- Quick Menu
09-06-2006
Moderator
No fight from me Camaradie. We each come at sailing from our own directions, and I understand that in most thing sailing there is no one single universally correct answer. I am focusing a bit more on the "good coastal cruiser' part and you are perhaps focusing a bit more on the 'possibly offshore cruiser' part. I think the diversity of opinion should be helpful in showing that there is a spectrum of choices. With more information from the original poster we each might move to a more central position.
The concern that I might have with the boats on your list is thier comparatively high price relative to the boats on Susan's original list.
Respectfully,
09-06-2006
Hey Jeff (and others),
The suggestion about the fractional rig is a good one. Is there a resource on the 'net somewhere where one can search based on things like rig configuration (full, fractional, cutter, split, ...), hull configuration (fin keel, full, rudder type), deck configuration (aft/center cockpit), interior configuration (# staterooms, galley, heads), auxilliary configuration (gas, diesel)? In addition to the normal LOA, Year, Builder, Price, Location
Cheers,
Mike
09-07-2006
Hi everyone,
Thanks for all of the great feedback. I guess I am leaning more toward the offshore capability, as I'd rather have too much boat than not enough. My only concern with some of the heavier, full-keel boats is that I might not be able to maneuver them well.
I have been considering a Cape Dory and should have added it to my list. I think the Pac Sea is out of price range. The Tayana is also very nice, but looks like it might require too much maintenance due to all of the wood.
The Pearson looks good, and if I were going to keep to the coast, I'd consider it. I really can't afford to buy 2 large boats over the next 4 years, so I need to go straight to the right one. The Tartan also looked good as a coastal cruiser, but I am not sure about the keel/centerboard that seems to be on most in the size/price range I am looking. I think I'd rather have a fin keel and a skeg-hung rudder or full keel.
As far as the singles thread -- I'd rather not be a single-hander, so I second that suggestion  It's very hard to find someone who would be willing to give up life on land.
09-08-2006
Moderator
Pretty much all of these boats are suitable for offshore use. None of them within your apparent price range are likely to be set up for distance cruising or single-handing without some modification, in some cases a huge amount of modification. This is especially true of the older designs like the Vanguard which can be single-handed (as a kid I would single-hand my family's Vanguard but it was brutal) but which are nearly imposible to make into an easily handled offshore capable single-hander.
The thing about the dedicated offshore type boats on the list is that they are often under-canvassed which means that you either end up losing a lot of sailing days or using extremely large overlapping light air sails, which in turn are very difficult to single-hand as compared to a more normal sailplan.
I would not rule out a keel centerboard boat like the Tartan 34. These boats are really a shoal draft fin keel with skeg hung rudder. The centerboard really helps upwind, and allows very precise adjustment if the balance of the sail plan, nearly eliminating weather helm and making these boats easier to handle and less tiring to steer manually, or under vane or autopilot.
09-08-2006
Moderator
GreenBoat...I don't think any of the boats I listed would be too much to hadle at sea. The additional weight and long keels give them directional stability and a sea kindly motion. They are all easily steered by a wind vane as well. Lighter is not better at sea or easier to handle IMHO and of course opinions vary on this...but I would refer you to a current discussion on the SSCA bulliten board. In this thread the writer describes a recent return trip from Hawaii on a Cal40...a well built but light boat and reaffirms his decision to buy a Hans Christian.
Note that the Cape Dory is also available in a 32 footer if size is a concern. The Tayana does have a lot of wood...but some have no teak decks or removed teak decks that have been re-done in glass, so just keep an eye on Yacht-world if you otherwise like the boat.
09-08-2006
Moderator
As a counterpoint to Cam's comments;
On the other hand, in boats of the size that we are discussing, full keels offer minimally more directional stability than a well balanced fin keel skeg hung rudder boat, (especially since the bulk of tracking ability in this size range comes from the dynamic balance of sails to keel profile, rather than from the length of the keel) and that directional stability comes at the price of much higher helm loads, which can really wear you down and in my experience actually make it harder to use a vane steering rig.
That so-called seakindly motion comes at the price of larger roll angles which make it harder to move about in a seaway and for some people are more likely to produce seasickness.
With regards to your comments on lighter boats, I would suggest that displacement is a better way to size a boat than length. By that I mean that ease of handling, carrying capacity, accomodation space, and maintenance costs, etc are pretty much directly proportionate to displacement. The heavier the boat, the bigger the sails and the harder the boat is to handle.
For any given person, there is a displacement that they can comfortably handle, more than than that amount becomes burdensome. The traditional rule of thumb for offshore capable distance cruising boats was 2 1/2 to 5 long tons per person (roughly 5500 to 11000 lbs). In a general sense, better winches, sail handling gear, deck layouts and ground tackle handling gear have stretched that range a bit, of course there are people whose athletic ability allow them to be comfortable handling much more than that.
Within reason, for any given displacement, and with similar weight distributions (for example ballast to weight ratio) the longer the waterline the easier the boat will be to handle, the more seaworthy it will be, the more comfortable its motion, the more it will be able to carry, and faster it will sail.
In other words, if we compare that Cal 40 to the Hans Christian 33, the Hans Christian 33 is 3,000 lbs heaver, has a lower ballast to displacement, carries nearly 150 square feet of sail area, on a shorter waterline with a greater beam. In other words despite its greater drag (and therefore the need for more sail area) the Hans Christian has less ballast stability and depends on more form stability than the longer Cal 40. The lower sail area, slower roll motion (less form stability) and higher stability should actually make the Cal 40 an easier boat to handle, and a more comfortable boat than the smaller but heavier Hans Christian 33.
In the case of the Cal 40 there is some loss of motion comfort that comes from pitching due to its short waterline length relative to its overall length. To continue this discussion, a boat like the Tartan 37 which has the same displacement as the Cal 40 but a longer waterline than either of the other two and a shorter length on deck, and significantly higher ballast than either of the other two, should offer even greater stability, motion comfort and ease of handling (except that the big jib, small mainsail rig proportion of the Tartan 37 doesn't make them as easy to handle as a boat with a more moderate rig proportion) compared to the other two boats.
And just to put all of this in proportion a boat like the J-40 (J's cruising series) has a longer waterline and way higher ballast ratio than any of these boats, similar waterline beam (greater beam at the deck though), a displacement higher than the Cal and lower than the Hans Christian, and an easier sail plan proportion to handle, should be the easiest of the bunch to handle, offer the most motion comfort, and probably offers the most seaworthiness of the bunch.
BTW I realize all of these are bigger and more expensive boats than Greenboat is looking for.
Respectfully,
09-09-2006
sfumato99
P30
Hi Susan --
My window is closer to yours -- my older son just went to college, my younger is a junior in high school. With my business, I can be anywhere, so I'm starting to think seriously about where to go. But as for a boat, all the suggestions you've gotten sound like terrific boats. You could also check out John Kretchmer's Used Boat Guide (Sheridan House, 2002, ISBN 1-57409-150-6) for some good ratings -- he has several idices that are good to know (safety, market value, durability, etc). While all the suggestions are good, I don't know that you can get most of them in your price range. No matter how good the boat's condition is, you should keep a sizeable reserve for inevitable maintenance expenses -- so I would figure a maximum you can afford, and shoot for at most 70% of that.No matter how great the boat is, it's useless if you can't afford a new alternator or get the roller fixed. I realize this sounds obvious, but it's easy to start thinking that extra 4 or 5 grand when you are looking at boats. I deal in violins, and I see it happen all the time -- my most difficult job is trying to keep clients from spending too much upfront.
I got a Pearson 30 this past spring up in Boston, and sailed it down to Greenwich, where I keep it. A great boat;fast and responsive, but good in heavy weather. The latter I discovered when I got caught in a ferocious gale the last day -- the worst weather I've ever been in, and I've sailed all over for 40 years now. I like the size -- plenty of room down below, but not so far to the foredeck that you can't get back to the cockpit in a hurry.
Prioritize what matters, and you will be able to get something at a surprisingly good price. Engine, prop, decks, hull, rigging -- they are what count, but price is driven by appearance; wood and so on. Whatever you think is important, that's fine -- but make a list before you even start looking. It will help keep you grounded when you see the gorgeous teak and chart table etc.
Anyway -- good luck!! And welcome back to the water -- Jim
07-09-2007
I chimed in to another post about the Dehler 101 I just bought and am loving a lot.
Lots of quality space below for longer crusing (can sleep 7!) with a great sized cockpit because hey, that's where you sail right? It's fast enough for club racing (IOR design of the 70's-80's). I sail single handed at times and find the boat quite easy to handle given the fractional rig and placement of everything needed at the tiller. I did replace the mid cockpit traveler with a Harken system but other than that, it's a great sailing in it's stock config.
if you have 30K or so to spend, you'll get a lot of boat for your money.
Happy to post pics if you'd like to see more of her.
07-09-2007
Re Member
These old threads are great, thanks for bring them back for everyone to enjoy again, kinda like mom's leftover meatloaf
07-09-2007
Bite Me
I am curious to know what happened. I sent her a PM.
Great men always have too much sail up. - Christopher Buckley
fogcitysailor
| Thread Tools |
Search this Thread |
| Display Modes |
Linear Mode
HTML code is Off
