Small main sail, large jib - questions - Page 6 - SailNet Community
 2Likes
post #51 of 59 Old 12-26-2012 Thread Starter
Re: Small main sail, large jib - questions
I guess I could do it whilst hove to.....
let the main sheet out when I drop the jib halyard so I won't start spinning like crazy...
matthewwhill is offline
post #52 of 59 Old 12-26-2012
Remember you're a womble
PaulinVictoria's Avatar
Do you actually thread the downhaul through the hank hardware itself, or just weave it back and forth around the hands between the headstay and the luff of the sail?
I have a loop that the next to top hank goes through (so it doesn't pull down on the top hank, likely to jam up if you do that), and then it just weaves back and forth between the forestay and luff. My line doesn't fit through the hanks, and if it did, I think it would introduce too much friction anyway.
Orange Crush
1974 C&C27 MkII
PaulinVictoria is offline
post #53 of 59 Old 12-27-2012 Thread Starter
Update
Haven't rigged the jib downhaul yet, but went out today with 150 in light winds.
Close hauled, trimmed the jib sheet tight, head to wind, jib backwinded, released the halyard and the whole thing dropped right down on the fore-deck and along the side between the shrouds and the lifelines.
I swear it almost flaked itself!
Very sweet. I don't think it will be as easy during stronger winds though.
Next question: I like my autotiller, but its a bit cumbersome. As a simple short term alternative does anyone set up a couple bungee cords?
post #54 of 59 Old 12-27-2012
Correct, it won't be quite as easy, and you'll appreciate the downhaul
I have a tiller tamer, Tiller-Tamer by Davis, does what it says on the tin.
Orange Crush
1974 C&C27 MkII
post #55 of 59 Old 12-28-2012
blt2ski's Avatar
Tiller tamer is not too bad. On the other hand, if your boat is like mine.....as soon as I getting going straight, I mover forward, or to the other side, the boat does not go straight any more, as it is not in balance from when I set the lines.....BUT, it does have a place.
Marty
She drives me boat,
I drives me dinghy!
blt2ski is offline
post #56 of 59 Old 12-28-2012
Re: Update
In strong winds the forces can tend to partially raise the sail which would fight the downhaul.. in that case try DDW, sheet in hard in the lee of the main, you'll find the sail readily drops because the wind wants to aid the drop, the backwind should allow most of the sail to land on deck.
Faster is offline
post #57 of 59 Old 12-28-2012
no longer reading SailNet
Alex W's Avatar
Davis Tiller Tamer works nicely. I often ran it with a little friction so that I could let go for a little bit without issue and without having to constantly adjust it.
Alex W is offline
post #58 of 59 Old 12-28-2012 Thread Starter
Why does it head to wind well?
Another stupid question:
How can a boat with massive headsails and small mainsail perform well close hauled? Doesn't the big headsail cause lee helm? Why doesn't the smaller mainsail cause not enough weather helm?
post #59 of 59 Old 12-28-2012
Moderator
Jeff_H's Avatar
The reason that boats with massive headsails do not develop massive lee helm is that typically a boat with that rig proportion was designed to balance with these sails in place.
Although seemingly counter intuitive, the other part of this equation that is often overlooked is that the larger the leech of the sail, the more the center of effort is moving aft. So it is that putting up a larger overlapping genoa can add to weather helm rather than reduce it.
Jeff_H is offline
small large larger captdavi Introduce Yourself 0 06-06-2011 10:39 AM
Loose luff on main sail questions MarkSF Seamanship & Navigation 16 05-08-2011 09:35 PM
propellers - large or small? anderbra Gear & Maintenance 3 08-14-2008 05:45 PM
Large Head Sail vs Jib and Main JasonEliasMackentyre General Discussion (sailing related) 4 08-14-2006 10:41 AM
large main or large headsail? jbarros Boat Review and Purchase Forum 2 09-29-2003 06:13 PM
