- Quick Menu
| Boat Reviews This forum has all types of boat reviews. Take a look, Dream, Agree, Dissagree.... but enjoy. |
10-02-2010
Advocate777
Nonesuch, Cape Dory, Oday
Does any one have any input for me as to which of these three 30 foot boats would be best suited for a:
1.) beginner sailor-ease of sailing
2.) based in Chesapeake Bay. trips down IC to Florida, passage to Bahamas/Caribbean
3.) liveaboard for two
4.) coastal cruising/best motion in offshore seas
5.) best cockpit
-Thanks
Chesapeake Bay area
10-02-2010
Bristol 45.5 - AiniA
Before commenting it is necessary to get more information. How do you define 'offshore'? Related question, is what part of Caribbean are we talking about and how do you plan to get there? Going to the Bahamas is a totally different challenge than going offshore to the Virgin Islands from the Chesapeake which, for boats of this size could be a two week passage, at a time of the year when the weather can be quite snarky.
Back in Brisbane. Have paid the entry fee for the Sail Indonesia Rally at the end of July, so I guess we are going to Indonesia and then South Africa. You can check OnAinia.blogspot.com for updates on our travels.
10-02-2010
Advocate777
Trip 1.)
Chesapeake bay south to Intercoastal. South on Intercoastal to Georgia. Out to ocean cruise off Florida coast- back in at Ft. Pierce. Live aboard in Stuart area. Make way down to Miami/Biscayne bay. When weather window opens go across Gulf Stream (42 miles) to Bimini.
(alternate route-palm beach west to Bahamas--Abacos cruising.
Trip 2.) (eventually)
From Bahamas south to Caribean- U.S. Virgin Islands, Granada
return to south Florida.
Chesapeake Bay area
10-03-2010
What you are doing would generally not be considered offshore although there would be several overnights - the difference is that you generally get to choose a weather window in each case eg to Bahamas and from southern Bahamas to Turks and Caicos. You can still get crappy weather within a decent forecast.
Any of the boats you mention, if well-equipped, could be used. You should be aware that the three boats have some fundamental differences. The most obvious example is the Nonsuch which has a different rig from the other two. Also, the Nonsuch is enormous compared to most 30 footers. In fact, I suspect that a Nonsuch 26 might have more interior volume than a Cape Dory 30. The ODay and CD are the same length but have completely different hull forms. Also the boats you ask about are hugely different in price with ODay 30s of different ages from $15k to $30k and Nonsuches from $35K to $80k (CDs somewhere in the middle)
I think you need a lot more information about boat designs in general so that you will end up comparing boats that are more alike. Also, figure out what your budget is, keeping in mind that you will have to do significant upgrades on almost every boat of this age and that the more you spend on the boat the less you have for your cruising kitty. Choosing a good boat really matters (there is not one 'best' choice) and it is worth the research.
10-03-2010
Da Most Educated Red Neck
I were the OP I would slow down the purchasing and read and learn more. Most importantly, sail more via sailing classes and volunteering to crew in other's boat.
Doing it right the first time is most efficient and rewarding.
Starting 2012 sailing season: Done with the timeshare boat. To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts.
10-04-2010
While I agree the OP needs to fine tune what he needs/want, that's not easy to do for someone without a lot of experience. Here's my take on e boats mentioned.
Any are fine for the Bay, ICW and a quick hop to the Bahamas in good weather. I wouldn't consider any for a longer trip to the Caribbean. Nonsuch has the most interior room by far, but handling that sail is a bear. The CD is a traditionaly styled boat, but gives up interior room for that style. The ODay is a typical cruiser/racer of the early 80s. Decent sailing performance and nice interior space. Of the three, it would be my choice. However none of these is good in light air, and there's a lot of that on the Bay. I would look further.
10-04-2010
Part of the issue is that the OP probably doesn't have enough experience on different types of boats to really consider/understand what is important in a boat to him. Getting more time in on as many types of boats as possible before making any decisions is probably a good idea.
His constraints are pretty general, and somewhat contradictory... a boat designed for coastal cruising is not going to have good offshore motion generally as a rule; the best cockpit for offshore use is generally a lousy choice for coastal cruising or daysailing; a good Chesapeake liveaboard boat isn't going to be a good boat for open water passages to the Virgin Islands.
He needs to figure out what his primary use of the boat is going to be and buy a boat best suited for what he will be using the boat for 99% of the time. If most of his sailing is going to be coastal cruising and daysailing, along with living aboard in the Chesapeake, then a Benehuntalina might be his best choice, rather than a bluewater voyager. It'd certainly give him more room for living aboard than a blue water boat would, as well as probably be a better choice for daysailing and coastal cruising.
Finally, he doesn't say what his budget for the boat is. The budget will eliminate a lot of choices.
10-13-2010
Back to the original post - we owned an O'day 34 and took her cruising through the Keys and Bahamas.
It was our first boat and neither of us had much sailing experience - she was brilliant tho; handled the Gulf Stream well, didn't get any damage when we rubbed the keel on the sand / mud every so often and had plenty of space. We entertained MANY times throughout our cruising and the cockpit could easily hold 6-8 people. Good sea motion also, unless the swell was on the aft-quarter, in which case she didn't track the best. We also saw 10.2 kts surfing small swell one afternoon, and averaged 5-6kts, including a number of overnight passages.
The only reason we sold her was we were returning to the UK and our future plans needed a bigger boat for global cruising.
I haven't been on an O'day 30 but keep in mind we found a 34 stifling at times, a 30 is going to be more-so.
Good luck with your purchase!
10-13-2010
Lies about her age
My O30 is the fin keel model I single hand her allot on the River here. The location of the primary winches are a PITA but in moderate air I just toss the sheets around them and use a cam cleat farther back.
Odays do have smallish cockpits.
10-13-2010
On the 30's perhaps (but then don't most 30's have small cockpits?) - our 34 had plenty of space for entertaining, even with the full tent and plastics up.
| Thread Tools |
Search this Thread |
| Thread |
Thread Starter |
Forum |
Replies |
Last Post |
cape dory 30
c172guy |
Boat Review and Purchase Forum |
26 |
03-06-2011 01:30 PM |
cape dory 25
slowpoke |
10 |
06-23-2010 05:05 PM |
Cape Dory 28 Cape Horn Self-Steering Installed
BillOfCapeCod |
Gear & Maintenance |
6 |
05-20-2009 07:49 PM |
Cape dory
billgcroton |
5 |
04-04-2003 03:23 PM |
Cape Dory 30
halyardz |
0 |
06-27-2002 10:41 PM |
