My advice was specific to the Tartan 34 and was not based on performance as much as the Tartan 34's behavior in gusty conditions. The T34 has a particularly long cockpit. When you put the traveller on the house you need to go to a new boom with a deeper section to resist the high bending loads and a very high purchase to deal with the very high loads (roughly 3,000-4,000lbs upwind) for a 34 footer. In talking to an owner who converted back from a coachtop traveller, they felt that converting back was a matter of safety sailing in changeable conditions such as those that William's planned sailing venue is likely to be exposed to as well.
The tiller vs
wheel problem is also specific to the Tartan 34 (and a lot of older boats of that era). The cockpit layout on the Tartan 34 was not really designed to accommodate
wheel steering. As a result you end up with a very small
wheel that is placed on a pedestal placed very far forward in the cockpit. The
wheel position cuts the cockpit in thirds and blocks access to the length of the cockpit from the companionway. It limits the ability to
rig a cockpit table or simply hang out when on the
anchor. I also suggested that the
wheel made no sense for William because William is concerned with singlehanding and you can't reach the control
lines from
wheel position. Also because of the binacle position you cannot see the leading edge of the
jib without sitting on the coaming and sailing with your arm completely outstretched, not a very suitable resolution. When a T34 is sailed with a tiller and tiller extension, all control
lines can be reached and the tiller tilted out of the way at
anchor.
There was nothing about performance in my recommendations. My recommendations were strictly about William's specific goals for the boat, ease of handling, safety, and practical utility considerations.
Respectfully,
