Suspect hole in hull - SailNet Community
post #1 of 7 Old 08-20-2012 Thread Starter
Dear all,
This is my first post on this forum. I am in my early 30's, I have been sailing for over 10 years cruising and racing in the waters of the channel islands. I have decided to purchase my first sailing boat.
I have yet to purchase I am hoping for some comments on the image below from a boat I am considering.
[IMG]IMG_1782[/IMG]
It's located inbetween the keel and prop roughly under the engine. It seems rather small for a seacock and there is an obvious dampness. The boat sits on a cradle and whilst all other seacocks are dry this one still weeps some 3hours + after the tide. I am still pre-survery but do you have any suggestions what this is?
Kevin
KevinCo is offline
post #2 of 7 Old 08-20-2012
johnnyquest37's Avatar
Re: Suspect hole in hull
Engine raw water intake? Weeps three hours after the tide? What do you mean?
[/B]S/V Wind Orchid
Catalina 350 (hull# 273)
Annapolis, MD
LET'S GET SERIOUS ABOUT REMOVING POLITCAL TAG LINES -- NOW!
johnnyquest37 is offline
post #3 of 7 Old 08-20-2012
where does the cockpit drain to?
buffalobrewer is offline
post #4 of 7 Old 08-20-2012
Skipper Jer's Avatar
And what is the boat? Model, year ?
Skipper Jer is offline
post #5 of 7 Old 08-20-2012 Thread Starter
Johnny, the boat was floating 3 hours previously and the tide went out (quite a tidal movement here). I was wondering if water had penetrated the core if there is one. There are signs of tiny bubbles. The engine had not been running for about a week so I'm wondering why would this one acts differently to other through hulls which are all dry.
Buffalobrewer there hasn't been any rain for a while and I'm not sure where cockpit drains to.
Kevin
KevinCo is offline
post #6 of 7 Old 08-20-2012 Thread Starter
The boat is a golden shamrock 30 from 1979 by the design of Ron Holland.
KevinCo is offline
post #7 of 7 Old 08-20-2012
Since the hole sits over the engine, I was guessing it might be the raw water intake, but there is no thru-hull fitting visible, I wonder what is holding the interior fitting, strainer, hoses, etc. in place. I'd take a look in the hole and see what is up there.
[/B]S/V Wind Orchid
Annapolis, MD
Help for small hole in hull near Beaufort, NC synapse General Discussion (sailing related) 5 08-20-2012 01:06 PM
Re-using thur-hull hole? Tanley Gear & Maintenance 2 04-23-2011 07:00 PM
Drilled Hole in Hull Repair weephee General Discussion (sailing related) 22 08-04-2009 11:56 PM
Thru Hull Hole Sizing cas8100 Gear & Maintenance 1 07-10-2009 06:55 PM
Open ocean, hole in the hull wind_magic Seamanship & Navigation 48 09-06-2007 12:21 AM
