Blogs
Go Back   SailNet Community > General Interest Forums > Buying a Boat
User Name
Old 09-30-2000
jw.nyc jw.nyc is offline
jw.nyc is on a distinguished road
Sail inspections
I''m in the process of buying my first boat. What should I look for when inspecting the sails? Are there any good books on the subject?
TIA
jw
Old 10-01-2000
paulk paulk is offline
paulk is on a distinguished road
Sail inspections
Used sails are hard to judge. While you can look for tears, worn or frayed areas, it''s hard for most people to see if a sail is "blown out", even if it''s up. (The dacron in a sail can last for 20+ years, but the shape may have dissappeared in 2.) Newer materials like kevlar are harder to gauge because the material (and shape) may look fine right up to the point it fails. Worn, "fuzzy" areas, or pieces that are coming unglued (delaminated, in the parlance)are obvious concerns that may be fixable. We have found that sailmakers are helpful in determining how old sails are, what needs fixing (and can be) and what isn''t worth fixing (or can''t be). It''s an adventure.
Old 10-01-2000
Sail inspections
Thanks for the tip. I did stumble across Bacon''s web site and they say to test with a sail needle. Trying to pass the needle through the sail cloth you should get some resistence and not hear any poping sounds.
jw
Old 10-02-2000
Sail inspections
The sounds you get from passing a needle through the cloth will vary depending on what the cloth is made of and what it may have been treated with by the manufacturer (plastic coatings stabilize warp and woof before the sailmaker gets it). I''ve never heard popping sounds, unless its the sound of the stitching pulling out when you should have reefed earlier.
Old 10-17-2000
cditzen cditzen is offline
cditzen is on a distinguished road
Sail inspections
A high-level kind of test seems to be to check if it''s crispy or nice and soft. You DON''T want the latter, not even on Dacron sails, since they also typically have been coated with some wax-like feeling material that gives as the sail is used.
If the sails are crispy, you are typically in reasonable shape.
Display Modes
vB code is On
HTML code is Off
Ketch/Yawl Handling svsymphony Seamanship 19 1 Day Ago 01:19 AM
Sloop, Cutter or Ketch jsgsail Buying a Boat 16 01-11-2008 02:20 PM
New to Sailing, please Help =) xyris Learning to Sail 17 03-05-2007 07:39 AM
Traveler usage? Humpwalker Seamanship 22 02-17-2007 10:54 AM
Windward performance deseely General Discussion (sailing related) 13 01-12-2007 01:09 PM
SEO by vBSEO 3.0.0 RC8
(c) Sailnet 2000-2006
