  #11
Old 03-19-2013
grumpy old man
bobperry will become famous soon enough
Re: Need opinions on hull
Is there a tank in the keel?
Bob's Blog ....
  #12
Old 03-19-2013
huntermj is on a distinguished road
No as far as i know it is 3,400 pounds of lead
  #13
Old 03-19-2013
grumpy old man
Is the keel steel?
What I am getting at is that if the keel is a steel envelope that plug may be a way to access the area above the lead as the lead will not fill the entire volume of the keel.
If the keel is timber then,,,,never mind.
Bob's Blog ....
  #14
Old 03-19-2013
Just a view of the interior.
  #15
Old 03-19-2013
I got ya now. most of these were built in the Uk. and they use steel keels. from the original owner i understand the the keel was poured in a wood mold.
  #16
Old 03-19-2013
I need to figure out how to resize pictures
  #17
Old 03-19-2013
grumpy old man
So, It's a steel keel with lead inside. Right?
If so, I would guess that plug is to access the volume in the keel above the lead. You have to have some way of getting into it.
Interior looks very nice.
Bob's Blog ....
  #18
Old 03-19-2013
do you think that would explain the corrosion of the plugs? i looked all over and this is the only corrosion i saw.
  #19
Old 03-19-2013
grumpy old man
Sorry but I am not a corrosion expert. I think there are several here who are. My guess is that plug fitting is just made of inferior metal not suitable for that environment.
Any way you can unplug it and take a look at what is in there? My guess is air.
Bob's Blog ....
  #20
Old 04-03-2013
So i had the survey done on this boat and it turns out these fittings are drain plugs and after wiping them off there is no corrosion just bilge gunk. And survey says that this is a very solid boat all around. just needs a few minor maintenance things done that the po has neglected. so i made an offer. So within in a week i should have a new and interesting way to wast money and time.
You may post attachments
You may edit your posts
Hull indent on P30, where uppers meet the hull hamburking P30 2 02-27-2013 12:43 PM
Seeking opinions for deck and hull-deck joint repair gregor1234 Gear & Maintenance 8 04-25-2012 11:10 PM
Multi-Hull vs Mono-Hull Sailboats? terryjoe Boat Review and Purchase Forum 8 11-11-2007 10:45 AM
Hull Issue - Need Opinions AboardIndigo Gear & Maintenance 20 08-29-2007 08:43 AM
Opinions on new motorsailing hull forms. amh Boat Review and Purchase Forum 0 01-11-2002 08:17 AM
SEO by vBSEO 3.6.1
