Pros and cons of steel sailboats - Page 33 - SailNet Community
 1723Likes
post #321 of 5317 Old 07-30-2013
Originally Posted by davidpm View Post
That is clever. Wouldn't have thought of that.
What do you use for bottom paint or the more accurately the whole bottom maintenance process.
Being a twin keeler ,with much of my time drying out , paint doesn't last long on my keel bottoms, and they have been bare 99% of the last 29 years. Not much sign of any corrosion or pitting. Zincs keep her in good shape, welded on for guaranteed contact. I use stainless bolts for temporary contact, with stainless weld around the bolt holes, to guarantee stainless to stainless contact, til I can get a tack on. Otherwise, a bit of rust on the strap can insulate the zinc from the hull, making it useless. I used epoxy tar when I launched in 84. On m first haulout, in 2,000, I gave her a coat of Wasser tar with copper ablative paint over it. Since then I have tried epoxy with epoxy cop antifouling paint, wet on wet, which seems to work much better than ablative paint, and you can scrub it any time. I hope to do the whole hull underwater that way, when full pension rolls in.
Brent Swain is offline
post #322 of 5317 Old 07-30-2013
T37Chef's Avatar
I thought BS got banned? LOL
Shawn
T37Chef is offline
post #323 of 5317 Old 07-30-2013
Originally Posted by mark2gmtrans View Post
Smack,
I am pretty experienced at working in sheet metals, and I have gotten paid a lot of money to weld stuff that was x-rayed, pressure tested, and inspected very tightly, and I would not attempt to build a steel boat unless I was in a full service sheet metal shop with a plasma cutting table, a heavy steel break, roller, and all the rest of the stuff you would find in an industrial fabrication and machine shop.
I am fairly sure most wannabe cruisers do not have this, which as far as I can see is the only reason they would consider a BS design in the first place. I certainly would not build a blue water cruiser out of steel without using frames, because I would want to be able to isolate compartments using some of those frames, and I would want to have the rigidity that the frames would give not only my hull, but my deck and my cabin sole, plus that it would give a nice place to hang stuff that I wanted to mount, like conduit and plumbing.
certainly am among the few I know with the skills to do the job, though I am far out of practice, I have not forgotten, and I still do some welding and fabrication for a couple of charity organizations from time to time. Most people are not certified welders, do not have any skills in working sheet metal, and certainly do not have a shop with overhead cranes, welding machines, torches, plasma cutters, grinders, a brake, a roller, or a sheer and this stuff is expensive.
This little gem is $24,500.00 and you would need it to build a steel hull boat of any size or you would need to pay someone to use theirs.
By the way, if you have one of those and a press roller and all the other stuff in a nice big high ceiling shop, say 80 feet high, located directly on the waterfront please feel free to contact me, we might be able to build something.
I worked for may years on a brake press in the 70's, at Mainland Foundry in Vancouver on a 180 ton Pearson hydraulic, along with plate rolls and section rolls, at Canron in Vancouver, on a 400 ton Pacific hydraulic and a Cincinatti 600 ton mechanical flywheel brake , and in Auckland at A&G Price on an 87 ton Dye hydraulic. I was considered very innovative as a brake operator, being asked to do jobs no one else could figure out. In all the boatbuilding I have done 38 hulls , I have only seen about 15 minutes worth of brake press use which would have been helpful, the edges of the forehatch and main hatch cover and the cockpit well, which we have had done for as little as $10. I have seen no use for any other kind of rolls in my boats. They could be useful on a power boat, with so many straight corners, but not on a sailboat, with almost all corners curved.
Plasma is nice , but not worth the cost for a one off. For the last boat we found it too finicky, and it quit often, without reason, so we used the torch mostly.
Inability to build a small steel sailboat without such expensive toys would take a total lack of imagination, or lack of ability to innovate.
Welds on a 36 footer simply don't break, no matter how badly they are done. I've never heard of it happening. The inertia of a 36 is simply not great enough. How does even the worst weld compare in strength to that of a copper fastening in red cedar every six inches, or six inches of plastic?
A kid I taught how to weld and build boats, went to welding school and got every ticked he needed. He said "Boy ,when it comes to embellishing their importance, welders are sure full of it."
Or as my next replacement says "You are not building a nuclear submarine."
You should s check out the origamiboats site, or my book or Alex's video to see how we have made overhead lifts redundant, by our building methods. Innovation does the trick.They would save maybe an hour or two at most, in building an origami boat.
80 ft overhead clearance would only be useful if you planed to put a 70 ft mast up in the shop. How often is that done?
I , Roberts, Dix, Tanton, Van de Stadt, Shannon and many others have designed very successful boats, without transverse frames, for decades, none of which have suffered any consequences for not having frames, and which has proven transverse frames irrelevant in a boat under 41 feet.
So would it be wise to believe the statements that we are all wrong, by someone who has never built or cruised extensively in a small steel sailboat?
This is the type of uninformed disinformation which needlessly discourages people from building their own small steel sailboats, and has them going to sea in boats which have far less chance of surviving a collision with Fukashima debris, sometimes resulting in boats going missing without a trace.
post #324 of 5317 Old 07-30-2013
grumpy old man
By the amount of BS I'd say his fingers are well rested.
Bob's Blog ....
bobperry is offline
post #325 of 5317 Old 07-30-2013
tdw
Super Fuzzy Moderator
tdw's Avatar
If we banned BS we'd lose all of Off Topic and probably half of On
Otoh ... Brent went for a short vacation.
Andrew B (Malö 39 Classic)
― Terry Pratchett.
tdw is offline
post #326 of 5317 Old 07-30-2013
You said it brother. That's why I bought a fiberglass boat!
This is the type of uninformed disinformation which needlessly discourages people from building their own small steel sailboats, and has them going to sea in boats which have far less chance of surviving a collision with Fukashima Debris, sometimes resulting in boats going missing without a trace.
jak3b likes this.
smackdaddy is offline
post #327 of 5317 Old 07-31-2013
grumpy old man
Little BS is back. Welcome back little guy.
Bob's Blog ....
bobperry is offline
post #328 of 5317 Old 07-31-2013
aeventyr60's Avatar
More lively discussions on the way. Was wondering why we did not have some thoughts on the bullet proofness of vinylester over polyester and plain epoxy?
"Your dreams minus your doubts equals your net worth"
Life is a short journey, filled with emptiness and pain. Get all the sailing and booty you can.
aeventyr60 is offline
post #329 of 5317 Old 07-31-2013
grumpy old man
Here are some of Neil Rabinowitz's Photos from the SLIVER move. This boat has a steel keel fin and an elaborate steel floor system to support mast and keel loads so I think it belongs here. Besides it raises the aesthetic bar and this thread could use that. I'm off to Seattle tomorrow to see it at the new yard. And no, I am most certainly not going to shoot it.
Bob's Blog ....
bobperry is offline
post #330 of 5317 Old 07-31-2013
Make sure to swim and get some ice cream!
Closed Thread
