Sun 27 (aka Sun 838)
This boat was built in fair numbers in Richmond BC by Spencer Boats in the late 70s/maybe early 80s I believe.
Quite spacious, with good headroom, I think the build quality is average or better, haven't heard of any glaring problems with these models and there are a few around in the Vancouver/Victoria area still. Some have even been out in the local PHRF fleets.
The Sunstar 31 (a big sister) had an encapsulated keel - so probably the 27 does too but I'm not positive about that. That may be a factor for you. (primarily it depends on the ballast used how good/bad/indifferent you may feel about that). On the plus side there are no keelbolt/hull keel joint issues - on the minus if it's ever damaged and it's iron ballast that can lead to some serious issues.
Typical Perry in that they will not be overcanvassed, probably not a bad beginner's cruiser and a pretty substantial first boat for anyone. Of course it goes without saying that you get it properly surveyed and checked over, and get a reasonable purchase price.
