Pros and cons of steel sailboats - Page 447 - SailNet Community
 1723Likes
post #4461 of 5317 Old 04-15-2014
djodenda's Avatar
Congratulations, Bob!
I like Marty's kids. They are an interesting bunch..
David
1987 CS 36 Merlin "Kyrie"
djodenda is offline
post #4462 of 5317 Old 04-15-2014
grumpy old man
Thanks Denda.
Life is thread drift.
Bob's Blog ....
bobperry is offline
post #4463 of 5317 Old 04-15-2014
shank32095's Avatar
Bob,
First congrats on the little guy! A while back you commented on obtaining stability calculations on my new boat Crusoe. I have been unable to contact the builder but maybe you can take a quick look at this informative piece I pulled up on the web on stability curves. Crusoe is 25 tonnes draws 3 meters and the keel ballast is 4.5 tonnes. Length 17 meters and the beam somewhat narrow at 4 meters. (A couple pics below). Question is where would you place the boat between the A to D per the article below.
Understanding monohull sailboat stability curves | M.B. Marsh Marine Design
Thanks as I am clueless to calculations such as this.
TS
shank32095 is offline
The Following User Says Thank You to shank32095 For This Useful Post:
Brent Swain (04-16-2014)
post #4464 of 5317 Old 04-15-2014
grumpy old man
Shank:
I can't connect to that link.
If you asked me to guess at your limit of positive stability I would guess that it is 123 degrees. That's a fine number. By the way, I am really good at guessing these numbers.
I'll see if I can connect to that link again.
Bob's Blog ....
bobperry is offline
post #4465 of 5317 Old 04-15-2014
shank32095's Avatar
Bob, Here it is again
post #4466 of 5317 Old 04-15-2014
grumpy old man
Shank:
That is a pretty generic article. It even refers to itself that way. Your CB boat doesn't fit any of those types. I'd stick with my guesstimate until you can get in touch with your designer. He really owes you that data. As a designer I have to provide technical backup up for my owners. I do it all the time. It's often a PITA but who else can they go to?
Bob's Blog ....
bobperry is offline
post #4467 of 5317 Old 04-15-2014
shank32095's Avatar
Bob, If you are able to pull up the article what was really interesting to me was the reply from Andrew Troup because Crusoe was designed to explore in Antarctic waters. The flat bottom portion of the hull was 25 mm. steel plate and with the keel up the idea was be able to sit on ice. Not my ideal use of ice but very interesting indeed.
post #4468 of 5317 Old 04-15-2014
grumpy old man
Shank:
That's 1" steel plate!
The biggest effect that would for your use is that it would put a lot of weight low to help your VCG.
I'll go back to the link and see if I can find that reply.
Ok I read that reply. Not sure I agree with all of it. But I agree and have for some time warned people of being too confident of static stability studies. They just don't have much in common with the real world conditions in which the boat would be subject to being rolled over.
As for pulling the CB up in survival conditions I have no experience with that so I can't comment. I understand the principle though and it sounds plausible. In your case raising the CB would not have the adverse affect, talked about in the link, of raising your VCG. That's a big plus for you. I don't know who this guy is but I did not read anything there I thought was "wrong". I like his dynamic approach to stability. On the face of it your boat has the best of both worlds.
Bob's Blog ....
bobperry is offline
post #4469 of 5317 Old 04-15-2014
shank32095's Avatar
Thanks Bob, Coming from you that means something. I am a very cautious sailor and with my wife and sons on board limiting any room for error is the deal.
post #4470 of 5317 Old 04-15-2014
grumpy old man
You are welcome Shank. It's only my opinion but I have been thinking about these things really hard for a long time.
Bob's Blog ....
bobperry is offline
Closed Thread
