Pros and cons of steel sailboats - Page 19 - SailNet Community
 1723Likes
post #181 of 5317 Old 07-16-2013
bljones's Avatar
yeah, okay.
Minnesail likes this.
It's 5 o'clock somewhere:
bljones is offline
post #182 of 5317 Old 07-16-2013
Senior Moment Member
SloopJonB's Avatar
forget about this Spray design, a true disaster in any material.
Fixed it for you.
The Spray - proof that even a haystack will sail downwind. Every Spray I've seen has made those Dutch lee-board barge yachts look like high tech racers.
Brent Swain likes this.
SloopJonB is offline
post #183 of 5317 Old 07-16-2013
SloopJonB's Avatar
I don't know if people have failed to recognize it or if they simply reject the concept but I understand where BS is coming from.
His priorities (ONLY priorities it appears) are cheap, relatively simple construction and ultimate survivability at sea - icebreakers as it were.
Aesthetics other than the brutal, purely functional workboat type, simply don't enter into his philosophy.
That is simply a lack of artistry IMHO. Bob & I wrote earlier about a local log salvage boat named Beach Boy that was designed by Garden. It is absolutely beautiful and a log boat has as hard a life as any boat out there. Most of them look much of a muchness with BS's boats from an aesthetic POV but Beach Boy proved they don't have to - you simply have to care about it and have a designer with some artistry.
I find BS's origami process interesting but I'd sure like to see one done with the aforementioned artistry, especially re: the deck structures.
post #184 of 5317 Old 07-16-2013
Lots of steel boats have been built by amatures in less then ideal conditions.IMHO there are even some good looking ones with chines.The Wylo II comes to mind.Folded plate construction(Origami) has been around for a while.Its not "Brents" he didnt originate it.He did not originate DIY either.He didnt invent ocean cruising,sailing, welding, or anything else as far as I can tell.The claim that he "pulls a hull and deck together' really means he has only tack welded it together.Its far from a complete shell.There is still many hours of welding to go just to get a empty shell.You can save alot of money fabricating fittings,using discarded wood for an interior.But even cheap epoxy is expensive(Yogi Barra?).For my area just a space to build in is expensive as hell.Trevor Robertson built his wylo Iron Bark in 2 years.Hes sailed her 100,000+ miles including wintering over in Antartica and Greenland. This is and interview with him and Annie Hill.Annie Hill & Trevor Robertson - YouTube
He seems like a nice guy.He probably wont insult your wife or belittle you for your choices.
jak3b is offline
post #185 of 5317 Old 07-16-2013
Holy CRAP! Now these are people I can respect.
Look at this!
Smiley face
Smiley face
Iron Bark's travels
Go the Trevor and Annie!
smackdaddy is offline
post #186 of 5317 Old 07-16-2013
bljones's Avatar
^^^This, friends, is what happens when you wait just a little too long for winter haulout in Ontario.
nemier, tdw, smackdaddy and 1 others like this.
bljones is offline
post #187 of 5317 Old 07-16-2013
Heh-heh. I have some very deep sympathy for you guys in the winter. That's brutal.
I'll raise a warm beer northward this January and have a moment of silence while I adjust my flip-flops.
post #188 of 5317 Old 07-16-2013
outbound's Avatar
I have read this thread from beginning to end and would wish to offer the following observations.
1.I took the commercial welding course at the local voc. school when deciding if I wanted to have a steel/aluminuim boat. I wanted to know about TIG/MIG welding,use plasma cutters etc. I figured if I went that way even if I had K+M or Kanter build the boat for me at least I would know what was a good yard, what was good construction,what was good 5k series Al or 3 series SS etc.
2.I have sailed on AL and Fe boats. and at one time was very close to buying a Boreal
Fe can be done well. In general it is cheaper, faster and safer to have it done by a professional yard. For me the calculations showed it was cheaper to have a professional yard do it as I could make more money at my day job per hour then they cost per hour given they are so much more productive with that hour. Also availability and expense of subsequent innsurance etc. needs to be factored in. Fe make sense at >50-60' but not below.
Al requires great skill and a controlled environment to be done correctly. Design of all systems not only the structure of the boat must be done and installed keeping the issues with Al foremost in mind. It is a material which is very viable for boat construction but in my view can only be done effectively in a professional yard to design made orginally for Al.
Owners of metal boats need an additional knowledge base concerning the issues germaine to metal construction and maintenance. The Metal Boat Society was a good resource for me.
I went with solid glass hull and divynicell core deck/house etc. Hannah2 went with Al professionally built. Both are good decisions for "blue water boats". In the current era unless one wishes to go slowly, can avoid going to weather, have very limited comforts,can spend years of their life getting a boat ready for sea and can self insure a BS boat makes little sense.
I would encourage the OP to google the Dutch/French yards, speak with surveyors and see/sail vessels in this catagory before making the jump.
s/v Hippocampus
Outbound 46
outbound is offline
post #189 of 5317 Old 07-16-2013
I respect people who sail to Greenland, Antarctica,NW passage but for me no thanks!.I want to be in an area that can natively support coconuts.San Francisco is bloody cold as far as I am concerned;-).
smackdaddy likes this.
jak3b is offline
post #190 of 5317 Old 07-16-2013
bljones's Avatar
Thanks for the thoughts, smack.
bljones is offline
Closed Thread
Pros and Cons of Catalina 350?? turfguy C350 8 12-27-2016 02:55 PM
C & C 24 pros and cons chuckg Boat Review and Purchase Forum 13 05-20-2015 01:05 AM
Hunter 36 Pros and Cons? turfguy Hunter 15 08-25-2014 06:08 PM
Watermakers—Pros and Cons Tom Wood Cruising Articles 0 06-11-2002 09:00 PM
Steel Hulls—Pros and Cons Sue & Larry Buying a Boat Articles 0 09-12-2001 09:00 PM
