Blogs
Go Back   SailNet Community > General Interest Forums > Buying a Boat
User Name
Old 07-22-2006
Liquidglowfish Liquidglowfish is offline
Liquidglowfish is on a distinguished road
Cat 22 Swing Keel Question
I'm in the process of buying a 1977 Catalina 22, and I have a general question about swing keels. From what I understand they generally have a tendency to rust a bit which shouldn't pose too much a problem; but I am curious about upkeep and refinishing the keel should it be needed. Maybe sand blasting? or just some sanding and repainting? A point of note: I am a college student with limited funds but ample time to try and do the work myself. Any suggestions related or unrelated would be more than welcome, thanks!
Old 07-22-2006
DirtManly DirtManly is offline
DirtManly is on a distinguished road
For just redoing the bottom I usually just sand swing keels, although I alway use a bariier coat on the swing keel. Interlux 2000 barrier coating seems to be the best metal primer on the planet. The only times that I have sand blasted the keel is when I have rebuilt pivot systems. Catalina 22 and 25 seem to have had to much play from side to side from the factory and they only get worse over time. Mind you if your not racing the boat it rarely gets bad enough to become a real problem, more like a real annoyance.
If you are going to do this kind of work your self, PLEASE get a VERY GOOD full mask respirator. Do NOT skimp on this, this stuff is absolutely no good for your lung or eyes.
I am very fond of Catalina's and believe that they are a reasonably good starter boat for just about anyone.
Very Best of Luck
Dirt
Display Modes
vB code is On
Swing Keel or Fixed Wing Keel? Catalina 22 or 25? BRCincy Buying a Boat 27 5 Days Ago 10:03 PM
Draft minus keel depth on Cape Dory 28? Nonkjo Buying a Boat 4 03-09-2007 04:59 PM
Electrolysis / Keel stepped mast WillS Gear & Maintenance 14 06-27-2006 01:45 PM
Cat 22/Bayliner US25, Cat 25? JeromeFr Buying a Boat 3 06-06-2001 08:55 AM
1965 Islander 32 Keel bolts Gene927 Gear & Maintenance 0 03-25-2001 06:00 PM
SEO by vBSEO 3.0.0 RC8
(c) Sailnet 2000-2006
