Blogs
Go Back   SailNet Community > General Interest Forums > Buying a Boat
User Name
Old 04-12-2001
rbaker6966 rbaker6966 is offline
rbaker6966 is on a distinguished road
Volvo Sail Drive
Any experiences with the Volvo Sail drive; looking at a 93 boat & need info! Pro''s Cons, etc...
Thanks!
Old 04-14-2001
paulk paulk is offline
paulk is on a distinguished road
Volvo Sail Drive
Early Saildrives got a bad reputation for corrosion problems because ''knowledgeable'' mechanics insisted upon grounding them improperly, and electrolysis ate them up. (What would you expect when you create a battery with an ocean of electrolyte?) Otherwise, saildrives solve a lot of problems. They make the propeller horizontal, so it pushes the boat more efficiently. (Unlike the standard shaft, which on some boats has to be at such an angle that it seems like the prop is trying to push the boat more out of the water than forward.) Saildrives also reduce wetted surface compared to many shaft/strut installations. They also avoid alignment problems that can cause vibration and failure of engine mounts and other parts. No stuffing box means not worrying about whether it is leaking too much or not leaking enough. All in all, saildrives seem to make a lot of sense, though others may have other opinions, and may know more about this particular brand.
Old 04-17-2001
fer@fer's Avatar
fer@fer fer@fer is offline
fer@fer is on a distinguished road
Volvo Sail Drive
I used two of them during more than 13 years. No problem at all.
The last one, on a Frers 36, I used it during 10 years, and never needed even to change the hull gaskets; despite I checked them every season.
Maintenance is clean and easy.
Aluminium folding prop did need replacement after 5 years.
But as said by the other colleague, no leaks, no vibrations, no aligment. The hazard is that you won´t notice it is there.
Regards.
Fernando
Display Modes
vB code is On
Ketch/Yawl Handling svsymphony Seamanship 19 07-05-2008 01:19 AM
Sloop, Cutter or Ketch jsgsail Buying a Boat 16 01-11-2008 02:20 PM
Traveler usage? Humpwalker Seamanship 22 02-17-2007 10:54 AM
Windward performance deseely General Discussion (sailing related) 13 01-12-2007 01:09 PM
Heavy weather sailing sailorfrank Learning to Sail 15 06-08-2002 04:38 AM
SEO by vBSEO 3.0.0 RC8
(c) Sailnet 2000-2006
