Pros and cons of steel sailboats - Page 136 - SailNet Community
 1723Likes
post #1351 of 5317 Old 10-01-2013
grumpy old man
I think I saw a video of their launch posted here. If o, it was a very sweet looking boat.
Bob's Blog ....
bobperry is offline
post #1352 of 5317 Old 10-01-2013
Moderator
Jeff_H's Avatar
Originally Posted by outbound View Post
At the risk of being mundane ( above posts where delightful and reminds me Beethoven continued to compose after he lost his hearing and the Wizard of Bristol kept drawing after he was too old to sail) wish to return to frameless construction. Seems practical way to increase plate thickness while eliminating frames so total hull weight remains in "acceptable" limits. What I wonder is:
Is there a upper and lower limit to LOA where it just doesn't make sense?
Why don't we hear about this technique more in Aluminum construction? Being easier to bend and of significantly lighter weight seems LOA limitations are less likely to apply. Forget where but seem to remember a new sailboat manufacturer using a modification of this technique. Also wonder if a female mold could be constructed and with a hydraulic press using Al ( or possibly steel but more force involved) a production line of sailboats could be constructed at very reasonable cost.
Just wondering
I am not sure that the limit on going frameless is length as much as it is displacement.
As a boat gets heavier, it needs more sail area if it is going to sail well. If the boat is going to stand up that bigger sail plan then it needs more stability. The combination results in the keel connection loads and rigging loads increasing. And as these loads increase, it gets harder to disburse them into the skin without distorting the skin, and so load patches need to be added. (Think of it this way, a sail is a single membrane monocoque structure, and so as the sail gets larger bigger stress patches need to be added at the tack, head, clew and reef points.)
Like the sail analogy, on a small boat you might be able to simply use heavier hull plating (sailcloth) rather than add stress patches but as the boat gets heavier the concentrated loads increase more extensively than the skin loads.
At some point, merely adding stress patches aren't enough and so knees and a minimum amount of frames get added at the highest stress locations rather than end up with a hull that is absurdly thick. Eventually as the boat gets heavier still these added frames end up concentrating loads in narrow bands and so additional structure is added to move the loads more effectively around the skin.
A good example of this phenomina is early fiberglass boats. When they first started building fiberglass boats, they wanted them to be frameless. The US government had done a lot of research on FG during WW II and the early designers knew that fiberglass was very string in bending, but not very stiff. Unlike the mythology, the early FG boats had thick hulls to deal with flexure. (Unfortunately to get that thickness early boats generally used a number of methods to bulk up the laminate which undermined the strength of the laminate especially over time. but that's another story..)
When you look at these earliest FG boats, even though they were very heavily built, it was not unusual to see dimples in the topsides where rigging loads distorted the hulls. Pretty quickly designers and builders started adding knews and structural bulkheads. By the mid to late1970's fully framed FG boats became the norm.
It is a similar problem with steel, as the boat gets longer and heavier, at some point the choice becomes to add frames, end up with an absurdly heavy hull, design a way to distribute the loads with the geometry of the hull and/or deck, or live with distortions.
There actually have been production aluminum power craft. Probably a decade or so ago, I attended a lecture on new aluminum Coast Guard boats. The aluminum sheets were precisely cut by a computer driven cutter. The electronically developed plate drawings allowed the yard to develop very efficient 'nesting plans' which allowed the carefull layout of the individual parts on the plate so there was very little waste. The cut plans included small tabs which allowed the precise aligment of the parts as the boat was assembled. Bulkheads served as part of the structure and also helped precisely control the final plate shapes. Very impressive to see.
I think that aluminum lends itself to the newer hull forms and so is more popular in Europe where they have embrassed the Open Class style boats more than we have here.
Jeff_H is offline
post #1353 of 5317 Old 10-01-2013
A couple of very successful origami aluminium 55 footers have been built here. I saw one at Christmas Islands the last time I was down there. She sailed back home to northern BC in November, a severe test in itself. The owner, Jean Marc loves to sail his homeland , Hecate Strait, year round, and the rougher the better for him .He has done enough miles of fulltime cruising up there to go around the world . You can often find him in Old Bella Bella, where he bought the place.
The French have been building heavily plated aluminium origami boats for a long time now, called "Strongall boats." A google search will find them.
I always use some transverse floors on my boats to help stiffen the keel attachment . On the single keel there is the aft end of the ballast and centreline tank , nearly 4 feet wide, and going to the bottom of the keel. Then there is a baffle 4 feet forward of that, again 4 feet wide and going almost a foot into the keel . Then there is the forward end of the tank and the top, most of a 4x8 ft sheet of steel .making a super strong and rigid structure . Twin keelers have 4- 3x3x1/2inch angles, on each side, from the chine to the tank edge, supporting the twin keels.
The topsides are a 3 ft wide, 3/16th steel plate on end, giving a chain plate attachment far stronger than any rigging wire you could ever put on them.
A good comparison of stiffness is to consider the way some GRP boats have cheated the rating rules ,by putting a big hydraulic backstay adjuster on, and cranking it until the boat sags and the waterline shortens considerably, for measuring. If you try that on a steel or aluminium origami boat , you wont change the waterline length a sixteenth of an inch. You will break the backstay long before that happens. I once broke the handle off a 3 ton come along trying to take a 1/16th inch twist out of a hull, after the decks were on. The hull never budged.
I put a half inch plate web under the mast support, then connect ( triangulate) the ends of that to the chine with pipes. The chines, structurally, constitute a longitudinal angle, 3 ft by 5 ft by 3/16th, far stronger than any combination of rigging wire which will ever load them
60 ft seems to be the upper limit, but one can use origami methods on larger hulls, and put stiffeners in after the hull is together, saving a huge amount of time over traditional methods.
A mold wouldn't give you any advantage over the external frames Van De Stadt uses. That kind of framing type mold would not be worth the trouble for a one off ,but would be well worthwhile for mass production. The weight of the steel would push it down into the frames, little more pressure is needed. A similar mold for decks would also work. Putting the plate shapes on a disk, for computer cutting, would save a lot of time for mass production. Interiors could also be done that way.
Brent Swain is offline
post #1354 of 5317 Old 10-01-2013
grumpy old man
"A good comparison of stiffness is to consider the way some GRP boats have cheated the rating rules ,by putting a big hydraulic backstay adjuster on, and cranking it until the boat sags and the waterline shortens considerably, for measuring."
Interesting. Can you tell us Brent what rating rules in place since the popular advent of hydraulic backstay adjusters actually measure the waterline?
Cute story but not based on any fact. One of my hobbies is the study of rating rules and their evolution. Better bring your A game to that question.
I was interested in how small a boat you think you could build in your origami method. What's currently the smallest boat you have done?
Bob's Blog ....
bobperry is offline
post #1355 of 5317 Old 10-01-2013
Jon:
Lots of composers composed for instruments they could not play. Mozart wrote a lot of horn concertos but he did not play the French horn. His buddy did.
Little Bobby Schumann could play the piano just fine. But there is a theory that he wrecked his hands using a contraption designed to stretch his finger reach. It is known that he did use this odd device. It's not clear if that's what lead to him stopping playing. But, he was a very weird guy. Ended up committing himself to an asylum where he eventually died. Some think he starved himself to death. Others think he died of syphilis.
Bobby's wife, Clara, was a very famous virtuoso in an age where it was very unusual for a woman to be a professional musician. She was also an accomplished composer when very few women were composers. Brahms lived with Bobby and Clara. Think of that.
What does this have to do with pros and cons of steel sailboats?
post #1356 of 5317 Old 10-01-2013
Originally Posted by chall03 View Post
Bad Smacky. Place nice in Sully's sandbox or he will send you home. Remember that place is all about HIM not sailing.
Brent, let's be clear about this. Smack was banned from Stuffers cause Sully is a dick. He is NOT just the Mod at Stuffers, he is the megalomaniac owner.
If that is your intended audience Brent then hang over there and leave us the hell alone.
How long did you last at stuffers??
Sully runs a great site, where innovation is encouraged . He's a good moderator. He was not the first one to point out that Smack and Bob were only there to follow, misrepresent and attack my posts.
Your hero, Smack, attacks all forms of innovation, and hides behind an alias.
Doesn't use his real name.
Google Smackdaddy
post #1357 of 5317 Old 10-01-2013
Come on Brent. I'm a technician and this sounds like i could pick up a lot of useful information following this train of thought.
Zen is a matter of recognizing reality.
desert rat is offline
post #1358 of 5317 Old 10-01-2013
Bob
Is it true that Boeing Surplus in Seattle is no more? It was a great source of tools and titanium.
That would be sad.
post #1359 of 5317 Old 10-01-2013
You are welcome to anything I have learned on the subject, over 38 boats and over 40 years of boatbuilding and cruising . Pick away and ask away. That is what these discussions are for.
post #1360 of 5317 Old 10-01-2013
djodenda's Avatar
Brent:
The Boeing Surplus Store is now online:
https://surplus.boeing.com/Index.cfm
I've not been looking much lately, and haven't noticed any titanium (The 787 has more Ti than any other previous model.. works better with composites)..
It might be a place where you can see expired rolls of carbon fiber pre-preg, which is probably still good, but you'd need to heat it up to cure it.
I see they are auctioning off 81,000 lbs of Invar.. maybe that could be a new thread regarding the pros and cons of building boats with Invar.
Pro #1: Less of a problem with thermal expansion..
(somebody go next)
David
1987 CS 36 Merlin "Kyrie"
djodenda is offline
Closed Thread
