Interior Wall near the CB rotting - SailNet Community
post #1 of 3 Old 12-11-2012 Thread Starter
Exclamation Interior Wall near the CB rotting
I'm interested in a Neptune 24. The boat seems run down. This is the CB version of a 1981 Neptune 24. The interior cabinetry and wall near the CB is rotting. It seems to come from the deck (near the mast electrical cable boot) but not sure. Is it easy to change the interior walls or is this considered structural and should be done by professionals?
I'm more of a handyman and less of a sailor... but not afraid to dig in and try.
Thanks
davidsmcse is offline
post #2 of 3 Old 12-12-2012
Tartan 27' owner
CalebD's Avatar
Re: Interior Wall near the CB rotting
NEPTUNE 24 CB sailboat specifications and details on sailboatdata.com
I am not familiar with this model/make but chances are that an interior wall would be load bearing or structural. I would not say that changing the interior wall is easy but I doubt you would want to pay a "professional" to do it for you. A little carpentry, a little epoxy/fiberglass work and a good bit of research on your part should get the job done.
Make sure that the center board (CB) trunk is not in danger of leaking or rotting.
Everybody has one:
CalebD is offline
post #3 of 3 Old 12-13-2012
At epoxyworks.com find and read the article on "Replacing damaged bulkheads". With that information in mind you'll be able to assess whether this something you want to undertake.
Hudsonian is offline
Tags
neptune , repair , rotting , structural , wall
Off The Wall, Sea berth ? DulceSuerna General Discussion (sailing related) 11 01-20-2011 01:52 AM
Wall covering petergumbrell Gear & Maintenance 5 03-24-2008 10:41 PM
Rotting Bulkhead - AGGGHHHH Finallybuyingaboat Gear & Maintenance 28 11-05-2007 10:08 AM
