01-26-2013
Warm Weather Sailor
Re: Purchase Advice for ICW, Bahamas, Carribbean
Originally Posted by Telesailor
Thanks everyone. I guess I am back to the age old question of a full keel boat (like an IP) with a protected skeg hung rudder which I am assuming would be better in the shallow water environment of the Bahamas, vs. a modern wing keel design with a spade rudder. It seems that most folks agree that the build quality of an IP is better than a Catalina or similar, but then for my budget $125,000 total (boat & upgrades/repairs) is it better for original "build quality" but a slightly older boat or a newer boat hopefully with less repairs required?
Why would a full keel boat be better in a shallow water environment?? The two boats I've sailed in the Bahamas, one (CS36M) had a wing keel (patented Hydrokeel 1988 from the days when wings were really wings) and my Beneteau has a shoal draft keel with a sort of bulb on the bottom. No problem with either. If you're thinking that a full keel will better protect the rudder, yes, but that's only if you run aground blindly going full tilt. Most groundings happen slowly as a prudent sailor slows down in shoal water.
As for build quality, most boats eventually have problems that are peculiar to that make. IP's have holding tank problems. Endeavors have ports that leak. These are a couple of examples. I would buy the newest boat I could for the price, preferably a boat that's been cruised recently as it will most likely be better equipped for cruising. Settle on a price and size. Don't get locked into one manufacturer. Get a good broker (that's another story) and see what he/she can dig up.
Rick I
Toronto in summer, Bahamas in winter.
