Originally Posted by sailphoto
I am not a cat expert but have been told by cat owner whom I helped load his boat that he carries almost all provisions as far out on the beams as possible so that the weight acts as windward ballast helping to translate the weight into "ballast" and thereby aiding acceleration mentioned by jeff_H. Mathematically it makes sense to me.
I doubt that really has much effect, as the weight put towards the end of the beam in the leeward hull would probably counteract the weight in the windward hull. It would also seem to me, that by putting the weight out to the extreme beam ends, you'll tend to increase the lateral pitching moment of the boat—much as adding weight to the bow or stern of a monohull increase the tendency to hobbyhorse...but I'm not a naval architect, so I can say for sure. If this is true, that is probably a really bad idea.
That said, the amount of weight that will start to detrimentally effect a catamaran's performance has a lot to do with the design and size of the catamaran. An ultra-lightweight racing catamaran will be more quickly affected than a heavy cruising catamaran.
As a general rule, most cruising catamarans have far more stowage space than can reasonably used before the boat's performance starts to suffer.
POST.
