Nonsuch 36 - What's the scoop? - SailNet Community
 1Likes
  • 1 Post By Jiminri
post #1 of 9 Old 04-30-2013 Thread Starter
A palapa awaits me...
Send a message via Skype™ to Razcar
Lightbulb Nonsuch 36 - What's the scoop?
I've recently come across a review of the Nonsuch 30- which seems nice but small for me. Come to find out, they made a 36, which appears to be perfectly sized. I'm not familiar with this boat and rig, and I'm curious to know what the downside is to it. I love the idea for such a simple rig, easy to single hand. What am I missing? Is the mast problematic, as big as it is? To me it seems like a nice option... great interior room, easy to sail, and from videos i've seen, easy to reef. I wouldn't be into racing it, just cruising it.... perhaps long distances, but mostly around the islands.
any ideas an opinions are welcome.
Raz - Denver, CO
Razcar is offline
post #2 of 9 Old 04-30-2013
Re: Nonsuch 36 - What's the scoop?
The Nonsuch's are great boats.My Family had a 30 ultra.It was the largest 30 footer I ve ever seen.Its about 30 on the WL to.The interior was very roomy for 2 or 3.It was also fast,very easy to sail.We had an electric Lewmar winch to hoist up the main.Never had any problems handling it.All in all a great boat. I miss it.The 36 is HUGE for a boat under 40'.I was only on one once at a Nonsuch rendevous.It was like being on a 50 footer.They a very well built, beautiful interiors.
jak3b is offline
post #3 of 9 Old 04-30-2013 Thread Starter
Thanks jak3b,
Do you think they'd make good bluewater cruising boats?
Any resources online that you know of that can speak to that?
Thanks!
Raz - Denver, CO
Razcar is offline
post #4 of 9 Old 04-30-2013
Dirt Free
boatpoker's Avatar
Suggest you do some googling on their masts, they had some problem and at $100k for a new one you'd better take a close look at it. Their propane systems are absolutely terrible with multiple connections and T's inside the boat and propane water heaters that say right on the "Do not install in a boat". To top it off they are fully balsa cored below the water line and about half of the ones I look at have serious core problems in the bottom. Curiously some are as dry and sound as the day they were built. Do a lot of research and get a very good surveyor
The hysterical laughter you hear as you drive a way in your"new" boat ..... is the seller.
boatpoker is online now
post #5 of 9 Old 04-30-2013 Thread Starter
many thanks boat poker!
Raz - Denver, CO
Razcar is offline
post #6 of 9 Old 04-30-2013
rugosa's Avatar
Check out owner's association at Home
Low volume production boat line with popular following. My understanding is they are not great upwind boats, but others on SN will need to weigh in to verify that.
When Hinterhoeller Yachts folded up Nonsuch tooling went to Wiggers Custom Yachts in Whitby, ON - not much information here - Wiggers Custom Yachts
BP's coring comment holds true with entire Hinterhoeller line from late 70's to end of production - Niagara and Nonsuch models known for coring problems.
rugosa is offline
post #7 of 9 Old 04-30-2013
Jiminri's Avatar
Best place to get information is from the web site of the International Nonsuch Association. Home
The INA is very active and you'll get lots of good advice.
Nonsuches were designed as the ultimate coastal cruiser, and are not bluewater boats. Cockpit is too big, drains are too small, no bridgedeck, etc. But they are fairly fast, very maneuverable, and easy to single hand. And build quality is excellent.
The very early Nonsuches did have problems with their masts because of bolt holes that were drilled down low by the deck level. Hinterhoeller replaced them all under warranty. A new mast for a 30 is nowhere near $100K and I cannot imagine that a mast for a 36 is 10 times the price of the mast for a 36. That's just sillly. Propane lines are tee-d in the cabin, but that's a very easy fix if it hasn't been done already. Hulls are cored, but so were a lot of boats and Hinterhoeller did it really well. I've looked at a lot of boats while shopping for mine and none had wet cores in the hull.
The sail on a 30 is big--about 540 square feet. Air draft is about 50 feet. The sail area on a 36 is 740 square feet. That's huge and I'm guessing you'll want some help from electric winches.
The 33 is a very good size boat too, you might take a look at that as well.
Good luck with your search.
bljones likes this.
Nonsuch 30 Ultra #343 1986
West River, MD
Jiminri is offline
post #8 of 9 Old 12-14-2015
The Nonsuch 36 is a very nice boat.
The interior is amazing for its size, layout and features.
The Nonsuch 36 once it gets sailing it goes. I was on a Nonsuch 36 in Milford CT on Long Island Sound in a 15 knot wind and the Nonsuch 36 heels over slightly and sails in the straight line, on a slight heel like a boat with a purpose and destination.
The Nonsuch 36 is ideal for long weekend cruises or over nite. Its is almost like having a cabin on the water.
There is no bending, ducking or weird movements to get in and around the boat. The interior is big. The boat is big for a 36 footer.
I wished they had continued making the Nonsuch and came up with a way to furl the sail to the mast, which seems like an easy thing to do.
If the sail furl to the mast, the Nonsuch would be the perfect boat to have and own.
reidclifford is offline
post #9 of 9 Old 12-15-2015
S/V Caper Nonsuch 36
What Jiminri said. I will add that I own a Nonsuch 36 and find it is very easy to single hand, sails surprisingly well to weather (seems everyone thinks otherwise). She is a fast boat and easy to handle, tracks and tacks very well. With a 54 hp. Yanmar and 3 blade max-prop she handles like a J 24. The sail at 742 sq. ft. is HUGE, watch your jibes, love the wishbone rig. You will want an electric winch to haul it up, at least I do at 66. With a tides track and stack pack dropping the sail is very simple, as is raising it for a quick sail. It is not a bluewater boat, but is a very capable coastal cruiser and very able to do a 1-2 day offshore hops with a weather window, it handles seas very well but the cockpit is large with no bridge deck to speak of. Also, with just one sail, your options are limited as to sail combos, and you can't hove to. You can rig a storm sail if you desire, but she reefs easily and stands up very well in a blow, has a comfortable motion too. Below deck she is HUGE, lots of storage, lots of ventilation, lots of headroom, well laid out, comfortable, well built and executed, quality fittings properly installed, nice fit and finish. The on demand gas hot water with pilot light is an issue for some (insurance companies) but I love it. Re-plumb the gas lines without Tees interior. The heater is located in the large salon/galley with a hatch, portlight, and dorade vent right next to it, my CO2 detector never goes off. The 30's have the heater inside the head with less room and ventilation, and have had an occasional(heater) problem with CO2 in the small space during cold weather. On the downside, she has a 62' mast (65 with antenna and wind etc), watch your bridges, a fair amount of windage so can be difficult to turn in tight fairways at low speed, and she hunts a bit at anchor. I've not seen any problem with hull coring, but have seen some issues with deck coring. To me, she is the perfect near coastal cruiser/live aboard, albeit not everyone's taste, she is a niche/cult boat.
flyrod is offline
Tags
nonsuch
Nonsuch 33 davidpm General Discussion (sailing related) 21 06-05-2015 11:41 AM
Nonsuch 33 (I don't get it) davidpm General Discussion (sailing related) 15 06-16-2014 10:52 AM
Nonsuch nl836 Boat Review and Purchase Forum 4 07-17-2010 02:39 PM
Nonsuch 21 yfuchs Boat Review and Purchase Forum 1 08-16-2008 09:04 AM
Wind Scoop Freesail99 Gear & Maintenance 11 06-11-2007 06:57 PM
