Looking for my first boat - Page 2 - SailNet Community
 1Likes
post #11 of 15 Old 10-26-2012 Thread Starter
Send a message via Yahoo to future sailor
Re: Looking for my first boat
TY Steve for the input.
Another question, is there any difference in a steel or lead or iron keel?
future sailor is offline
post #12 of 15 Old 10-26-2012
Senior Smart Aleck
jameswilson29's Avatar
Lead has the greatest density of the three allowing a smaller volume for the same weight. Lead absorbs more energy in the event of a grounding. Lead is the easiest to re-shape for optimal speed of the foil through the water. Lead may also be the most expensive to use; consequently cheaper boats and high volume production builders have used iron or steel.
I understand you can now recycle a lead keel for about $1 a pound.
jameswilson29 is offline
post #13 of 15 Old 10-28-2012 Thread Starter
Well, we went and looked at our first boat(s) yesterday. OMG! My head is still spinning trying to wrap my head around it all. Man do I have a lot to learn and there are a lot of things to know and learn about a boat. But the wife definitely said "we don't need a small boat" lol. she wants a private head or porta-pot. And she likes the more "open" layout of the cat 26/7(?) we looked at. That's good and bad I suppose. Lets me/us know where to head and how to get there, but also means more work for me now. lol.
post #14 of 15 Old 10-28-2012
scurvy's Avatar
Send a message via AIM to scurvy
Originally Posted by jameswilson29 View Post
Gasoline fumes are the real danger. The fumes are heavier than air and can fill enclosed spaces like a boat. Boats with gasoline inboard engines have a blower to expel the fumes from the inside of the boat before starting the engine.
In addition, gasoline has a lower flash point than diesel fuel. You can light gasoline with a match, whereas you cannot light diesel fuel with a match.
Diesels engines do not require the complicated ignition systems that gasoline engines do, making them simpler and more reliable.
Totally agree, however, I had an Atomic 4 In my Sabre and loved that little engine. There are simple steps to take to assure that the gas engine can be used safely. Closing all hatches, ports and washboards when fueling up, then airing everything out prior to firing up the engine. Run the sparkless blower for the recommended amount of time, etc...should be no problem.
People have LP gas on board which is equally as dangerous, seeks low areas (ie: bilge) and can go up in an instant, but do we recommend to cruisers to use alcohol stoves only? As long as the proper steps are taken and become ritual, one should have no issues with operating a gas inboard safely.
In terms of reliability, I had more trouble with my diesel on the Vega than I did with the A4, your mileage may vary. diesel needs to be treated, water can build up, micro organisms can grow, fuel filters need to be watched carefully, lines bled constantly...they are a lot of maintenance as well.
I guess my point here is not to allow a gas engine to be a deal breaker for you necessarily, particularly if it has been well maintained.
Good luck with your search and welcome to the sailing family!
scurvy is offline
post #15 of 15 Old 11-28-2012
Well this si good you have your boat you have all the latest features in your boat and this is good infomation about the boats also i was collecting fotr this information and also in collecting some Kayak and surfboard informaiton at here..
Link to site with commecial content removed per forum rules. Jeff_H: SailNet Moderator
Anderson222 is offline
WANTED: BASIC BOAT BBQ. CHARCOAL IS OKAY, BEATUP IS OKAY, ANY BOAT BBQ - $25 seattle stephenronning Gear & Maintenance 2 03-30-2009 09:21 AM
Coast Guard finds missing boat, still searching for other boat - FayObserver.com NewsReader News Feeds 0 05-11-2007 11:15 PM
Coast Guard finds missing boat, still searching for other boat - Access North Georgia NewsReader News Feeds 0 05-11-2007 10:15 PM
Coast Guard Finds Missing Boat, Still Searching For Other Boat - WSOCtv.com NewsReader News Feeds 0 05-11-2007 04:15 PM
Coast Guard finds missing boat, still searching for other boat - Myrtle Beach Sun News NewsReader News Feeds 0 05-11-2007 08:15 AM
