Rethinking inboard - Page 2 - SailNet Community
 6Likes
post #11 of 14 Old 01-09-2013
Chastened
Ajax_MD's Avatar
Re: Rethinking inboard
The Coronado 25 and 27 have outboard engine wells.
My first boat was a Coronado 25, with a Honda 9.9 4-stroke longshaft installed. I sailed in very choppy weather and NEVER had a problem with cavitation. The boat also backed and handled well.
The Honda 9.9 4-stroke had a huge powerhead though, and I couldn't lock the engine in the full "up" position with the engine's plastic dome installed.
I wouldn't let this deter you though. Other manufacturers' 4-strokes seem to have smaller powerheads and 2-stroke engines are still out there.
I agree-
If you insist on having an outboard-powered boat, I wouldn't go with a transom mounted outboard, I'd look for a boat with an engine well.
However, I also agree that if you had a heavy engine smell, the engine either needed maintenance or fuel was spilled somewhere. Personally, I did have some trepidation about buying an inboard-powered boat, but I'm ok with it because I have excellent access to my engine, so maintenance isn't a terrible chore. Some boats have terrible access to the inboard, which can really sour you on larger boat ownership.
Some examples of good inboard engine access are the Tartan 30, Pearson 30 and certain build numbers of the Catalina 30. In the case of the C-30, so many have been built, and the furniture re-arranged, that engine access is not equal in all C-30's.
1981 Tartan 33 #168
Ajax_MD is offline
post #12 of 14 Old 01-09-2013
chef2sail's Avatar
Agree with most here. Diesel is the way to go. Clean up the engine area. Look for leakage of diesel fuel. Make sure the exhaust has no pin holes.
Gas engine prop will always sit higher than a prop under the boat and will be more suseptable to cavitaion easpecially in any kind of even moderate sea state.
Sa is also inherently more dangerous than diesel with fumes also. Given the use of ethanol in gas now, I would recommend strongly the diesel fix.
Dave
___________________________
C&C 35 MKIII Hull # 76
Parkville, Maryland
(photos by Joe McCary)
Our blog-
chef2sail is offline
post #13 of 14 Old 01-09-2013
denverd0n's Avatar
Just wanted to say "ditto."
If you keep your engine clean and fix leaks as they occur, you will not have any noticeable smells from an inboard diesel installation.
The unfortunate fact is that far too many boat owners do NOT keep their engines clean, and do NOT fix small leaks. That is the only reason that you smell diesel on so many sailboats.
denverd0n is offline
post #14 of 14 Old 01-09-2013
Lake Superior Sailor's Avatar
Some Cal 28s were made with outboard wells .........Well thank God and Jensen, mine has an inboard!......Dale
Reluctant Lady
Cal 28, 1967
Lake Superior
Where God got it done!
Lake Superior Sailor is offline
2 stroke inboard PeterSailer General Discussion (sailing related) 26 11-21-2013 12:47 PM
Newport 27 w/o inboard WheresTheLeak Boat Review and Purchase Forum 0 05-11-2010 01:44 PM
Ascaird of my first Inboard mattstamour Introduce Yourself 3 02-11-2009 09:01 PM
Outboard or inboard? ImASonOfaSailor Boat Review and Purchase Forum 12 03-06-2008 09:16 PM
Rethinking Sinking David Schaefer Seamanship Articles 0 08-03-2004 09:00 PM
