38 footers
Save yourself alot of money and get a great boat that use to be owned by a friend of mine. I bought its sistership 20 yrs ago and his boat sounds in even better shape.
C-C Apache 37 Mk II “EASTERLY” – US Documented Yacht – For Sale
37’ Sparkman & Stephens Apache Mk II Racer-Cruiser, 1969/96 by Chris-Craft & Corny Shields under Olin Stephen’s supervision, after design of America’s Cup “INTREPID”.
S&S Brochures, History & Sail Plan available
LOA: 37’ Hull Construction: Solid Fiberglass, Hand-laid Sail Area: 744 Sq. Ft.
LWL: 27’ Deck & House: Solid Fiberglass Spinnaker: 1,100 Sq. Ft.
Beam: 10’3” Displacement: 14,500 Lbs. Berths: Six @ 6’6”
Draft: 5’9” Keel: 6,220 Lbs. Iron Bulb Headroom: 6’3-1/2”
Tankage: Fresh Water – 80 gallons. Diesel Fuel – 30 gallons. Waste – 16 gallons (with 3-way valve).
SAILS: Full Batten “Marblehead” Premium Main by Harding 2001, Spectra Tri-radial Genoa by Shore 1996 on Pro-Furl R/F. Light Blue Nylon Spinnaker, Pole & sheets; 160% Drifter of 1.5 oz Nylon; new Dacron stay-sail.
PHRF Rating: 160/182; Race History: 1st’s & 2nd’s; 3rd overall 1997 Beverly Yacht Club Twilight Series.
Cruising History: Marblehead to Nova Scotia; Marion to Mt. Desert 2002 without incident. Never chartered.
POWER: 1989 25-Hp Universal Diesel w/ low hours, Fresh-water-cooled; Full Engine gauges: Tach, Volts, Temp, Oil Pressure & Temp alarms. Fuel Gauge. New Hurth Transmission 1994, New Heat Exchanger 1998, New 55-amp Alternator & Starter 2003/04. Automatic Halon Fire extinguisher in engine compartment.
INSTRUMENTS/ELECTRICAL: New Circuit Breaker Panel and new primary wiring 2003. Wind, Speed & Depth Meters, programmable Anchor watch, race timers, API & CHI. Loran, GPS, VHF Radio with Hailer. 6” Constellation Compass in Pedestal, 4” Richie Compass, AM/FM Stereo Cassette and TV-VCR. 2 G-27 deep-cycle house batteries and an isolated starting battery. 45-watt & 15-watt Solar Panels. Autohelm.
GROUND & DECK TACKLE: Double-throw manual Anchor Windlass with Rope and Chain jennies feeding S/S Double Bow Roller holding a Large Danforth on 250’ chain, and a Plow anchor on 300’ nylon. Spare Danforth on 250’ nylon rode. Sea Anchor. Large Fenders, Batter Boards. Outboard Crane Hoist at Stern.
UPGRADES: Wheel Steering, Barient #32 & Barlow #28 Winches, Windlass, SS Opening Ports, Holding tank.
CNG gas Stove-Oven & Hot Water Heater: H&C water at Galley, Head w/ Corian Sink & Shower. New 12-V Refrigeration with Icemaker; new Velvet Upholstery, New Breaker Panel & Wiring 2003. Custom Mahogany Interior & Floors. Hull topsides Awlgrip1994, compounded & waxed 2003. Bottom sandblasted & West System Epoxy-Copper Barrier Coated 1994; Keel stripped & Epoxy-Zinc sealed with new ablative copper bottom 2003.
LAYOUT: Preferred Aft Galley - Mid-ships Dinette: V-Berth forward, Head & Shower to port, two Hanging Lockers to starboard, Main Salon with Dinette to port which converts to a Double Berth, a Pullman Berth and Pilot Berth to starboard. Aft Galley, then Companionway steps to Bridge Deck and Cockpit with two large sail & gear lockers. Edson Pedestal Wheel Steering; Helmsman’s Seat, Aft Lazerette.
EASTERLY carries classic lines and sheer, and is a “head-turner” in any harbor. This belies her fast, dry, weatherly sailing performance made possible by her modern Bulb Keel – Skeg Rudder underbody. Keel-stepped mast. C-C quality fiberglass construction, epoxy-bottom, bronze thru-hulls, grounded. She easily out-sails Alberg 37, Cape Dory 38, Bristol 40 & Hinckley B-40’ and holds her own with many newer boats such as Bristol 38.8’s and Mason 43’s upwind. The S&S Apache 37 hull design is same as the S&S Hinckley 38.
BY APPOINTMENT ONLY at Triad Boatworks, Mattapoisett MA, (508) 758-4224 – broker (508) 748-3115
Offered at $34,500 before July 1st, $36,000 after. Owner (772) 215-3131 e-mail” <tructor@bellsouth.net>
