Old 06-14-2004
steve911t is on a distinguished road
jeanneau deck problem
Im thinking of purchasing a 1985 jeanneau 45 sunkiss Ive had a survey done and the results where good untill the surveror found that the deck had a lot of moisture from the chain locker back to the cockpit.I found out that the yacht had previousley had a teak deck which had been removed and where the screws had been hadnt been repaired properly.the suveyor suggested that the core betwen the deck and the inner skin,which I think is bolsa has to be removed ,replaced and then a new deck applied.
What I would like to know is ,has any body had a similar problem and what is the best cure,and will this affect the strength of the yacht or should I just walk away?
thanks for any input steve
Old 06-14-2004
Jeff_H's Avatar
Super Moderator
You had emailed me about this and I sent back a reply but I did not realize that the boat previously had a teak deck. I do not know what Jeaneau''s practice was, but most manufacturers use plywood cores when they build a teak deck. If that is the case, the problem can be a lot worse than on a balsa cored deck since plywood tends to rot more quickly since the plys carry the moisture in all directions from a leak. Run, don''t walk, the other way from this boat.
1976 41'' TA CHIAO CT ?????? hyway Boat Review and Purchase Forum 18 02-05-2010 03:20 PM
Deck vs. Keel Stepped Masts Envirella Gear & Maintenance 10 11-29-2009 11:06 AM
Deck stepped Mast-Always Bad ? Mrs Mutiny Boat Review and Purchase Forum 24 10-05-2009 07:55 PM
Crackling deck on an ericson-27 marcberoz Boat Review and Purchase Forum 0 01-04-2004 03:02 AM
Jeanneau quality is fine (Jeff H) JHodor Boat Review and Purchase Forum 7 12-28-2003 02:38 PM
