Pros and cons of steel sailboats - Page 442 - SailNet Community
 1723Likes
post #4411 of 5317 Old 04-10-2014
outbound's Avatar
So we are back to grp, composite wood, and Al as viable materials for those with visions of a boat within financial reach not requiring excessive maintenance that actually sails until one is up to mega yacht length.
s/v Hippocampus
Outbound 46
outbound is offline
post #4412 of 5317 Old 04-10-2014
christian.hess's Avatar
as it has been for quite a long time now
jajaja
Merit 25 sold...Islander 36 still afloat? who knows...Im still in Columbus, and back...I think...jajajaja!!!!
christian.hess is offline
post #4413 of 5317 Old 04-10-2014
scally wag
just found a nether pic of "pearl song" my ol brent swain
christian.hess likes this.
sonsunmandelin is offline
post #4414 of 5317 Old 04-10-2014
Senior Moment Member
SloopJonB's Avatar
This looks like a good buy for someone wanting a steeler.
1996 Roberts Cutter Sail Boat For Sale - www.yachtworld.com
SloopJonB is offline
post #4415 of 5317 Old 04-10-2014
Once known as Hartley18
Classic30's Avatar
Dock
Originally Posted by chall03 View Post
I remember one of the new millionaire maxi toys cutting the fleet up a few years back, the skipper screaming "mother f***ing starboard" to all, but as he came up on one of the old salts on a Van de Stadt the guy looked over at him and just replied "STEEL"
The maxi beared away.
In the only Sydney-Hobart I've ever been in, I was one of the crew on one of those maxis heading for the start line at full speed just like you describe, with numerous "skittles" getting shoved out of the way to the left and right of us... No major damage done (that I know of) just a few scrapes off the paint job and a few damaged egos - but quite a spectacle, let me tell you!!
(Of course, nowadays they've separated the boats into two separate start lines precisely to stop this happening.)
chall03 and christian.hess like this.
Classic30 is offline
post #4416 of 5317 Old 04-11-2014
DEAD WRONG!
The many people happily cruising in small steel boats, and making just as good a passage times as most, who wouldn't dream of owning anything but steel boat, prove this dead wrong with every good passage they make .You'd be far better off getting your advice from those who have actual long term cruising experience in steel boats, rather than from those with little or no steel boat experience,trying to justify their plastic boat decisions.
A Canadian boat from Saltspring Island BC was just rolled and holed 1300 K NE of Auckland.Luckily for the skipper, a nearby freighter was able to pick him up in rough conditions. The boat was lost. What could punch a hole in a boat after being rolled? Probably a broken mast. The odds of a mast punching a hole in 3/16th steel plate?
ZERO!
I just checked a dent in a 36 anchored next to me, a dent made by hitting a rock at hull speed, about 6 inches deep by 40 inches in circumference. Tensile strength of 40 inches of 3/16th plate at 11,500 PSI per lineal inch? 460,000 lbs! It would have torn the bottom out of anything but a steel hull. This impact happened several years ago. The skipper has continued cruising since then , and hasn't got around to straightening it out. Its just not that important.
Ya Bob . I know . Its all the designer's fault when anyone hits a rock! (Jeeeezze)!
Odds of a mast floating in water, giving that kind of impact?
ZERO!
A plastic boat is only lower maintenance if you use it like Smack does, park it in a marina , throw money at it by day, then go home to a house and spout advice on all there is to know about living aboard and cruising full time, something he doesn't do.
A steel boat is more like an off road vehicle of cruising. Things simply don't work loose, pull out or leak .You don't have to keep rebedding gear, and chasing down leaks , as you do on nonmetal boats. Using a stock plastic boat for off the beaten path, full time, long term use is like using a Lincoln continental for off road or logging road use. In that kind of use, a steel boat has far less maintenance (repairs).
Without the freighter, the skipper of the returning boat NE of Auckland would be just another "lost without a trace" , skipper, like so many plastic boats cruisers. Had he had a steel hull, he could have jury rigged for the distance left to Tonga , or Rarotonga, had a new mast shipped up, and continued cruising.
Brent Swain is offline
post #4417 of 5317 Old 04-11-2014
scally wag
reconize this boat, i have always wanted to meet you, your boats rock brent
Brent Swain likes this.
post #4418 of 5317 Old 04-11-2014
scally wag
locally i see 3 of your boats within a 30 mile radius of victoria, im a big fan! sounding like a freak, but, i have sailed pearl song and she was awsome, although no motor was a downer in the gulf islands as you would know, i talked to a father and son on the main land some years ago, on pricing a pilot house 37, but they built your boats, tried and true!
The Following User Says Thank You to sonsunmandelin For This Useful Post:
Brent Swain (04-12-2014)
post #4419 of 5317 Old 04-11-2014
scally wag
lucky art! made it
post #4420 of 5317 Old 04-11-2014
scally wag
since, i am on a rampage i will note, that every swain owner i have met, witch is lots, all say the same thing "safe", i only have a columbia 36, right now, because of convenience according to my budget, or i would own the sailing submarine that will take me thru the arctic! but i could see, some people liking fb boats, for their speed in light winds, and probably will never even hit heavy winds, steel is not meant for fair weather
ok i am going to stop now
Closed Thread
Currently Active Users Viewing This Thread: 3 (0 members and 3 guests)
