Like Tree20Likes
  #51
Old 12-09-2012
L124C's Avatar
L124C is on a distinguished road
Story of my life...It's too big!
Asked the seller why he went with a 20hp motor. He replied that he bought a 27 but it "wouldn't fit in the hull" so they went with the 20. Hard to believe that with all this space (gotta love the access!) they couldn't make a 27 fit.
He claims 20hp is plenty, especially since it's a diesel (there is that diesel vs. gas hp thing again). Yet, he also said he didn't think he was using the extra hp with the A4 anyway. Not that it matters, she's got 20hp and that's that. But it does throw the credibility of the claim that 20's plenty into question.
Would have made more sense if he said, "We never used all the power from the A4, so we decided on 20hp for the refit.
Conditions could be benign during a sea trial and it might be hard to determine if she's under powered.
You guys buying the "wouldn't fit" excuse?
Edit: After I posted this, I decided to post the same question in the diesel forum.
Could 27 hp fit here?
  #52
Old 12-09-2012
brob76 is on a distinguished road
Re: Looking at a Alberg 35
The 27 would definitely fit. That's the same engine I have in Auriga. Beta and Universal both use the Kubota D1005. I have plenty of space in the engine room to work. From the picture it looks like they kept the original engine beds and put some aluminum bar to accommodate the extra width of the mounts. It would have been much better to cut out the engine beds and glass in new beds the proper width. Looks like the aluminum is lag bolted to the engine beds which is not a good idea either. Would have been better to through-bolt steel angle or something of the sort. I doubt shaft length was an issue as someone suggested on the diesel forum. Looks like there is room to move the mounts fore or aft on those aluminum plates. That was probably the largest engine they could get on those original beds. I've seen an A35 with a 35 hp engine so engine room space is not the issue.
L124C likes this.
  #53
Old 12-09-2012
smurphny's Avatar
Over Hill Sailing Club
smurphny is on a distinguished road
There is room for a much larger engine but the old engine mounts need to be cut away and new, wider mounts glassed in. It's a pretty big job. That's probably why they went with a smaller engine. Kinda like the tail wagging the dog
L124C likes this.
  #54
Old 01-02-2013
L124C's Avatar
Noticed that the shower drain on the boat in the OP simply terminates under the shower pan as the photo shows. In the boats drawings, I see that it is supposed to drain to a sump. I guess that as shown in the picture, the water simply runs around the water storage tank, to the bilge.
I assume the seller was not using the shower, especially given the fact he has not seen fit to even install a auto bilge pump in the boat!
In any case, were did the original sump drain, and is it necessary?
  #55
Old 01-02-2013
smurphny's Avatar
Mine's the same way. There was what looked like the remnants of a shower sump pump down there but it's so inaccessible that it's just not a good place for one there under the shower base. Mine is piped w/ 1-1/2" right to the bilge next to the bilge pump. Works fine. If there were a bunch of people using it on a regular basis, it would probably need some sort of screen.
You may post attachments
You may edit your posts
Alberg 37 captainkip Alberg 9 12-27-2012 04:47 PM
Alberg 35 Advocate777 General Discussion (sailing related) 5 11-29-2012 05:07 PM
Alberg 22 akoroves Boat Reviews 19 01-19-2011 02:50 PM
Alberg 29 ianhoar Boat Reviews 6 11-15-2010 08:56 PM
When Is An Alberg Not An Alberg? TSteele65 General Discussion (sailing related) 3 09-21-2007 12:46 AM
SEO by vBSEO 3.6.1
