Blogs
Boatbldg & Repair
Galley
Hardware
Interior
Plumbing
Tlr & Wtrsprts
Videos
Go Back   SailNet Community > General Interest Forums > Buying a Boat
User Name
  #11 (permalink)
Old 04-09-2007
ahemingway75 ahemingway75 is offline
ahemingway75 is on a distinguished road
I have a 1982 Hunter 25' which I race/cruise and love. Fast, solid boat! However, nobody could pay me to own a new Hunter 25'. Poor construction and more for a housewife to putter around in.
Two great questions! I myself just bought a Mercury 9.9. This is PLENTY of engine. I almost went 6hp, but if you are caught in a storm you will want that little extra. Do not go any higher! The dry weight is 93lbs. My old 9.9 was 78...I believe. I was a little concerned to I put new bolts/lock nuts along with very large washers, along with another set of washers to offset the weight (Hunter only puts 4 bolts with 4 little washers. I was totally not comfortable with this.) The only problem is there is a gas tank shelf and you have squeeze between into the bilge to get to the lower two bolts. It was very uncomfortable to do, but my mind is totally at ease now. I also made a new engine mount out of 3 pieces of 3/4" oak ply (gorilla glued it, sanded and varnished it with 3 coats of man-o-war high gloss. Looks great!
Now...more important, the crack in the keel. It is normal to have what may look like a seperation. The question is, are there water stains that look like leaks? If not you might be halfway home. Second, go onboard and lift up the bilge board in the main salon. You will see, I believe 4 keel bolts. If they are rusted to hell then move on to your next possible purchase. Otherwise, throw a coat of ablative paint and set sail. You might notice that water will fill that bilge where the keel bolts are. Don't worry, that is normal. That is coming from the percperation or other areas of the boat, but settles there because it is the lowest point of the hull.
  #12 (permalink)
Old 04-11-2007
SailinJay SailinJay is offline
SailinJay is on a distinguished road
Perhaps the OP has resolved his issues, one way or another, given that his post was nearly 10 months ago, and there was no further discussion.
  #13 (permalink)
Old 04-30-2008
Gralex Gralex is offline
Gralex is on a distinguished road
Sure the post might be a bit old, but I am asking myself the very same question right now and the discussion was still useful. Thanks.
Sponsored Ad
Display Modes
vB code is On
Hunter 260 vs. Catalina 250 C_QUAD Buying a Boat 6 12-10-2006 04:19 PM
Buying: C&C, Hunter, Chance, Paceship--HELP! pnaroth Buying a Boat 16 06-29-2006 11:58 PM
Advice for breaking into racing dzipkin Racing 3 12-04-2000 03:02 PM
Hunter 42 - at sea maroca Buying a Boat 6 11-19-2000 06:13 PM
Hunter vs. Beneteau PASailor Buying a Boat 10 11-12-2000 08:04 PM
SEO by vBSEO 3.0.0 RC8
(c) Sailnet 2000-2006
