| Tom Wood |
11-11-1999 07:00 PM |
The Turner T45
<HTML><!-- eWebEditPro 1.8.0.2 --><P>All the words to describe the new Turner T45 start with highhigh quality, high performance, high pedigree, and high tech. This boat has gran prix IMS stamped all over it. </P><P>Engineering and design by Bill Tripp should be the first clue. Sailors may be less familiar with Turner Marine, a phoenix-like resurrection of the superb craftsmen left jobless by the disastrous fire at the C&C plant in St. Catherines, Ontario. </P><P>The details of the T45 are just as impressive. A 45-foot plus LOA sitting on a 38.26 LWL and only 18,500 pounds displacement. With a max. beam of 13.82 feet and a waterline beam of only 11.20 feet, the Turner 45 has nearly a skimming dish hull. Ballast at 8,500 pounds comprises over 45 percent or her displacement, which is needed to keep the 1,081 square feet of sail in the air. A Displacement/ Length ratio of 147.46 combined with a Sail Area/Displacement ratio of 24.72 spell speed from start to finish. Standard draft is a nine-foot fin with optional six-feet five-inch shoal bulb and a free standing elliptical spade rudder to match. </P><P>Hull and deck construction are vacuum bagged vinylester resin and Kevlar/S-glass reinforcements over a balsa core that should give immense strength-to-weight ratios. Hull and deck are laminated together for leak-proof longevity. The high-polish stainless is a work of art. While the rudder glides on state-of-the-art Tides Marine bearings, I question the use of an aluminum rudder post for long term immersion in salt water. </P><P>Rising above all this is a three spreader carbon fiber stick fitted with Antal track, discontinuous Navtec rod rigging, ultra-low-stretch Aramid, Spectra and Vectran running rigging. At 65.17 feet off the water, the T45 is perilously close to many bridge heights.<BR></P><TABLE width=450 border=0><TBODY><TR><TD width=373><TABLE height=291 width=364 bgColor=#d9ffd9 borderColorLight=#ccccff border=0><TBODY><TR borderColor=#ccffcc><TD width=147><FONT face="Arial Black, Garamond, Georgia, Marigold, Tahoma, Trebuchet MS, Modern, Roman, sans-serif" color=#333399 size=1>Length Overall</FONT></TD><TD width=48><FONT face="Arial Black, Garamond, Georgia, Marigold, Tahoma, Trebuchet MS, Modern, Roman, sans-serif" color=#333399 size=1>(LOA)</FONT></TD><TD width=76><FONT face="Arial Black, Garamond, Georgia, Marigold, Tahoma, Trebuchet MS, Modern, Roman, sans-serif" color=#333399 size=1>45.16'</FONT></TD><TD width=75><FONT face="Arial Black, Garamond, Georgia, Marigold, Tahoma, Trebuchet MS, Modern, Roman, sans-serif" color=#333399 size=1>13.765 m</FONT></TD></TR><TR borderColor=#ccffcc><TD width=147><FONT face="Arial Black, Garamond, Georgia, Marigold, Tahoma, Trebuchet MS, Modern, Roman, sans-serif" color=#333399 size=1>Waterline Length</FONT></TD><TD width=48><FONT face="Arial Black, Garamond, Georgia, Marigold, Tahoma, Trebuchet MS, Modern, Roman, sans-serif" color=#333399 size=1>(L)</FONT></TD><TD width=76><FONT face="Arial Black, Garamond, Georgia, Marigold, Tahoma, Trebuchet MS, Modern, Roman, sans-serif" color=#333399 size=1>38.26'</FONT></TD><TD width=75><FONT face="Arial Black, Garamond, Georgia, Marigold, Tahoma, Trebuchet MS, Modern, Roman, sans-serif" color=#333399 size=1>11.662 m</FONT></TD></TR><TR borderColor=#ccffcc><TD width=147><FONT face="Arial Black, Garamond, Georgia, Marigold, Tahoma, Trebuchet MS, Modern, Roman, sans-serif" color=#333399 size=1>Beam Maximum </FONT></TD><TD width=48><FONT face="Arial Black, Garamond, Georgia, Marigold, Tahoma, Trebuchet MS, Modern, Roman, sans-serif" color=#333399 size=1>(BMax)</FONT></TD><TD width=76><FONT face="Arial Black, Garamond, Georgia, Marigold, Tahoma, Trebuchet MS, Modern, Roman, sans-serif" color=#333399 size=1>13.82'</FONT></TD><TD width=75><FONT face="Arial Black, Garamond, Georgia, Marigold, Tahoma, Trebuchet MS, Modern, Roman, sans-serif" color=#333399 size=1>4.212 m</FONT></TD></TR><TR borderColor=#ccffcc><TD width=147><FONT face="Arial Black, Garamond, Georgia, Marigold, Tahoma, Trebuchet MS, Modern, Roman, sans-serif" color=#333399 size=1>Beam Waterline</FONT></TD><TD width=48><FONT face="Arial Black, Garamond, Georgia, Marigold, Tahoma, Trebuchet MS, Modern, Roman, sans-serif" color=#333399 size=1>(BW)</FONT></TD><TD width=76><FONT face="Arial Black, Garamond, Georgia, Marigold, Tahoma, Trebuchet MS, Modern, Roman, sans-serif" color=#333399 size=1>11.20'</FONT></TD><TD width=75><FONT face="Arial Black, Garamond, Georgia, Marigold, Tahoma, Trebuchet MS, Modern, Roman, sans-serif" color=#333399 size=1>3.41 m</FONT></TD></TR><TR borderColor=#ccffcc><TD width=147><FONT face="Arial Black, Garamond, Georgia, Marigold, Tahoma, Trebuchet MS, Modern, Roman, sans-serif" color=#333399 size=1>Displacement</FONT></TD><TD width=48><FONT face="Arial Black, Garamond, Georgia, Marigold, Tahoma, Trebuchet MS, Modern, Roman, sans-serif" color=#333399 size=1>(Disp) </FONT></TD><TD width=76><FONT face="Arial Black, Garamond, Georgia, Marigold, Tahoma, Trebuchet MS, Modern, Roman, sans-serif" color=#333399 size=1>18,500 lb.</FONT></TD><TD width=75><FONT face="Arial Black, Garamond, Georgia, Marigold, Tahoma, Trebuchet MS, Modern, Roman, sans-serif" color=#333399 size=1>8,400 kg</FONT></TD></TR><TR borderColor=#ccffcc><TD width=147><FONT face="Arial Black, Garamond, Georgia, Marigold, Tahoma, Trebuchet MS, Modern, Roman, sans-serif" color=#333399 size=1>Ballast</FONT></TD><TD width=48><FONT face="Arial Black, Garamond, Georgia, Marigold, Tahoma, Trebuchet MS, Modern, Roman, sans-serif" color=#333399 size=1>.</FONT></TD><TD width=76><FONT face="Arial Black, Garamond, Georgia, Marigold, Tahoma, Trebuchet MS, Modern, Roman, sans-serif" color=#333399 size=1>8,500 lb</FONT></TD><TD width=75><FONT face="Arial Black, Garamond, Georgia, Marigold, Tahoma, Trebuchet MS, Modern, Roman, sans-serif" color=#333399 size=1>3,856 kg</FONT></TD></TR><TR borderColor=#ccffcc><TD width=147><FONT face="Arial Black, Garamond, Georgia, Marigold, Tahoma, Trebuchet MS, Modern, Roman, sans-serif" color=#333399 size=1>Draft</FONT></TD><TD width=48><FONT face="Arial Black, Garamond, Georgia, Marigold, Tahoma, Trebuchet MS, Modern, Roman, sans-serif" color=#333399 size=1>(D)</FONT></TD><TD width=76><FONT face="Arial Black, Garamond, Georgia, Marigold, Tahoma, Trebuchet MS, Modern, Roman, sans-serif" color=#333399 size=1>6' 5"/9'</FONT></TD><TD width=75><FONT face="Arial Black, Garamond, Georgia, Marigold, Tahoma, Trebuchet MS, Modern, Roman, sans-serif" color=#333399 size=1>1.96 m/2.74 m </FONT></TD></TR><TR borderColor=#ccffcc><TD width=147><FONT face="Arial Black, Garamond, Georgia, Marigold, Tahoma, Trebuchet MS, Modern, Roman, sans-serif" color=#333399 size=1>Ballast/Displacement </FONT></TD><TD width=48><FONT face="Arial Black, Garamond, Georgia, Marigold, Tahoma, Trebuchet MS, Modern, Roman, sans-serif" color=#333399 size=1>45%</FONT></TD><TD width=76> </TD><TD width=75> </TD></TR><TR borderColor=#ccffcc><TD width=147><FONT face="Arial Black, Garamond, Georgia, Marigold, Tahoma, Trebuchet MS, Modern, Roman, sans-serif" color=#333399 size=1>Righting Moment</FONT></TD><TD width=48><FONT face="Arial Black, Garamond, Georgia, Marigold, Tahoma, Trebuchet MS, Modern, Roman, sans-serif" color=#333399 size=1>(RM)</FONT></TD><TD width=76><DIV align=left><FONT face="Arial Black, Garamond, Georgia, Marigold, Tahoma, Trebuchet MS, Modern, Roman, sans-serif" color=#333399 size=1>2,100</FONT></DIV></TD><TD width=75> </TD></TR><TR borderColor=#ccffcc><TD width=147><FONT face="Arial Black, Garamond, Georgia, Marigold, Tahoma, Trebuchet MS, Modern, Roman, sans-serif" color=#333399 size=1>Limit of Positive Stability </FONT></TD><TD width=48><FONT face="Arial Black, Garamond, Georgia, Marigold, Tahoma, Trebuchet MS, Modern, Roman, sans-serif" color=#333399 size=1>(LPS)</FONT></TD><TD width=76><FONT face="Arial Black, Garamond, Georgia, Marigold, Tahoma, Trebuchet MS, Modern, Roman, sans-serif" color=#333399 size=1>125 degrees </FONT></TD><TD width=75> </TD></TR><TR borderColor=#ccffcc><TD width=147><FONT face="Arial Black, Garamond, Georgia, Marigold, Tahoma, Trebuchet MS, Modern, Roman, sans-serif" color=#333399 size=1>Sail Area</FONT></TD><TD width=48><FONT face="Arial Black, Garamond, Georgia, Marigold, Tahoma, Trebuchet MS, Modern, Roman, sans-serif" color=#333399 size=1>(SA)</FONT></TD><TD width=76><FONT face="Arial Black, Garamond, Georgia, Marigold, Tahoma, Trebuchet MS, Modern, Roman, sans-serif" color=#333399 size=1>1,081 sq. ft.</FONT></TD><TD width=75><FONT face="Arial Black, Garamond, Georgia, Marigold, Tahoma, Trebuchet MS, Modern, Roman, sans-serif" color=#333399 size=1>100.46 sq. m</FONT></TD></TR><TR borderColor=#ccffcc><TD width=147><FONT face="Arial Black, Garamond, Georgia, Marigold, Tahoma, Trebuchet MS, Modern, Roman, sans-serif" color=#333399 size=1>Spar Height Above</FONT></TD><TD width=48><FONT face="Arial Black, Garamond, Georgia, Marigold, Tahoma, Trebuchet MS, Modern, Roman, sans-serif" color=#333399 size=1>DWL</FONT></TD><TD width=76><FONT face="Arial Black, Garamond, Georgia, Marigold, Tahoma, Trebuchet MS, Modern, Roman, sans-serif" color=#333399 size=1>65.17' </FONT></TD><TD width=75><FONT face="Arial Black, Garamond, Georgia, Marigold, Tahoma, Trebuchet MS, Modern, Roman, sans-serif" color=#333399 size=1>19.86 m</FONT></TD></TR><TR borderColor=#ccffcc><TD width=147><FONT face="Arial Black, Garamond, Georgia, Marigold, Tahoma, Trebuchet MS, Modern, Roman, sans-serif" color=#333399 size=1>Masthead Sail Plan</FONT></TD><TD width=48><FONT face="Arial Black, Garamond, Georgia, Marigold, Tahoma, Trebuchet MS, Modern, Roman, sans-serif" color=#333399 size=1>E</FONT></TD><TD width=76><FONT face="Arial Black, Garamond, Georgia, Marigold, Tahoma, Trebuchet MS, Modern, Roman, sans-serif" color=#333399 size=1>20.68'</FONT></TD><TD width=75><FONT face="Arial Black, Garamond, Georgia, Marigold, Tahoma, Trebuchet MS, Modern, Roman, sans-serif" color=#333399 size=1>6.30 m</FONT></TD></TR><TR borderColor=#ccffcc><TD width=147> </TD><TD width=48><FONT face="Arial Black, Garamond, Georgia, Marigold, Tahoma, Trebuchet MS, Modern, Roman, sans-serif" color=#333399 size=1>P </FONT></TD><TD width=76><FONT face="Arial Black, Garamond, Georgia, Marigold, Tahoma, Trebuchet MS, Modern, Roman, sans-serif" color=#333399 size=1>54.52' </FONT></TD><TD width=75><FONT face="Arial Black, Garamond, Georgia, Marigold, Tahoma, Trebuchet MS, Modern, Roman, sans-serif" color=#333399 size=1>16.762 m</FONT></TD></TR><TR borderColor=#ccffcc><TD width=147> </TD><TD width=48><FONT face="Arial Black, Garamond, Georgia, Marigold, Tahoma, Trebuchet MS, Modern, Roman, sans-serif" color=#333399 size=1>I </FONT></TD><TD width=76><FONT face="Arial Black, Garamond, Georgia, Marigold, Tahoma, Trebuchet MS, Modern, Roman, sans-serif" color=#333399 size=1>61.0'</FONT></TD><TD width=75><FONT face="Arial Black, Garamond, Georgia, Marigold, Tahoma, Trebuchet MS, Modern, Roman, sans-serif" color=#333399 size=1>18.59 m</FONT></TD></TR><TR borderColor=#ccffcc><TD width=147 height=2> </TD><TD width=48 height=2><FONT face="Arial Black, Garamond, Georgia, Marigold, Tahoma, Trebuchet MS, Modern, Roman, sans-serif" color=#333399 size=1>J </FONT></TD><TD width=76 height=2><FONT face="Arial Black, Garamond, Georgia, Marigold, Tahoma, Trebuchet MS, Modern, Roman, sans-serif" color=#333399 size=1>16.97'</FONT></TD><TD width=75 height=2><FONT face="Arial Black, Garamond, Georgia, Marigold, Tahoma, Trebuchet MS, Modern, Roman, sans-serif" color=#333399 size=1>5.17 m </FONT></TD></TR></TBODY></TABLE></TD><TD width=96><TABLE width=100 border=0><TBODY><TR><TD align=middle height=145><IMG height=139 src="http://www.sailnet.com/images/content/authors/wood/T451.jpg" width=96 align=center></TD></TR><TR><TD width=100 height=27><DIV align=left><FONT face="Verdana, Arial, Helvetica, sans-serif" color=#ff6666 size=3><B><FONT color=#3333ff size=2>Turner Yachts 580 Read Rd. St. Catherines, Ont. Canada L2R7K6 905.934.8300</FONT></B></FONT></DIV></TD></TR></TBODY></TABLE></TD></TR></TBODY></TABLE><DIV align=right></DIV><DIV align=right></DIV><DIV align=right></DIV><DIV align=left></DIV><DIV align=right></DIV><DIV align=center></DIV><DIV align=right></DIV><P>On deck the Turner 45 is simplicity itself. Decks are wide and clear, and the large cockpit is geared for action. The helmsman is separated from the crew by the mainsheet traveler and a 60" destroyer wheel running in a cockpit channel. An unusually high bridge deck makes access to the companionway difficult, but adds space to the smallish galley below. </P><P>The Turner 45 does have some performance cruising appeal as well. Power is supplied by a standard 47hp Yanmar turbo diesel through a "Z" drive just aft of the keel. 30 gallons of diesel should be adequate tankage. Stainless steel tanks hold a surprising 150 gallons of water and another 70 of waste holding. Two hatches and five opening ports are standard. </P><P>Down below, the combination of white surfaces with teak paneling and trim creates a modern classic in rich contrasts. Two staterooms and two heads are separated by an ample saloon amidships. Hanging locker space is generous as is the nav table. </P><P>At a base price of US$385,000, the Turner T45 will not be for everyone. Ready to race with a full complement of sails, electronics and gear, this head-turner should price in at close to $500,000. But the fun it could generate might be worth it. </P></HTML>
