Pros and cons of steel sailboats - Page 45 - SailNet Community
 1723Likes
post #441 of 5317 Old 08-07-2013
Jeff:
Funny Tripp story.
When I went to work at Carter's I called K. Aage Nielsen. I loved his work and I wanted to meet him. I asked him if I could come to the office. He said something like "only if you plan on spending money". I never called him back. Bill Garden was very generous with his time when I was a kid. He could have blown me off but he was patient with me. Whenever a kid calls me and wants to visit I remember the way Bill treated me and I respond the best I can the same way.
My friend Nathan, started Valiant, made an appointment to meet L. Francis. He arrived at the Castle one snowy night, having driven from New York, and knocked on the door. The famous "housekeeper" opened the door, looked at Nathan, made some comment about his long hair and sent him packing.
Long after the money has been spent , the satisfaction of having helped someone fulfill their dreams remains. Making money less relevant in one's life, enables one to do that far more often, without regard for money. Concentrate on helping people realize their dreams, and the money will take care of itself.
Some get it; some don't. The former are much happier people.
Celebrate the successes of others as your own ,and you are always winning.
Brent Swain is offline
post #442 of 5317 Old 08-07-2013
Originally Posted by Jeff_H View Post
Mark,
I'm not sure that Brent's math is as wrong as you may be suggesting. My assumption is that Brent is using something like an A572 which is a high-strength low alloy steel which has better corrosion properties and more strength than A36 which you mentioned, and which has a tensile yield strength in the 60,000 psi range.
Brent said,"That is 11,250 lbs per linear inch for 3/16th plate. Multiply that by the 96 inches in the side of one of my twin keels." And in that regard, something like A572-60 that was 3/16 thick would have a tensile yield strength around 11,250 lbs per linear inch. (60,000*3/16= 11,250) His arithmetic is essentually correct.
The problem is one of how the is applying that math relative to proper engineering principles contained in Brent's metaphoric description of:
"That is 1.08 million pounds per side, times four keels sides.
How are you going to break that with a boat under 20,000 lbs?"
This metaphor assumes that the loads are shared by both keels equally and that the loads are solely in tension. Neither is likely to be present or likely to relate to the actual failure mode of the keel.
The more probable failure modes for a frameless keel connection would more likely be some mix of buckling of the keel sides in compression (skinny column failure), sheer where the keel sides try to cut through the hull plate (as you noted in your comments), or bending of the hull skin perhaps coupled with lamellar tearing near where the hull meets the keel since the hull plate would be in bending due to the large lever arm formed by the depth of the keel and the narrower width of the keel root being resisted in bending by comparably thin plate.
But beyond that I also want to touch on Brent's Herreshoff reference.
I am not sure that its clear which Herreshoff Brent is referring to, but by and large all of the Herreshoffs were consumate engineers. Nat Herreshoff and Herreshoff Manufacturing developed their own formulas for many of the calculations involved in properly engineering a boat. At a time when boats were 'engineered' by rules of thumb, Nat did his own scientific research and developed his own formulas based on his research. And he used these formulas to design some of the most sohisticatedly engineered designs in that era. He later boiled those down into his own set of widely used rules of thumb, but these were heavily based on proper engineering based methodologies.
L. Francis began his carreer working with Nat as a designer at Herreshoff Manufacturing but did the majority of his apprenticeship working beside Starling Burgess and Frank Payne at Burgess, Swasey & Paine in Boston. Burgess was one of the most creative, multi-discipline, engineering-oriented designer/ inventors of his day. Burgess was a brilliant mathematician who was able to do high level scientific research, then develop mathematic equations to explain the observations and ultimately literally wrote the book on a wide range of early 20th aeronautical engineering applications.
In yacht design, Burgess literally developed sophisticated formulas that replaced the crude rules of thumb which preceeded his time. Starling Burgess working with Glenn Curtiss was key to the design of the first successful seaplane (only a few years after the Wright Bros first flight), he designed three America's Cup winning defenders, he designed the first successful aluminum masts, he designed many of Buckminster Fuller's so called Dymaxion inventions (car and house being most notable), (and designed 'Little Dipper' for Bucky, one of the most beautiful little cutters of all time), as a kid in the late 1800's he designed one of the first light weight machine guns, he also is thought to have possibly/probably designed the Times New Roman font, wrote poetry, and novels, and produced world class paintings.
And L. Francis learned his trade at Starling's side and along side of Frank Payne as well. And Frank Payne was no slouch either when it came to sophisticated engineering. There was nothing even slightly shoddy about L. Francis's math or engineering skills.
But of all the Herreshoffs', L. Francis would be the only one that I could imagine who might write negative comments about using engineering formulas. I can imagine that since L. Francis was known for writing things that he thought sounded good and doing just the opposite. (Like advising adult sailors that they had an obligation to take children sailing and teach them the ways of the sea, when L. Francis notoriously hated kids and hated being around them.) So, if L. Francis was dismissive of the crude formulae of the day, it was only because he and his close life long friends, Starling and Frank, were beyond the quick and dirty engineering methods that he decried.
Sidney Dewolf Herreshoff was a graduate from MIT in engineering. 'nuf said. He used the numbers. Halsey Herrshoff has an undergraduate degree from Webb Instutute and a masters from MIT, I have to figure that he uses the numbers as well.
Please, lets try to keep the historic references close to what is actually known about these people.
1.08 million pounds per side, times two, means 3.6 million pounds per keel, if you only hit one keel at a time. Sheer and tensile are the same at that point, as you are not talking about a sharp edge. Still not wooden boat numbers, nor plastic boat numbers. To buckle, plate has to buckles both ways, inward and outward . Kind of hard to for it to buckle inwards, if they have 4500 lbs of lead cast inside.
How do my 4 lengths of 3 by 3 by 1/2 inch angles across the tops of the keels, slotted and fully welded into them , let the plate take all the flexing?
How does running the 3/16th water tank top, fully welded in against the inside edge of the keel, a fully welded steel longitudinal bulkhead, a triangular shape, let the hull plate take all the flexing, when it gives you three curved, fully welded edges of steel coming together ? How do they allow the hull plate to bend at that point, like a simple flat piece of steel, when they are far more structurally complex?
I think the biggest problem some have in comprehending steel hull shapes and their structural factors, is they are incapable of seeing structural loads in three dimensions. They only look at a cross section in two dimensions, and make their conclusions on that basis. That is why some put a longitudinal right next to a cabin side, which is a super strong longitudinal in itself , then put a series of gussets along the sheer, when such an I beam structural equivalent needs only two supports anywhere along its length; any more being structurally irrelevant. That is why they suggest longitudinal stiffeners along the keel side, when the keel itself is the structural equivalent of a fully welded longitudinal steel 1/4 inch plate bulkhead.
Where they get really loonie tune, is when they talk about hogging and sagging in a 36 foot steel boat, which would take 12 1/2 feet of 1/8th inch deck and cabin side plate to stretch longitudinally, or more than 10 feet of 3/16th hull plate to stretch longitudinally . Racers have shortened the waterline of plastic racing boats for measuring, by putting a hydraulic backstay tensioner on and jacking it up til the boat bows and sags considerably, shortening the waterline considerably. When I tried to take some twist out of an origami 36 ft hull, by a 3 ton come along from the top corner of the transom to the opposite chine, I broke handle off the come along without changing it a 16th of an inch. The hydraulic back stay tensioner would break the back stay before shortening the waterline 1/16th of an inch. Implying that transverse frames will stop hogging and sagging is like saying that transverse frames will stop a camera bellows from lengthening or shortening, or sagging. You couldn't ask for a clearer demonstration of a complete inability to see reality in three dimensions.
As for L Francis Hereshoff, I suggest you read his book "The Common Sense of Yacht Design," in which he ridicules mathematical exhibitionists.
As he points out , if you add up the areas of sections in sq feet, and multiply it by the space between them, you get your displacement in cubic feet. Multiply this by the number of pounds of water per cubic ft and you have your displacement , exhibitionists Simpson's multipliers be damned. Compare this with a figure acquired by multiplying the area of your midships section by your waterline length, and you have your prismatic coeficient .
Its that simple , to the consternation of exhibitionists!
post #443 of 5317 Old 08-07-2013
So, wait, if I add up the lineal inches for every Brent boat that's ever been built, isn't that, like, in the billions?
Dang. Those are some strong boats.
Compare it to the number of copper fastenings holding a woodie together, or the frozen snot holding a glass boat together, and yes, it is super strong.
You are finally beginning to get it ! Congratulations!
post #444 of 5317 Old 08-07-2013
Originally Posted by mark2gmtrans View Post
Okay, let's address the math here....
First we need know that to figure the force of the impact, we are going to have to calculate the Impulse of Force, which is the force of the impact in PSI in this case over the period (length of time) of the impact. In order to know the force we have to know the weight, the speed and the size of the impact point, and to get the Impulse on that we need to know the duration.
From there it is a simple little calculus problem, and we can get it all done in just a few minutes. So, we figure that the length of one of Brent's keels is about 60 inches long by 6 inches wide at the point of contact. ( I tried to look up some of Brent's designs on sailboatdata.com like I do with Bob's or Roger Long's but I found this photo, and I am just kind of guessing on the actual length, at the end of the story it won't matter.
So we have a weight (per Brent) of 20,000 lbs
A hull impact area of 360 square inches maximum.
We will designate a forward hull speed of 10 knots which is 26.465 per sec
A downward force of 954417 N on the keel, and that is not a full calculation, but there are too few here who would understand the math to make it worth the effort.
So that translates to 214561.47 PSI
Score Fukushima Debris Field 1 BS hull Zero
In other words a full on 10 knot collision would poke a hole in your boat, and that force is the force that would occur along the entire 360 square inches, angle it slightly and it goes way up. I know my math is dirty on this because the formula I used was not the full formula, which gets to be fairly complex because I would have to estimate too many of the numbers. I used
Impact Force(F): 2 m vt
Which is really too simple. The actual formula for calculating keel impact force is longer and more complicated and I would have to calculate too much stuff after a very long day at work.
However for those interested the whole formula is here....
Guide Specifications and Commentary for Vessel Collision Design of Highway ... - Aashto - Google Books
There is a far simpler formula. Steel origami boat T- bones steel barge at hull speed . Zero damage. Steel origami boat pounds for 16 days in 8 to 12 ft surf with zero damage . Steel origami boat pounds across 300 yards of Fijian coral reef and is pulled off thru similar surf . Zero damage . Steel origami boat goes thru NW passage in one summer .Zero damage . Steel origami boat pounds thru a quarter mile of five inch ice . Zero damage.
Fiberglass boat pounds in surf . Demolished in minutes. Results conclusive.
Plastic boat T- bones Lasqueti Island, while the skipper tries out new autopilot and new girlfriend simultaneously . 14 feet of boat demolished. Skipper never lives it down.
Ego demolished.
No mathematical exhibitionism ( or fantasy) necessary!
post #445 of 5317 Old 08-07-2013
grumpy old man
So much BS, BS, BS. You'd think he has nothing better to do than type.
I went tri sailing today with my buddy Doug. The tri is an F28R with an F31 rig. This is the boat that won the Race to the Straits overall this year. We reached at over 14 knots and beat up Port Susan at up to 9.3 knots. I had a ball. It's a far cry from the BS here.
We stopped at Langley for lunch. I saw a really ugly boat with a PH in the marina. It reminded me of ,,,,but no.
BS you react like a cornered animal. You project your weaknesses. Why so defensive? Be proud of those boats you create and respect the preferences of others. That's a simple way to approach life in general. I'm not a trimaran kind of guy but I had a blast today. I could easily get used to those speeds.
Bob's Blog ....
bobperry is offline
post #446 of 5317 Old 08-07-2013
grumpy old man
Here's another shot showing just how terrified Doug and I were sailing a grp production boat in salmon infested waters. Obviosly neither of us was having a good time. We spent our time pondering the great depths of why one man should impose his way of thinking on other people. We quit that after 3 minutes and just enjoyed the sail. I am happy to say we made it home safely. In fact, after Doug dropped me off at my Walker Bay hanging on my mooring he went back out by himself. The last I saw of him he had a big JUICE PLUS asym up and was rocketing down the bay. Flirting with certain death I suppose. Probably went looking for things to bash into.
Bob's Blog ....
bobperry is offline
post #447 of 5317 Old 08-07-2013
The Elephant
smackdaddy's Avatar
So what you're saying is when I start saying absolutely insane things...in your mind, I'm "beginning to get it".
Okay. Makes sense.
smackdaddy is online now
post #448 of 5317 Old 08-07-2013
The Elephant
smackdaddy's Avatar
Brent, this is the best advice you'll ever receive in your life. If you don't take it, you're a fool - and will simply continue to destroy what's left of your legacy.
bubb2 likes this.
post #449 of 5317 Old 08-07-2013
sailing soon
mark2gmtrans's Avatar
Send a message via Yahoo to mark2gmtrans
Brent,
I know you are severely challenged on the math because you just cannot in good conscious be saying that I could exert three million pounds of force on one of your thin skinned little boats and not squish it flat, much less thinking that I could give your hull a three million pound impact and not send the thing to the moon with a GIANT GAPING HOLE IN IT.
Exert a three million PSI impact on the keel and it would probably exit the hull through the deck and land somewhere on Mars.
But, I am happy if you are happy, so if you have people buying your BS boats then go forth be fruitful and multiply.
It is good to learn from your mistakes, but much better to learn from the mistakes of others...
mark2gmtrans is offline
post #450 of 5317 Old 08-07-2013
Any day sailing is always a good day!. I went out today to.On an Islander 36 I have been doing alot of work on.Had a blast.Missed the Louis Viton Race but saw the Oracle cats practicing.I am jealous Bob, you seem to have sunshine where you are at.It was a typical San Francisco summer day here,overcast,about 65,15 - 18 knots.Luckily we were able to avoid hitting any Salmon to.Had a tense moment after getting in, We thought a Night Heron was going to land at the masthead,Phew! he flew by.Close call
jak3b is offline
Closed Thread
Currently Active Users Viewing This Thread: 11 (0 members and 11 guests)
