Blogs
Go Back   SailNet Community > General Interest Forums > Buying a Boat
User Name
Old 09-27-2000
bishopn bishopn is offline
bishopn is on a distinguished road
Purchasing a used bluejay
Can anyone fill me in on this boat''s handling characteristics? (I have limited experience.) Also, do you have any hints/tips for inspection prior to purchase? Any ideas about the ideal, small boat, manageable by a woman who''s not into racing---just likes being out on the water?
Old 09-27-2000
Jeff_H's Avatar
Jeff_H Jeff_H is offline
Moderator
Jeff_H will become famous soon enough
I raced Bluejays as a kid. They were the primary Jr. trainer on Long Island Sound. They were typically sailed with crew weights of a couple hundred pounds of less. They were quite weight sensative: too much weight and they were really sluggish, to little weight and they were hard to keep level enough to be competetive enough in a breeze.
Even by the standard of the day they were quite heavy and a bit under canvassed and so were considered pretty slow. They pointed OK but were no match for boats like the Flying Jr. or a 420.
I don''t think two adults are light enough to race one competitively. I could be wrong but it seems like the older kids began to loose competetiveness at some point and moved on.
Still they make nice daysailors for an adult or two and would be fun to own in an envirnment with a bit more breeze than Long Island Sound.
BTW: Is your boat wood?
Good luck
Old 10-02-2000
paulk paulk is offline
paulk is on a distinguished road
The Blue Jay, designed by Sparkman & Stevens, is still the primary Jr. Trainer on Long Island Sound. We have about 100 of them at a regatta at our club each summer. It is a simple boat that works well as a trainer because it has a main, jib, and spinnaker and requires teamwork from the skipper and crew. Fast Opti sailors who move to the Laser get to the 420 and find themselves surprised by things like jibs, spinnakers, and having to coordinate with someone else in the boat. The Blue Jay''s hard chine and adequate, but not overly generous sailplan makes it a relatively stable platform for learners (quite unlike a 420). An adult will find that the size of the sails makes them easy to handle. If the spinnaker gets messed up, twisted, for example, it''s small enough for to stand up, grab the sail and and untwist. Shorter, (younger) hands would find such a maneuver more difficult. The fact that it is a known quantity means that when its time to sell again, there should be a market for one. Older boats may have leaks around the centerboard. I re-glassed ours this season. The keel can also have problems if the boat''s been trailered a lot or left with water in it on the trailer. (The weight or shock of bouncing on the trailer can damage the keel.) Also make sure the air tanks don''t leak too much. (Check the Blue Jay Class Association Website for more info.)
That said, you may find the Blue Jay a bit small for two adults. Something like a Rhodes 19 would give you similar stability, training and resale potential with enough room to invite some friends out with you. You''d also be able to put an engine on a larger boat without totally killing performance. If you look around in your area you will see what boats are there that fit in your niche and suit your needs-- and post again about that one.
ely stable ey''re hot suddenly find out
Display Modes
vB code is On
purchasing a catalina 28 pdean Buying a Boat 0 06-14-2004 11:36 AM
Purchasing a used boat in Thailand? Myblueheaven Buying a Boat 1 12-22-2003 06:26 AM
Charter Boat purchasing JohnManzano Buying a Boat 3 07-18-2003 02:37 PM
Purchasing through Charter Programs jillskor Buying a Boat 13 09-09-2001 07:30 AM
Purchasing a Bristol 29.9 RMelvin Buying a Boat 2 11-30-2000 06:26 PM
SEO by vBSEO 3.0.0 RC8
(c) Sailnet 2000-2006
