Pros and cons of steel sailboats - Page 82 - SailNet Community
 1723Likes
post #811 of 5317 Old 09-01-2013
Originally Posted by outbound View Post
Would seem this line of thinking would also apply to other materials not just steel. Even a glass boat when hit in a manner that the force was oblique to the plane of the hull would be stronger. It would be weakest if struck perpendicular to the hull. Increased curvature would also decrease likelihood of "oilcanning". Would think this improvement would be more likely to occur in a fully developed hull with compound curves than a chined hull or hull with simple curves. Would think having a fine bow would likely also increase strength in context of impact . Speaks well for the Sliver.
Still remember earlier post about hitting the corner of a container at hull speed. That remains my nightmare so think having a forward collusion bulkhead makes sense.
Yes, more compound curves definitely make any hull stronger, but hard chine steel hulks are so overstrength that it would not be worth the huge increase in time and expense for something so irrelevant. Most round bilged steel hulls use a lot of filler , eliminating one of the advantages of a steel hull in the first place , care free cruising. You don't want to chip the bondo.
Yes, fibreglass hulls benefit greatly by their compound curves, and flat surfaces on fibreglass hulls, without additional stiffening, should be viewed with suspicion.
Any designer working in a heavy material should, before adding unnecessary parts, look for some other part or feature which will be serving the same function.
Few designers have anything to offer, to deal with biggest hurdles most wanna be cruises face , time and money.
In fact, all too often, their response to such issues is often ridicule and obstructionist disinformation. Unless one has unlimited funds, they would be wise to steer clear of such designers, and their "advice".
Brent Swain is offline
post #812 of 5317 Old 09-01-2013
Senior Moment Member
SloopJonB's Avatar
I would suggest the same applies to builders. If a person wants to go cruising but has limited time & money, their best course of action by far is to buy an existing boat and prep it to suit.
No-one can build a boat remotely as cheaply as something similar can be bought used.
I speak from experience.
SloopJonB is offline
post #813 of 5317 Old 09-01-2013
Finally! I found those pics of the $2 blocks Brent was talking about:
I assume these are from his own boat - which starts to give some small indication of its condition. I guess we all have different measures of "perfection".
As you can see, they are in perfect condition, with zero wear or corrosion after 29 years , and many Pacific crossings. If you want "shiny" you can do it in minutes with a brillo pad on a grinder. That has never been a priority for me. I prefer to concentrate on structurally and functionally sound. I have no interest in impressing anyone but the practical.
Thanks for posting these Smack. They make my point.
post #814 of 5317 Old 09-01-2013
Here is a cute photo of the Sliver keel.
Holy crap! That's huge!
Or is she 18" tall?
smackdaddy is offline
post #815 of 5317 Old 09-01-2013
No worries, Swaindaddy. Actually, I think what this shows more than anything is your definition of "perfection". It's much, much narrower than the typical interpretation of what most would even remotely consider "perfect". So this was a very good exercise. Now the 99%-er can have a clear illustration of what you mean by "the perfect yacht": a floating tractor.
How about some more photos of your boat so we can see more perfection?
Just to be clear, I only ridicule and obstruct disingenuous knuckleheads. And I have unlimited funds to do so.
post #816 of 5317 Old 09-01-2013
Or is she 18" tall?
Kerry is 5'5", the keel is about 9' (The boat draws 10')
(I am working on my required 10 posts, only 8 to go, then I will go back to lurking.)
kimbottles is offline
post #817 of 5317 Old 09-01-2013
tdw
Super Fuzzy Moderator
tdw's Avatar
Welcome Kim B. Nice to see your name pop up.
Andrew B (Malö 39 Classic)
― Terry Pratchett.
tdw is offline
post #818 of 5317 Old 09-01-2013
I CAN'T WAIT to see thing thing sailing!
post #819 of 5317 Old 09-02-2013
grumpy old man
Excuse me but Kerry is 3" tall.
Bob's Blog ....
bobperry is offline
post #820 of 5317 Old 09-02-2013
blt2ski's Avatar
Me thinks I am glad I am on the wrong side of the pond, relaxing on my eetsy bitsy boat, with mr winston and spouse, homefully sailing back tomorrow.
Marty
She drives me boat,
I drives me dinghy!
blt2ski is offline
Closed Thread
