Steel boats - things to watch for? - Page 2 - SailNet Community
post #11 of 16 Old 03-22-2013
bljones's Avatar
Re: Steel boats - things to watch for?
10 gauge is not atypical.
It's 5 o'clock somewhere:
bljones is offline
post #12 of 16 Old 03-22-2013 Thread Starter
krisscross's Avatar
Thanks. Good to know.
I still like that boat but now have a lot more perspective.
krisscross is online now
post #13 of 16 Old 03-23-2013
Sea Sprite 23 #110 (20)
mad_machine's Avatar
10 guage seems thin.. that is only 3mm or so...
Art Haberland
In the end all that matters is how fully you loved, how gently you lived, and how gracefully you let go of things that did not belong to you -Buddha
mad_machine is offline
post #14 of 16 Old 03-23-2013
TQA
Bombay Explorer 44
TQA's Avatar
3mm not unusual for top sides esp. on a smaller boat.
4 - 5 mm for hull as a minimum.
Steel boats die from the inside. Ignore the outside surface rust get inside with mirrors and good lights and a hammer. An ultrasound examination carried out by a surveyor used to working with steel boats would be a good investment if you have doubts.
I cruised an old steel boat for 7 years and had some patching done when problems appeared. Relatively cheap and I knew that repairs were as strong as the original.
That Tahitiana looks good if you can cope with a slow boat. Several have circumnavigated.
TQA is offline
post #15 of 16 Old 03-23-2013
A hammer and a centrepunch will find any thin spots. Whack any doubtful point with a centre punch, and if it doesn't dent severely, you have plenty of metal there. Check the low point of the keel and any sealed areas, such as ballast etc. Check for adequate paint under the spray foam insulation. Folks and Fehr boats had zero paint under the foam, which gave steel boats a reputation for rusting from the inside out. Foam is not adequate protection by itself. Three or more coats of epoxy tar is the only thing which works.
Patches are a bad sign.
10 guage is common, but I prefer 3/16th and less framing. With the huge amount of excess framing in a Tahiti, you could go frameless and 3/8th plate and she would be lighter. They have a totally ridiculous amount of framing. Yesterday I saw a Fehr boat which had so much framing in the bow, with 10 guage pate,you could have used quarter inch plate and no framing and she would have been lighter, and far tougher. Hit a sharp rock and thickness will save you from holing, framing wont, and framing will in fact increase the chance of holing.
Tahitis are slower than a bureaucrat's brain.
You can always find me on the origamiboats site ( yahoo groups) a good source for anyone considering a steel boat.
Brent Swain is offline
post #16 of 16 Old 03-24-2013
TQA
Bombay Explorer 44
TQA's Avatar
A hammer and a centrepunch will find any thin spots. Whack any doubtful point with a centre punch, and if it doesn't dent severely, you have plenty of metal there. .
Wow I would have gone totally BATSHIT if anyone had used a centrepunch on my old steel boat. Breaking through the paint skin that I had so lovingly coddled over the years.
TQA is offline
1970 E-35. Things to watch out for? salamandyr Ericson 6 06-11-2012 09:50 AM
Things to watch out for... Allanbc General Discussion (sailing related) 2 03-24-2012 02:21 PM
new to steel boats xymotic Gear & Maintenance 20 09-10-2011 10:27 PM
Advice and Things to Watch out for DrB Gear & Maintenance 1 01-05-2009 10:54 AM
