Hey,
Maybe this will help. It's a list of all work done on my boat since I purchased it in december 2006. Some of the costs are exact (where I recorded it) others are my estimated recollections. I am afraid to total it all up. Additional costs not listed include ~$2000 each year for haulout, bottom wash, mast removal and storage, moving the boat to a winter storage yard (where I can work on it) and splashing in the spring, $150 or so for mooring permit, $150 to have the mooring hauled in the fall and $150 to have the mooring dropped in the spring.
2013
3/10/13 Order new furler - Selden Furlex 200S. $2800
quote to have standing rigging replaced $5000 (which includes new furler)
2012
12/11 Change oil, oil filter, and fuel filter (R24S 10 micron) $50
11/27 James installes new lifelines ($3030 for new lifelines and 4 stanchions and bases)
11/19 R+R Bent stanchions and stanchion bases.
11/18 Move DTR to Oldman’s dock. Winterize fresh water system.
November - DTR is damaged by super storm sandy. See ‘Hurricane’
October - change fresh water diverter valve $50
August - new Main sail from UK $2700
6/1 Move boat to dock and commission water system. Boat can be sailed.
5/31 Put sails on and tune rig.
5/30 Boat is on mooring (moved by Old Man). Lauren I do put boom on, run rigging and connect mast wiring. Too windy to put sails on.
5/15 Boat is ready for launch. Old Man can’t launch until Monday 5/21 and we are on vacation from 5/22 to 5/29.
5/15 pick up mainsail and dodger from Wedekind. $250 for mainsail repairs (leech, batten pockets). $275 for dodger repair (new window and zipper stiching).
5/14 repair mast wires for anchor light and steaming / deck light
5/12 poliglow stb side. install new batteries (Costco 27DC 115 AH, 750 MCA), wash decks, paint prop (est $300 for 3 batteries)
5/11 poliglow port side
5/6 paint bottom (SR 40) (est 2 gallons at $150 each plus supplies, say $400 total)
5/5 rig check. Need to repair anchor light wiring
5/4 Clean hull w/Poliprep. Clean bottom. Hull is ready for PiloGlow and bottom paint. Test run engine, runs great. Batteries are old and shot.
4/16 R+R shaft Zinc. Service all boat winches (not mast winch)
4/14 Sand Bottom Paint - complete (est $50 for supplies)
3/28 Sand bottom paint. Starboard front half complete.
3/23 Sand bottom paint. Port side complete (except for under jack pads)
3/21 Sand bottom paint. Completed about 25% (port rear half)
3/17 rewire - new jumper from ignition to glow plug. New jumper from glow plug (hot side) to start switch. Clean start switch solenoid wire (yellow with red stripe). Clean fuse in that line. Run additional glow plug power line and clean glow plug connections. ($75 for switches and wires)
3/3 install new glow plug switch
2/21 install new bird spikes on spreaders
2011
12/15 - removed wind instrument -checks OK. Broken wire from mast.
12/4 boat covered
11/19 boat winterized and gear brought home
11/14 boat hauled
11/13 change oil and filter (3879 hours) (estimate $50)
11/9 last sail. Solo
6/15 re-seal exhaust flange to prevent water coming in when motoring
6/12 new jib sheets (Cajun XLS) ($100 I think)
5/26 headsail leach and foot line replaced ($250)
5.20 new lazy jack lines
5/11 boat launched
5/3 paint prop with antifoul
5/1 clean, poliprep, poliglow hull
4/23 scrub bottom with stuff brush to remove dead paint and expose new paint
4/22 Replace STBD port line clutch, Repair instrument mount, new prop shaft zinc
2010
11/13 Unload gear for winter
11/10 change oil. Boat hauled for winter
8/29 New oars and oarlocks – last ones lost during vacation storm
6/12 install new water heater, new engine water pump, new thermostat
($240 for water heater $100 for water pump, $20 for T Stat)
6.5 remove engine water pump
5/21 Remove Hot Water heater
5/12 Hot water heater is leaking and needs to be replaced.
5/7 Water system commissioned, 2 new lights installed. All mast wired connected. Boat ready for the season
May - new SH GX2150 VHF and command mic $350
4/26 move boat to mooring. Put boom on. Engine ran hot – bled 3 times. Better?
4/23 boat launched (not in yard, have not heard from OMBY)
4/21 finish poliglow, prep for launch
4/20 Clean topsides, poliglow starboard side
4/19 paint bottom (SR 40 entire family) ($500 for all?)
4/15 Clean, lighten, oil teak. Test run engine (raw water hoses were reversed). Engine started and ran great. Wash topsides
4/14 wash and wax decks
4/7 Rudder installed. Wire rope is not run correctly
4/1 install new water pump, HX, drain and add new coolant
3/24 finish sanding port
3/17 finish sanding stb side, do ½ of port side
3/9 sand stb ½ of boat w/60 grit
2/25 New shaft (1” X 49”), coupling, packing box hose, clamps, etc.
2/5 Clean engine compartment and bilge
2/5 New Cutless beating (OMBY) - $1000 for all driveline work
1/20 January - Prop shat removed, cutless bearing removed. Shaft log removed (OMBY)
Heat exchanger removed, cleaned $75
Walts Radiator 928 1220
807 Hallock Ave
Port Jeffrsn Sta, NY 11776-1220
2009
December – drop rudder (remove quadrant)
11/16/09 Boat hauled
11/16 Change oil and filter, 8 gallons diesel
12/15 remove rudder
11/20 boat hauled
May: New main and jib halyards (Yale Aracom T $500)
4/6 New start battery $100
Spring - Pettitt Ultima SSA
2008 Work
11/22 – cover boat, connect solar power
11/10 – winterize hot water side (blow out lines)
11/8 Winterize – remove sails, winterize cold water (drain hot water, need to blow out HW lines). Winterize head and holding tank, bring home electronics, remove impeller (blades cracked).
11/6 Boat hauled
11/1 Change oil. Add 5 gallons of fuel. 3727 hours
10/10 56' StaysetX for main sheet
8/6 - 15 gallons of fuel. Scrub boat bottom
7/25 - engine doesn't start (does not turn over). clean all wiring connections
July - new exhaust system after NYC trip (hard pipes only, not waterlift muffler) (work performed by yard Mechanic, estimate of $300)
5/08 New headsail – 140% UK Passagemaker $2780
4/26 –Engine doesn’t start, replace Facet fuel pump
4/25 - Launch day
4/08 bottom done (fair keel, barrier coat, bottom paint - Pettitt Hydrocoat), poliglow
3/08 Sand bottom, keel.
2/08 Boat bottom soda blasted. Don at All Surface Soda Blasting. $1700 for everything. He did a great job.
2007 Work
12/3/07 send Datamarine Wind Machine to DMI Inc. for repair
11/07 - start bottom paint removal
11/1/07 Boat hauled
10/07 change oil, filter, air filter, tension alt belt - 3685 hours
9/07 change macerator
9/07 tighten stuffing box, clean bilge
7/07 Repair starboard winch
6/07 Service winches (lose shaft and bearing overboard). New gears in port lazarette
5/07 Lowrance LMS337CDF ($550), SH GX1500 w/ command mic $240
4/07 New jib sheets, remove old name, new plow anchor, new mainsheet blocks and routing of sheet, install new name (estimate $500)
3/07 Change engine oil, filter, fill fuel tank, fill propane tanks, new propane lines, repair glow plugs (wiring bad), coolant, fuel filters, engine zinc, refrig pulley and belt, radio installed, bilge pump re-wired, 12V meter installed
1/07 new house battery ($200)
See on Yachtworld. Listed at $xxxxx make offer 11/06/06 for $xxK. Offer is rejected, increase to $xxK, which is accepted. See boat 11/10 and leave deposit. Survey scheduled for 11/17
Purchased 11/27/06 from Kelly Finkenworth. $xxxxxxxxx
Warren Trafton broker.
Barnaby Blatch Surveyor
Jack Neades Delivery Captain
Costs
$44 X 2, + 2 X 2 for trip to see boat 11/10
same plus $595 (survey) $650 (Haul) on 11/17 for survey
$200 car rental, $300 Jack, $50 (ferry) for delivery
Delivery was 11/27/06 - Newport to Noank
11/28, Noank to Mt. Sinai
