Pros and cons of steel sailboats - Page 34 - SailNet Community
 1723Likes
post #331 of 5317 Old 07-31-2013
Splashed
JomsViking's Avatar
Here are some of Neil Rabinowitz's Photos from the SLIVER move. This boat has a steel keel fin and an elaborate steel floor system to support mast and keel loads so I think it belongs here. Besides it raises the aesthetic bar and this thread could use that. I'm off to Seattle tomorrow to see it at the new yard. And no, I am most certainly not going to shoot it.
Love it!
Please keep posting Pictures.
/Joms
Watch great footage about the story of one man’s slow odyssey around the UK:
JomsViking is offline
post #332 of 5317 Old 07-31-2013
Senior Moment Member
SloopJonB's Avatar
Have you got another Swiftsure winner there Bob?
And PLEASE - tell us those steel floors are stainless, not coated mild steel. That's been done and it always seems to end badly, eventually.
SloopJonB is offline
post #333 of 5317 Old 07-31-2013
sailing soon
mark2gmtrans's Avatar
Send a message via Yahoo to mark2gmtrans
I worked for may years on a brake press in the 70's, at Mainland Foundry in Vancouver on a 180 ton Pearson hydraulic, along with plate rolls and section rolls, at Canron in Vancouver, on a 400 ton Pacific hydraulic and a Cincinatti 600 ton mechanical flywheel brake , and in Auckland at A&G Price on an 87 ton Dye hydraulic. I was considered very innovative as a brake operator, being asked to do jobs no one else could figure out. In all the boatbuilding I have done 38 hulls , I have only seen about 15 minutes worth of brake press use which would have been helpful, the edges of the forehatch and main hatch cover and the cockpit well, which we have had done for as little as $10. I have seen no use for any other kind of rolls in my boats. They could be useful on a power boat, with so many straight corners, but not on a sailboat, with almost all corners curved.
Plasma is nice , but not worth the cost for a one off. For the last boat we found it too finicky, and it quit often, without reason, so we used the torch mostly.
Inability to build a small steel sailboat without such expensive toys would take a total lack of imagination, or lack of ability to innovate.
Welds on a 36 footer simply don't break, no matter how badly they are done. I've never heard of it happening. The inertia of a 36 is simply not great enough. How does even the worst weld compare in strength to that of a copper fastening in red cedar every six inches, or six inches of plastic?
A kid I taught how to weld and build boats, went to welding school and got every ticked he needed. He said "Boy ,when it comes to embellishing their importance, welders are sure full of it."
Or as my next replacement says "You are not building a nuclear submarine."
You should s check out the origamiboats site, or my book or Alex's video to see how we have made overhead lifts redundant, by our building methods. Innovation does the trick.They would save maybe an hour or two at most, in building an origami boat.
80 ft overhead clearance would only be useful if you planed to put a 70 ft mast up in the shop. How often is that done?
I , Roberts, Dix, Tanton, Van de Stadt, Shannon and many others have designed very successful boats, without transverse frames, for decades, none of which have suffered any consequences for not having frames, and which has proven transverse frames irrelevant in a boat under 41 feet.
So would it be wise to believe the statements that we are all wrong, by someone who has never built or cruised extensively in a small steel sailboat?
This is the type of uninformed disinformation which needlessly discourages people from building their own small steel sailboats, and has them going to sea in boats which have far less chance of surviving a collision with Fukashima debris, sometimes resulting in boats going missing without a trace.
Well you certainly think a lot of your opinions, as I do my own. I have personally been in charge of transportation for a LOT of steel that went to shipyards to be used in the building of ships. Funny thing BS, a lot of it was rolled, or had been bent with a press brake. It is a good way to get nice straight lines in steel, something I am sure you know. Now as to why I want the building to have such a nice high clearance, I want to be able to rig the vessel inside in order to have it all ready once I am ready to move it. I would not leave it on there, I just would like to be able to get every bit of the rigging done indoors, all the stuff fitted and done correctly, then take it all down and transport it. I kind of doubt that it would be a bad idea to be able to do it, an even better one would be to have the building be located where you could launch the boat mast and all right into the ocean by using a nice travelling crane to walk it out and set it gently into the water, fully rigged and ready to test the engines and sails.
If you used a brake or roller to make some of the bends and shapes you would be able to get a lot more out of the steel than if you did not. The fact that you are braking the material when you pull it together does not mean that a method of braking it was not used, because it is either rolled or has a brake in it anywhere it is not flat. Facts is facts, and since even you are not trying to sail a flat piece of steel it had to get bent some way, I just thought I would prefer to do it a little ahead of time, and not as I was trying to make the hull joints. In fact in light steel like the kind you use I would think the brake would give some rigidity, like if you broke the two halves at the keel seam up to a 90 degree angle to make a flange to weld together there, now maybe you are using angle iron or something like that welded at the keel seam, but I think that if you ran it through a brake, or even a roller brake and put a 4 inch high 90 degree flange along the seam it would be easier to weld, and would have a really good structural load point there.
Maybe I am wrong, but I know the material would be much stronger and you would have the added benefit of that flange, which you could have to the inside or the outside whichever one makes the most sense to give you a structural reinforcement right there along the keel seam. If it were facing to the inside you could drill through it to mount things like the mast step, the engine mounts, and the other loads. If it faced outward it would act as a mini keel from stem to stern and you would have a centerline that you could use to anchor the keel on the cross section as well as the welds or bolts that you use from the bottom to the hull. If you wanted to do things like that to the design then you could, but of course you like to have it built in someone's backyard, take ten years to do it, and then have the poor original owner have to sell it and let someone else come in to finish it.
It is good to learn from your mistakes, but much better to learn from the mistakes of others...
mark2gmtrans is offline
post #334 of 5317 Old 07-31-2013
grumpy old man
Jon:
Trust me that every component of this design has been chosen for it's suitability with the build and purpose of this first class yacht. We are very comfortable in our choices.
As for the Swiftsure Race, thanks for saying that but my client does not want pulpits or lifelines so we would not qualify for the Swiftsure. We will have to contend ourselves sailing around the Sound beating up on anything we can find. I pushed for lifelines but lost that argument. I know the boat will look better without them but,,,,,,,,,,,,,,,,,,,,,,,,
Bob's Blog ....
bobperry is offline
post #335 of 5317 Old 08-01-2013
grumpy old man
It just gets beautifuller and beautifuller. I can't help it. I'm good. I have worked hard all my life to be good at this. When I make myself happy then I know I have hit a home run.
Bob's Blog ....
bobperry is offline
post #336 of 5317 Old 08-01-2013
bljones's Avatar
So, that qualifies you to discuss construction....how?
BS and i may disagree on many things but no one can deny that he has designs on the water, and has built a boat or two. Hydrodynamics and aesthetics and personality aside, he has been there and done that..
you, on the other hand?
watched a truck being loaded, apparently.
It's 5 o'clock somewhere:
bljones is offline
post #337 of 5317 Old 08-01-2013
Picnic Sailor
chall03's Avatar
I sincerely apologise to Bobs wife, for involving someone who is not involved in any way. After Bobs very personal insults to me and my work, I guess I didn't see the part where he and others are allowed to insult anyone they please with impunity, and their targets are nor allowed to respond in kind. I had no business involving an inocent third party. If you go back you will find my responses are just that, responses to personal insults, first hurled at me.
As far as apologies go that one sucked.
'Life is either a daring adventure or nothing' - Helen Keller
chall03 is offline
post #338 of 5317 Old 08-01-2013
Bob, you most certainly have the "eye"!!! Beautiful lines!
Vindö 50
copacabana is offline
post #339 of 5317 Old 08-01-2013
grumpy old man
Thanks Copa. It has been a very enjoyable project.
Bob's Blog ....
bobperry is offline
post #340 of 5317 Old 08-01-2013
Moderator
Jeff_H's Avatar
There are woman and boats that need all kinds of war paint to look as good as they can, but there are the few-and-far-between whose beauty is so natural and compelling that there is no need to try to improve it with camouflage. Seeing every inch painted just plain white, emphasizes that this is one of those few-and-far-between. Nice work Bob.....
Jeff_H is offline
Closed Thread
