Seaworthy Sailboat Help! - Page 2 - SailNet Community
 2Likes
post #11 of 19 Old 08-17-2012
Doesn't sail enough
zedboy's Avatar
Paul's post reminds me of a story that happened to someone I know. He bought a Pearson Triton - a boat a lot of people would consider to have bluewater potential - real cheap, and spent a few months fixing her soft decks and redoing the interior. He then set off on a sail down the CA coast, and sliding down the backside of a big roller he landed with a bit of a bump and popped a swage on the shroud. All of a sudden his rig was coming down around him - luckily he wasn't more than a few miles out. He called the CG, they helped him cut away the rig and towed him back in.
What would've happened had he been halfway to HI and a storm brewing? He shoulda know better than to trust 40+-year-old rigging.
Since then whenever I see a chainplate thru-bolted to the cabin trunk (likely without a backing plate ) or a spade rudder I think "How many big thumps would that survive?"
'78 Dolphin 31
zedboy is offline
post #12 of 19 Old 08-17-2012
KNOT KNOWN
Capt.aaron's Avatar
Re: Seaworthy Sailboat Help!
Sounds to me like you want and older Cal or Soverel. Late 60's model, 36 to 40 footers.
Re-rig it with sta-lok top and bottom, get a couple of big anchors and oversize chain, a spool or two of 1/2" 3 strand and pop a dual action hand crank windlass on the bow.
" Some are boat wise and some are other wise"
Capt.aaron is offline
post #13 of 19 Old 08-17-2012
Moderator
Jeff_H's Avatar
If these are your goals,
"A friend and I, both 20 yrs old, and are experienced surfers and sailers. We've both always wanted to go on an adventure to wherever we might end up, meeting new people and surfing new breaks along the way. So the plan is to be crossing oceans as big as the Pacific. Basically going around the world in a criss-cross, zig-zag pattern, stopping basically wherever we want." And
"We would preferably want a center-cockpit so that we can each have our own birth(aft-berth and v-berth). Obviously a functional galley will be needed, and at least one head w/ a shower."
Then none of these make any sense at all:
"Olson 30"
"New York 36, Santana 34, Santana 30, Schock 35 "
In reality these boats are okay for their purpose, but were by no stretch of the imagination even vaguely intended for what you are proposing to do. Faced with your objectives it seems like you should have a more focused list of criterial than you do.
For example, the traditional rule of thumb for distance voyaging is that the boat should have somewhere between 5,500 lbs and 11,000 lbs of displacement per person, with the upper end of the limit creeping up as better hardware and the desire for more space has prevailed. This displacement per crewman was generally a compromise between carrying enough supplies and consumables and what could be easily managed by the crew.
Similarly, you will need adequate tankage, storage, ground tackle handling. You will need good seaberths (vee berths and aft cabins berths on smallish boats are useless features offshore), an offshore suitable galley and head, and a pretty robust boat to take the kind of use and abuse that distance cruising implies. Nice as they are to have as a liveaboard, showers really do not make sense on an small distance cruiser (use too much water and take up too much space)
Lastly boats in good shape with these kinds of features do not come cheaply, but the can be found. If I had to start somewhere I would look at perhaps something like a first generation Seawind, Ericson Independence (31C), Pearson 323 or perhaps a Westsail. There are better performers out there but probably not with the mix you would need to do what you want to do....
Jeff_H is online now
post #14 of 19 Old 08-17-2012
KNOT KNOWN
Capt.aaron's Avatar
You can't go wrong with a Westsail, I've seen 'em for 25 grand in the 30 something foot range.
Let's not rule out an older 35 foot Prout catamaran. They are out there and have done some circ's.
post #15 of 19 Old 08-17-2012
Lookin' for an excuse ...
CaptTony's Avatar
Am I missing something here? There is no way you will get you get a seaworthy boat and do the necessary outfitting for $25,000. If you want to sail the Pacific, you're going to need at minimum two to three times that amount. Even a 40 year old Westsail will need a lot of work.
Capt Tony
CaptTony is offline
post #16 of 19 Old 08-17-2012
KNOT KNOWN
Capt.aaron's Avatar
NO NO NO NO NO. That thought process is why more people are'nt doing it, My buddy just sold is 1966 Cal 36 for ten grand, ready to go. For over the hill suburbanites who are new to the game and need all the crap their house had in it to even consider living on a boat, yes the 80,000 dollar gadget boat is a must. For young adventurous, salty, dudes, all we ever needed was a sound hull, stout rig, some decent used sails and a compass. And YES, you are missing out on the wonderful life of simple barebones, gadgetless and affordable cruising that quite a few of us enjoy. I'm betting your "absolutly need's" are guy's like me "Absolutly don't want's" and that's fine. But these dudes should know that yes, they can get a boat for $10,000 and have $15,000 for the trip.
olson34 likes this.
post #17 of 19 Old 08-20-2012
There is a misconception about the 'size' of sailboat required.
The New York 36 was designed to do the Bermuda Race in style and comfort for a crew of 6-8 by a group of the New York Yacht Club.
Schock 35s have sailed across the Pacific.
A Schock Harbor 25 was just in a microburst - 50+ kts peak recorded. Only boat to keep sailing. Rest of harbor had boats demasted, sails torn up, water everywhere. The Owner of the Schock Harbor 25 was single handing, he furled his jib and kept sailing. Said he had the time of his life - screaming along in 40+ knts winds.
jameswilson29 likes this.
WDS123 is offline
post #18 of 19 Old 08-20-2012
Senior Smart Aleck
jameswilson29's Avatar
I have always been intrigued by the NY36 - they seem to be great values right now.
Do you think a NY36 could be sailed solo fairly easily?
jameswilson29 is offline
post #19 of 19 Old 08-22-2012
cal30's Avatar
Howzit Riverwind,
Good luck with your plans. Hopefully, your buddy has some offshore experience as well. Some good advice given so far. If it's the Pacific you're starting in, there's always boats in Papa'ete, Tahiti for sale. Fiji as well. I've been to both,good surfing, but have no knowledge of accomodations for crusing boats. Something to check out. We have a Cal, and it's a great boat. But, for cruising between the Hawaiian Islands(rough water), I ride with my friend on an Cheoy Lee Offshore 41. 20 tons displacement,3/4 cutaway keel and barn door rudder. A liitle more protection against things that bump in the night. My opinion is heavy displacement and manageable sail plans is best. As for Hawaii, you'd be moored on the South shore during the good surfing months(winter) as there are no good, safe anchorages on the North Shore. 25 grand will get you a boat (probably 30 years old)that could do what you're planning, but getting it ready would be another 15, with new rigging , engine overhaul and any other essentials you will need. My opinion only. I hope that you guys get to do it. Good Luck.
S/V HoloHolo
cal30 is offline
Tags
ocean , sailboat , sea , world , worthy
Bayfield 25, how seaworthy? SVDistantStar Sailboat Design and Construction 40 03-21-2017 06:52 PM
SeaWorthy Badriance Cruising Articles 6 12-22-2012 02:18 PM
Is this 420 seaworthy? sailingnoob Boat Review and Purchase Forum 17 09-16-2010 10:04 PM
How We Define Seaworthy Don Casey Seamanship Articles 0 04-07-2001 08:00 PM
How We Define Seaworthy Don Casey Buying a Boat Articles 0 04-07-2001 08:00 PM
