Irwin 38 1983 for offshore?? - SailNet Community
Boat Reviews This forum has all types of boat reviews. Take a look, Dream, Agree, Dissagree.... but enjoy.
 1Likes
  • 1 Post By chucklesR
post #1 of 5 Old 01-15-2013 Thread Starter
benhead
Smile Irwin 38 1983 for offshore??
Hello,
I am thinking to purchase an Irwin 38' 1983 in Florida, I know there is much better blue water boats however I am wondering if anybody can help me find out if she is strong enough for ocean crossing (Pacific, Indian).
Thanks,
Ben
benschleifer is offline
post #2 of 5 Old 01-16-2013
Lake Superior Sailor's Avatar
Re: Irwin 38 1983 for offshore??
It's not a problem for the boat! The real question is are you captain enough to handle the task? It's the sailor not the boat that makes the crossing. The boat make it easy or hard; How well will you prepare her for the trip? Where will you cross? and what weather window? this is what matters....Dale
Reluctant Lady
Cal 28, 1967
Lake Superior
Where God got it done!
Lake Superior Sailor is offline
post #3 of 5 Old 01-16-2013 Thread Starter
benhead
Thank you, couldn't agree more...
I know that the captain is the main thing however I heard that there is some structure problems in some Irwins from the 80' and I am wondering about this model... I am worried about the weigh, keel, "week spots", flipping over and more...
so, if you or anyone else can help me with his/her knowledge it will be a great help.
All the best!!
Ben
The Following User Says Thank You to benschleifer For This Useful Post:
robertluster (01-29-2014)
post #4 of 5 Old 01-16-2013
chucklesR's Avatar
Sure it can - with good weather windows, a good skipper, and proper maintenance having been done.
Takes the same thing for any boat of course..
BTW, my Irwin 38 is a '87, so I might be biased
chef2sail likes this.
chucklesR is offline
post #5 of 5 Old 01-29-2014
There are Irwins in ports all over the world. Sure there are issues with Irwins, but often they are 'lack of maintenance' issues, more than design issues. Remember Irwin produced over 6000 boats! A few things I would consider if you are preparing for crossings. I would through bolt my hull deck joint every 18" this is no small task as interior parts will need to be replaced. The hull deck joint was very strong when these boats were new and the method of joinery top notch, (joint type) except that instead of bolts Irwin used screws on the top and from the side throught the rail. (Irwin was very proud of the hull deck joint at the time by the way) Crevise corrosion is the problem here and the screws can be dangerously weak on a 30 year old boat.
Replace the chain plates.
Inspect the bulkheads, they are tabed to the hull all the way around, but some could use reinforcement.
The salons are often huge and not adequately supported for the riggors of passagemaking. There are several ways to add strength, all are labor intesive and if you're aren't prepared to do the work yourself, are likely cost prohibitive.
I have heard talk of the larger Irwins having not adequate deck hardware, but that is certainly not the case on my 65 as it is all massive, infact overkill on the winches IMO.
Inspect the Mast Step- this is a hot spot on many Irwins... the original rusts inside and out and should be replaced if it's not sound.
Get a good surveyor, preferably one is is familiar with Irwins.
And rememeber Irwins are in ports all over the world and they all sailed there!
Total Chaos is offline
The Following User Says Thank You to Total Chaos For This Useful Post:
1983 S-2 10.3 wcstorm Boat Review and Purchase Forum 6 10-06-2011 03:13 PM
C & C 29.5 1983? Jigdancer Boat Review and Purchase Forum 10 01-18-2010 10:18 PM
Offshore performance of a Beneteau Oceanis 500 offshore JohnVerver Introduce Yourself 1 05-23-2009 01:40 PM
1983 Irwin 37 essman Irwin 1 09-29-2006 04:50 PM
1983 Irwin 34'' Owners animaashi Gear & Maintenance 4 01-09-2002 10:46 PM
