,; then as the wind builds, one throws in another second reef and furls the jib; then the sailor will have just the staysail up and double reef in the main; his vessel will be balanced, the center of effort is low and center; the autopilot works effortlessly, the crew is relaxed.
Bernie
Solstice, HR53
  #24 (permalink)
Old 02-05-2004
DelmarRey's Avatar
DelmarRey is on a distinguished road
Gene, Thanks for the reply.
This is one reason for my Questions. My main is streached out and I planing for a replacement within a couple years. I''m not sure I would have the dipping problem. At present my boom is 14'' (luff= 46'')and I still have another 2'' to the back stay. I''ve been heeled over 35 degrees (normal is 15- 20 degrees) and my boom was a long way from the water in white caps and on the wind. Maybe if I were before the wind broaching deep swells, but that seems unusuall? My gooseneck is 8'' off the water and the vessel has a 12'' beam. A longer boom would serve two purposes, one of them would get the traveler out of my cockpit, the other, I would hope for better light air performance.
Del
  #25 (permalink)
Old 02-05-2004
Del, a longer boom would help you downwind but will hurt you upwind in anything over light winds. You will have to reef earlier due to the weather helm, and in so doing you loose sail area up high, which helps the boat point higher. Also, 2 feet of clearance to the backstay does not sound like alot to me. Be sure to measure with the boom raised until it is perpendicular to the backstay, one would hate an acidental jibe cause the boom to hit the back stay.
Gene
  #26 (permalink)
Old 02-05-2004
DelmarRey's Avatar
Gene, Good point on the back stay! I guess I should just get a QUALITY new mainsail when the time comes. I keep trying to improve this old IOR racer, but it seems I should just leave well enough alone when it comes to the rigging. I will be adding a genoa furling though. Thanks ...........Del
New to Sailing, please Help =) xyris Learning to Sail 19 11-17-2008 09:30 AM
Ketch/Yawl Handling svsymphony Seamanship 19 07-05-2008 02:19 AM
Cutter to sloop wallm Boat Review and Purchase Forum 6 07-24-2003 01:27 PM
diffrent rigs? (schooner, ketch, cutter, sloop) jbarros Boat Review and Purchase Forum 2 07-09-2003 05:10 PM
Cutter Rigs Vs. Sloop Rigs LarryBrink General Discussion (sailing related) 22 04-16-2001 05:48 PM
SEO by vBSEO 3.6.0
(c) Sailnet 2000-2006
