Like Tree1Likes
  #1
Old 02-08-2013
White Beard is on a distinguished road
Smile Help choosing a deck-stepped Sailboat
Hello - I am looking for advice on a sailboat purchase, Great Lakes Region; details as follows:
- deck-stepped mast essential, please don't try to convince me that keel-stepped is the way to go :-)
- shoal draft essential, ideal = under 4.5'
- 25' - 35'; with 28' to 33' preferred
- wheel preferred over tiller
- reasonably quick 140 to 180 phrf preferred, but also seaworthy
- prefer lead keel, for this phrf range will likely need to be fin, but I am open to anything, bilge, full, long...
- any engine, except no saildrive - OK with Atomic 4s or diesels, or even an outboard in a well if properly constructed
The boat will be used primarily for daysailing so a good sized cockpit would be advantageous; but it also needs an interior that would be comfortable for short over night stays for my me & my wife. I would like a top quality designer/builder, and a boat without significant concerns such as pox, decks prone to soft spots... I do not want to fix a price, because I do not want to eliminate any suggestions, but I would expect to be able to purchase used for under $60,000 although I have considerable flexibility for the right boat.
I look forward to hearing your suggestions & my thanks in advance!
  #2
Old 02-08-2013
Mark1948 is on a distinguished road
Re: Help choosing a deck-stepped Sailboat
Why not start your search on yachtworld and narrow down your list to give us something to respond to. Parameters are very broad. Not sure you will find a combinating meetng all your parameters without a priority.
  #3
Old 02-08-2013
jimgo's Avatar
Asleep at the wheel
jimgo is on a distinguished road
I've found quite a few boats that meet your definition (except that I haven't researched the PHRF, might need to confirm here - http://offshore.ussailing.org/Assets...+Handicaps.pdf - but if the Allmand can hit 166 and average 188, most of the other boats should fit your requirements too). All are on the east coast, and all are $10,000 or less, and require only a little bit of work (at best). With your budget, you could easily have one transported, and have any changes you want made to it, with a lot of cushion. You can check out this thread:
"Value-priced" boats in the mid-Atlantic
Most of the boats that I've seen have had deck-stepped masts. All are in the 26-34 range (most are 28-30), and have wheel steering. I was looking for a cabin for a family of 4, so anything that would have worked for us should work for you.
- Jim
Home: Western Philly 'burbs
1980 Allmand 31
1975 Albacore 15
  #4
Old 02-08-2013
Stumble is on a distinguished road
White beard,
Try to narrow down your range a little. In that price range and size you could go all the way from a Cal 25 to a Beneteau 351. You need to be a little more specific in what you are looking for.
Greg Rubin
Titanium Salesman
  #5
Old 02-08-2013
Jeff_H's Avatar
Administrator
Jeff_H has a spectacular aura about Jeff_H has a spectacular aura about Jeff_H has a spectacular aura about
If I had to make one recommendation for your needs it would be the Nightwind 35, with a rating between 135 and 141. These fractionally rigged centerboarder have beautiful interior and sail very well.
Faster likes this.
  #6
Old 02-09-2013
Thank you for your contributions. I will give a little more thought to my parameters and re-post. I have followed up on a few recommendations and several interesting boats have surfaced. WB
  #7
Old 02-09-2013
Great looking boat... hadn't heard of that one before, Jeff.. only 14 built, apparently so might be a tough find. If only they'd put a little nicer effort into the top portion of the rudder...
  #8
Old 02-09-2013
Hudsonian is on a distinguished road
Although there are not many of then in the US, the Jeanneau 34.2 fits your criteria. The accomodations exceed your needs -- three cabins -- and it's faster than 140. Narrow fin keel with a lead bulb. It's got an offbeat saloon layout which you may like or not.
  #9
Old 02-09-2013
swedeish cedar is on a distinguished road
There was one of these aroung Michigan/Huron but I can't find the ad. I have a CP 23 and this or the the earlier version CP 25 is my goal.
.boatus.com/boatreviews/sail/ComPac27.asp usual 3w infront, I can't post links
  #10
Old 02-09-2013
Jeff_H's Avatar
Administrator
These have always struck me as being very charismatic for a shoal draft boat. I had seen a number of these when I lived in Florida and had even visited the factory at one point and seen them under construction. There was one in Sarasota that I occasionally saw out sailing and one here on the Bay that I would see from time to time. I have always been very impressed with these boats when I have seen them underway.
I have generally been a fan of Bruce Kirby's non-racing rule designs. I am surprised that there were only 14 built. My recollection my be mistaken but I seem to recall that they were built by two different yards and would have guessed that the 14 boats listed were only the ones built by Fort Meyer Yacht and Ship building.
To me, the strength of the Nightwind design is that these boats are a good example of the virtues of a design which was built without worrying about a racing rule. When I want to discuss the impact of racing rules on hull forms and rigs, I typically use two designers as examples, Bruce Kirby and Bruce Farr. Both designed boats that were designed to the IOR rule as well as designed totally independently of the IOR but at roughly same periods of time. In Kirby's case I look at his designs for the original Laser, Sonar, Kirby 25, Kirby 30 and the Nightwind and I see weel rounded boats which sail well on all points or sail and which are comparative easy boats to sail. The impact of the rule is pretty graphic when comparing the IOR Kirby 1/4 tonner to Kirby 25, or the IOR San Juan 30 to the Kirby 30.
Anyway, if I was looking for a shoal draft coastal cruiser, or even a boat to do the Bahamas and Carribean basin, the Nightwind would be high on my list.
You may post attachments
You may edit your posts
Deck-stepped vs. keel-stepped mast psemme Seamanship 7 11-16-2010 09:23 AM
What is a Deck-stepped mast and keel-stepped mast djr3203 General Discussion (sailing related) 11 12-25-2009 08:24 PM
Deck stepped Mast-Always Bad ? Mrs Mutiny Boat Review and Purchase Forum 24 10-05-2009 07:55 PM
Deck-Stepped vs. Keel-Stepped Masts Dan Dickison Buying a Boat Articles 0 12-12-2000 07:00 PM
SEO by vBSEO 3.6.1
