Rethinking inboard - SailNet Community
 6Likes
post #1 of 14 Old 01-08-2013 Thread Starter
rbyham's Avatar
Rethinking inboard
We were on two boats today. Both had inboard diesels. One a yanmar one a westerbeke. Both in 27-28 foot range. Plenty of room below but... the smell was heavy of engine in both regards. To this point I have been committed to an inboard diesel for Charleston waters. Now not so sure. I would not want an outboard hanging off the back for many reasons. But I saw a Cape dory online tonight with a built-in outboard well in rear lazarette. This is starting to look like a good option. The well reduces or even alleviates cavitation problems. That and the sound reduction of a closed lid and affordability of outboard maintenance really has me wondering. Beyond the Dory are there other boats out there in excess of 25 feet with a built in well? I see James Baldwin modifying Alberg 30s to use a well... but are there other options? Thanks.
rbyham is offline
post #2 of 14 Old 01-08-2013
steve77's Avatar
Re: Rethinking inboard
A friend of mine did that with his Bristol 27. You lose some room from the rear lazarette but otherwise seemed like a nice solution.
steve77 is offline
post #3 of 14 Old 01-08-2013
There are several issues with well mounted outboards.. most are surmountable if you really want it...
The prop is still further aft and higher than an inboard install so while better than a transom outboard it's not 'the answer' to cavitation in waves.
Many well installs preclude steering the outboard, and if the well is aft of the rudder you lose a lot of maneuverability because you can't 'redirect' the propwash with the rudder.
Side mounted wells can sometimes interfere with full rudder travel, with obvious consequences (T Birds had to put limiting strops on tillers while motoring to prevent rudder from hitting the spinning prop)
To make it quiet, you need to close the hatch.. as you power ahead the stern wave can 'seal' the well, and some engines will actually run out of air.. so now you need to crack the hatch (so much for quiet) or you need to arrange alternate venting/air supply.
Many well designs preclude easily lifting the engine up while sailing, with it's attendant drag. The T-Bird 26 did allow this and even had a drop-in cover plate, but I wouldn't say it was easy to use. But in many cases lifting the engine clear doesn't happen (The Flying Tiger has a clever solution to this problem, and it's under the bridge deck so more or less equivalent to inboard)
I've seen some wells (Columbia 26 IIRC) that were right in the cockpit... noisy, splashy, smelly....
The biggest plus is that it gets rid of the unsightly outboard and bracket on the transom We owned a Viking 28, a very pretty C&C design, originally fitted with a lazarette well that had been removed and a bracket added.. I always hated the way the motor 'ruined' the lines.. great boat otherwise though.
So just some food for thought... btw with a good engine installation coupled with good maintenance there should be no significant fuel/engine odours below...
jrd22 and barefootnavigator like this.
Faster is online now
The Following User Says Thank You to Faster For This Useful Post:
mf70 (07-09-2015)
post #4 of 14 Old 01-08-2013
Sabreman's Avatar
Having owned diesels and worked on them for over 30 years, my opinion is that they are far more reliable than outboards. Maintenance is simple and takes me about 2-3 hours a year. You can easily clean up a diesel and get rid of that oily smell. I suspect that the owner spilled fuel or oil.
IMO, outboards in a well do not work well (pun intended). As Faster says, they are too high and cavitate. That results in overheating and loss of power in a seaway. My father had an outboard in a Catalina 27 and it was a real mess in the Great Egg Harbor inlet; he got rid of the boat after 3 years. I worked for a boatyard that even installed a diesel in another Catalina 27 and got rid of the outboard. IMO, outboards for this size boat should be relegated to a racing sled.
chef2sail likes this.
Sabre 38 "Victoria"
Sabreman is offline
post #5 of 14 Old 01-08-2013
Old enough to know better
Some wells are quite small so cannot accept 4 stroke outboards so you are limited to older outboards.
Sent from my ADR6425LVW using Tapatalk 2
1976 C&C 33
Project boat, lots of work to be done!
miatapaul is offline
post #6 of 14 Old 01-09-2013
no longer reading SailNet
Alex W's Avatar
A local sailor with a Cape Dory 25 has complained that the well plus having the outboard behind the rudder makes the boat very hard to steer under motor power, especially at low speeds. Another friend with a Columbia 22 that has a well mounted inboard finds the whole thing very loud compared to transom mounted ones.
I had a transom mounted outboard with a 25" long shaft on a Catalina 25 and didn't have problems with prop cavitation even in 3 to 4' waves. I do know that this becomes a problem quickly as the boat gets any longer. I did like being able to steer with the outboard in tight quarters.
An inboard is nicer if you'll be using the boat a lot since it is quieter, has better fuel economy, and is easy to maintain. An outboard is nicer if you are on a tight budget because they are cheap to replace, don't require expensive props to avoid drag while under sail, and don't add a stuffing box and a couple of extra through hulls to the boat.
My Pearson 28-2 has a Yanmar 2GM20F with no smells. Having a diesel inboard doesn't mean that there should be a strong oil or diesel smell.
wdwright1967 likes this.
Alex W is offline
post #7 of 14 Old 01-09-2013
Senior Moment Member
SloopJonB's Avatar
Nothing beats a diesel inboard. If you smell engine or fuel you have a problem.
Outboards, especially 4 strokes will do for leaving & entering harbour but if you have any distance to go under power they suck big time, especially is there is any sea running. They also use a lot more fossilized liquids.
bljones likes this.
SloopJonB is offline
post #8 of 14 Old 01-09-2013
Ok, here's one that is sure to flop.
Put in a new Atomic 4 from Moyer Marine! Perfect size for boats in this range, benefits of inboard, no smell.
Really, I'm serious. I hate the smell of diesel and prefer the performance of an inboard.
Skywalker
T27 249
1966 Atomic 4 running lie a top.
SkywalkerII is offline
post #9 of 14 Old 01-09-2013
chucklesR's Avatar
If you have diesel smell you have a dirty engine.
There is no way I'd go with a outboard over a inboard on any sailboat that is being used as more than a over nighter.
I've ridden quiet a few 24-28 footers with outboards, that well is NOT quiet and usually needs to be open to both cool and provide air.
I've got a buddy with a Bristol 24 - he went through heck finding a motor large enough to push him, small enough to fit.
bljones likes this.
chucklesR is offline
post #10 of 14 Old 01-09-2013
Senior Smart Aleck
jameswilson29's Avatar
Pearson 26, great starter boat!
jameswilson29 is offline
2 stroke inboard PeterSailer General Discussion (sailing related) 26 11-21-2013 11:47 AM
Newport 27 w/o inboard WheresTheLeak Boat Review and Purchase Forum 0 05-11-2010 12:44 PM
Ascaird of my first Inboard mattstamour Introduce Yourself 3 02-11-2009 08:01 PM
Outboard or inboard? ImASonOfaSailor Boat Review and Purchase Forum 12 03-06-2008 08:16 PM
Rethinking Sinking David Schaefer Seamanship Articles 0 08-03-2004 08:00 PM
